300hp to 400hp upgrade
Old 04-07-2017, 11:19 AM
  #81
¯\_(ツ)_/¯
Old 04-07-2017, 04:03 PM
  #82
patsmx5's Avatar
Total Cats: 488
Originally Posted by elior77
yes, Pat got 500hp~ with ebay manifold and turbo
If you have read my build thread, I have two turbos to make the big power. That said the Gt3076 I run could for sure make 400whp. I ran it to 30 PSI before with just that turbo, and it would spin street tires on dry concrete to 90mph. But I didn't make 500whp with just that turbo.
patsmx5 is offline
Old 04-23-2017, 01:59 AM
  #83
elior77's Avatar
Total Cats: -481
Got my pistons
The engine will be ready soon, time to order more parts...
83.5mm
8.5:1
elior77 is offline
Old 07-07-2017, 05:57 AM
  #84
elior77's Avatar
Total Cats: -481
Head got surfaced and a rebuild, block machined to 83.5mm and surfaced, all engine parts got acid cleaned.
The crank is one mil smaller then spec - a decision will be made on sunday and the assembly.
Got the oil cooler adapter, oil pressure sensor and all the rest.
What ring gap should I go for ? it is a street car.
The rings manual says 0.050" I saw people go 0.043"... - aiming at 20-25psi of boost.
At what gap do they come from the manufacture ?
elior77 is offline
Old 07-07-2017, 08:13 AM
  #85
ryansmoneypit's Avatar
Total Cats: 456
Weisco XX rings? Follow the instructions. I know 100% that .0050 is wrong. It's a multiplication factor of the bore size.
I highly recommend having te machine shop gap the rings.
ryansmoneypit is offline
Old 07-08-2017, 02:14 AM
  #86
elior77's Avatar
Total Cats: -481
I was wrong with the numbers, the factor is 0.0050" the bore is 83.5mm=3.287" so my ring gap should be 0.0050"*3.287"=0.0164" right ?
Thanks
elior77 is offline
Old 08-23-2017, 03:23 AM
  #87
elior77's Avatar
Total Cats: -481
Getting somewhere
elior77 is offline
Old 08-23-2017, 08:00 AM
  #88
ysleem's Avatar
Total Cats: 7
Im surprised you bought your pistons after having the block bored. What is your piston to wall gap?
ysleem is offline
Old 08-23-2017, 10:37 AM
  #89
Total Cats: 456
your pistons are in backwards.
Old 08-23-2017, 10:48 AM
  #90
Total Cats: 3,019
Nope.
sixshooter is online now
Old 08-23-2017, 11:36 AM
  #91
ysleem's Avatar
Total Cats: 7
No they arent lol
ysleem is offline
Old 08-23-2017, 01:55 PM
  #92
The picture is from the back
Old 08-23-2017, 02:20 PM
  #93
Total Cats: 456
It was an engine builder joke. first thing I tell everyone who just finished a build.
Old 08-23-2017, 02:23 PM
  #94
I actually did install 2 pistons backwards....
Old 08-23-2017, 02:42 PM
  #95
psyber_0ptix's Avatar
No they aren't.
psyber_0ptix is offline
Old 08-24-2017, 09:21 AM
  #96
Total Cats: 1,681
Yes they are.
shuiend is offline
Old 08-24-2017, 10:57 AM
  #97
I like turtles
Old 08-25-2017, 12:47 PM
  #98
elior77's Avatar
Total Cats: -481
Dropped my heart there with the backward joke...
I'll clean the head as much as I can and I'll shorten the oil filer threads there.
Next thing is getting the ARP2000 replacement for the con rod bolt that I broke with a bad torque wrench.
A double torque routine for head studs is a must ?
Thanks
elior77 is offline
Old 08-25-2017, 12:52 PM
  #99
Nice progress.
I use triple routine: 20, 40, 55-60 (depending on whether you're using lube or not)
Old 08-25-2017, 12:55 PM
  #100
elior77's Avatar
Total Cats: -481
I mean do the 25-45-65 twice... tight loose and tight again...
elior77 is offline
Quick Reply: 300hp to 400hp upgrade
