I sold my CTS-V2 to build an NB1 and then buy a CTS-V again then build the NB1 again
Old 06-16-2017, 12:20 AM
  #161
Padlock's Avatar
Total Cats: 563
Havent updated in a few days.... so here we go...
As of Friday it looked like a scattered dirty miata disaster. I had everything necessary pulled off the chassis though, so that was nice.
Planning for the future, I picked up a fender ruining mechanism
I made the executive decision that this was optional equipment on a car with a cat and resonator #weightreduction
I burned diff bushings out when it was 95 degrees outside on Monday, which is as awful as it sounds. Got Poly's installed and shot it with a nice coat of paint to pretty it up while I'm at it
Currently in progress of removing surface rust from control arms, painting them, installing ELBJ, installing zerks, and installing NASA package Sadfab delrin kit. Here are 2 finished pieces
I'd just like to point out my inner unknown genius by painting control arms the color of anti-seize. Given its nature to get everywhere upon application, I bet you cant even tell where I made a mess.
And lastly, tonight I got the diff put back home which is a really fun task to do by yourself. Started bolting on orange things as well.
Padlock is offline
Old 06-16-2017, 03:17 AM
  #162
icantlearn's Avatar
Total Cats: 117
you need to do a gauge reset. I usually clean everything up and reset the garage after one "checkpoint" is passed. Yours being diff installed.
icantlearn is offline
Old 06-16-2017, 09:02 AM
  #163
Padlock's Avatar
Total Cats: 563
Nahh, I currently have organized chaos.. All the hardware is in a pile next to where it was removed.. I'll clean the garage when its done
Padlock is offline
Old 06-21-2017, 10:59 AM
  #164
Padlock's Avatar
Total Cats: 563
Status update:
  • Painted rear tow hooks because racecar
  • Painted front calipers orange because 949 says orange is faster
  • Painted rotor hats because screw surface rusted hats with everything else looking minty
  • Got the 7/8" bit in from the mail to ream out the delrin bushings after being pressed in.
Waiting on the following things in the snail mail
  • Replacement front upper ball joint boots. (Pickle fork destroyed my old ones. Joints are still stiff.)
  • Tie rod ends.
  • Redline 75W90 diff fluid
  • 949 Valve Stems
  • 245/40/15 Hankook RS4's (backordered until end of the month currently)
Need to do:
  • Install new tie rod ends
  • Grind off and plug all threaded bosses on the steering rack tube
  • Paint steering rack
  • Paint rear calipers to be just as fast as the fronts
  • Finish pressing in and installing delrin bushings in the RLCA's and FUCA's
  • Paint RLCA's and FUCA's
  • Bolt everything together (control arms, rack, coils, sways, endlinks)
  • Add fluid to diff (I'm told this is important?)
  • Buy proper fluid (motul most likely?) and bleed the whole brake system manually
  • Mount / Balance tires/wheels when the tires arrive
  • Roll/Pull/Destroy Fenders to fit 10"/245 combo
  • Corner balance and align
Padlock is offline
Old 06-27-2017, 03:28 PM
  #165
Padlock's Avatar
Total Cats: 563
Status update:
  • ALL THE PARTS ARE IN!
  • Tires/Wheels mounted.
  • Rack Properly Depowered (Large end nut did NOT want to come out which made for a bunch of scary thoughts thinking I destroyed the rack tube threads, but all ended up ok)
  • Front Upper ball joint boot replaced.
Need to do:
  • Add diff fluid
Padlock is offline
Old 06-27-2017, 05:16 PM
  #166
Padlock's Avatar
Total Cats: 563
Just a bit more width than what i had
Nom nom nom
Padlock is offline
Old 06-27-2017, 07:38 PM
  #167
icantlearn's Avatar
Total Cats: 117
those look so good...
Old 06-28-2017, 12:09 AM
  #168
Padlock's Avatar
Total Cats: 563
Yeah, in hindsight I'm so happy I ended up with these over 6ul's. Although both look good, the concavity on these is much more my style
Tonight I was having issues getting the rlca-o's pressed in place. So after some thought, i got creative with a 5/8" threaded rod, some washers, and some nuts. The bushings pressed right into place afterwords with some simple wrench action. $5 well spent
After finishing pressing bushings in (which addmittedly took long than it should have without ideal tools), I got zerks installed, masked them off, and got the last of the control arms painted up after removing surface rust
hoping to have the car on the ground by friday as I would like to take it on a cabin trip for the weekend of the 4th. Likely will just run the old tire setup however as I don't want to rush myself on the fender job. I'll save that for next week.
Padlock is offline
Old 06-29-2017, 01:18 AM
  #169
Padlock's Avatar
Total Cats: 563
Had a friend stop over and give me a hand which made progress a lot faster.
Depowered rack painted up then installed with new tie rod ends.
xidas installed
All control arms greased/installed
ball joints and tie rods tightened
I got antsy and wanted to see how the wheels would look.
taking a half day at work tomorrow to finish up what's left:
Paint rear calipers
Install all calipers
install sway bars and endlinks
fill diff with fluid
bleed brakes
tighten down all bolts
set ride height
Eyeball alignment then toss on old tires for the weekend shakedown driving
next week after vacation I'll focus on rolling fenders and getting the car properly aligned and corner balanced with the jongbloeds on. Can't wait!
Padlock is offline
Old 06-29-2017, 11:50 PM
  #170
Padlock's Avatar
Total Cats: 563
Got my goal done for today.
car is all bolted together with an eyeballed alignment on the old tires/wheels. That said, I took the car for a drive down a rough section of road with the xidas and sways on full soft. I don't know how, but I think it rides smoother than it did before all oem even with the sadfab delrin kit. Can't freaking wait to get an actual alignment on it with the rs4s, but that'll be next week
I have the pinch welds set at 4.5" all around.
And just because I wanted to see how it looked on the 10's while messing with it... the orange calipers are a bit brighter than I was hoping for, but once they get a little dirty they should tame down a bit. They look a bit darker while hidden behind the wide wheels. Glad I didn't go standard red..
Padlock is offline
Old 06-30-2017, 01:32 AM
  #171
2manyhobyz's Avatar
Total Cats: 42
Looks great. I still have to roll my fronts but the rears came out great. Take your time and don't skimp on the heat. I probably had them to about 130 degrees, I couldn't hold my hand on the paint. This allowed the paint to be flexable and not crack. Good luck.
2manyhobyz is offline
Old 06-30-2017, 02:48 AM
  #172
Scaxx's Avatar
Total Cats: 884
Xidas are amazing, I have 900/500 and I hit a section of the highway that's a spine breaker in my stock daily a few time and it's way more comfortable. That's not even on their full soft setting. And agreed on the heat, give it lots so it doesn't crack
Scaxx is offline
Old 06-30-2017, 10:50 AM
  #173
Padlock's Avatar
Total Cats: 563
Thanks for the tips. It'll be my first time rolling fenders so I'm going to be referencing the college of YouTube prior to tackling it. The eastwood roller also came with a programmable heat gun with temperature control. If I recall correctly it said to shoot for 120 degrees or so to keep paint pliable. Hoping it shouldn't be too bad.
Padlock is offline
Old 07-05-2017, 10:52 AM
  #174
Padlock's Avatar
Total Cats: 563
So break-in weekend on the suspension went pretty well overall. Got about 350 miles on the car without a major hiccup or rattle to track down, so yay for nailing that all down the first go. A couple notes:
  1. The upper heim on the front driver side sway bar endlink made contact with my coilover body, thus flattening the threads on the body pretty good. Not exactly happy about that, but it is what it is at this point. I have since adjusted my sway bar to the stiffer setting in the front to move the heim away from body. Hopefully this fixes the issue.
  2. Stopped at a friend who races spec Miata and got the suspension all sorted with a string alignment. For the sake of my documentation here's the specs.
    1. Specs I set up:
      1. Front
        1. Camber: -3.3 degrees
        2. Caster: MAX (didn't have the tool to measure on hand). Steering effort isn't bad at all FWIW
        3. Toe: 1/32" OUT
      2. Rear
        1. Camber: -2.9 degrees
        2. Toe: 1/16" IN
      3. Ride Height
        1. 4.5" at the pinch welds with me in the car.
      4. Corner Weights (with me in the car)
        1. LF: 631 lbs
        2. RF: 597 lbs
        3. LR: 611 lbs
        4. RR: 576 lbs
        5. Cross Weight: 1208 lbs (50.0%)
        6. Total Weight: 2415 lbs
        7. Curb Weight (without me in the car): 2240 lbs
Overall the car drives fantastic as-is prior to before, but I'm VERY tire limited on the old tires that are on the car now. Will begin the fender rolling process tonight to get the RS4's fitted. Started out the weekend with the xidas set at click 0 all around and have since moved up to 8 Front and 6 Rear. Still more playing around to do there, but overall made a lot of progress over the holiday weekend.
Padlock is offline
Old 07-07-2017, 12:00 AM
  #175
Padlock's Avatar
Total Cats: 563
I'll let the pictures do the talking. Fenders rolled and pulled. No rubbing noticed so far
Padlock is offline
Old 07-07-2017, 01:12 AM
  #176
DeerHunter's Avatar
Total Cats: 2,246
Lookin' good.
DeerHunter is offline
Old 07-07-2017, 06:01 PM
  #177
Chilicharger665's Avatar
Total Cats: 57
Your car looks awesome! Now drive it awesome.
Chilicharger665 is offline
Old 07-08-2017, 07:40 AM
  #178
mreakus's Avatar
Total Cats: 15
I love the way it is sitting. Congrats!
mreakus is offline
Old 07-08-2017, 10:02 PM
  #179
icantlearn's Avatar
Total Cats: 117
I didn't know a pull was necessary. I might have to go back to get that done
Old 07-09-2017, 08:27 PM
  #180
Padlock's Avatar
Total Cats: 563
Thanks guys
The rear DEFINITELY needs a pull. I have 2.9 degrees of camber in the rear and it just clears. the front could get away with a flat roll although I did a mild pull on those as well to be safe
Padlock is offline
Quick Reply: I sold my CTS-V2 to build an NB1 and then buy a CTS-V again then build the NB1 again
