01 VVT Turbo build
Old 02-01-2017, 11:14 PM
Bara83's Avatar
Default 01 VVT Turbo build
Good evening!
I have an 01 VVT, and building an MS turbo setup. I have been reading the forum for a few days now, and I am in complete confusion.
My question would be, could someone please help me, which diy megasquirt kit do I need to be able to control VVT, turbo and keep my AC too. I am pretty advanced in soldering, not afraid of assembling the MS. Also would like to know, what exactly need to get, to be able to build a plug in ECU, what sensors and modifications needed and so on. Yes, Ive searched, and yes, I am more confused than ever.
Thank you for helping me out!
Barabas
Bara83 is offline
Old 02-01-2017, 11:16 PM
psyber_0ptix's Avatar
Yes!
Welcome to the forum!
psyber_0ptix is offline
Old 02-01-2017, 11:38 PM
Bara83's Avatar
Ich verstehe nur bahnhof lol, do you speak german? also thank you for the welcome
Bara83 is offline
Old 02-01-2017, 11:44 PM
acedeuce802's Avatar
Total Cats: 175
https://trubokitty.com/#/ms3xassembly
acedeuce802 is offline
Old 02-02-2017, 11:14 AM
Matt Cramer's Avatar
Ja, aber mein Deutsch ist nicht so gut. Dein Englisch ist viel besser. Du brachst ein MS3 V3.0 mit MS3X fur VVT.
(OK, I can't keep this up and have no idea what the German abbreviation for VVT is!)
Matt Cramer
www.diyautotune.com
Matt Cramer is offline
Old 02-02-2017, 11:33 AM
bahurd's Avatar
Total Cats: 314
variable Ventilsteuerung
bahurd is offline
Old 02-02-2017, 11:36 AM
Total Cats: 1,681
Originally Posted by acedeuce802
This is the answer. It will tell you everything you need to buy and how to assemble it all.
shuiend is offline
Old 02-03-2017, 06:03 AM
hector's Avatar
Total Cats: 163
My vote is for MS3 Pro Module and Franks adapter board. Cleanest install. Even cleaner than a MSProPNP.
https://www.miataturbo.net/megasquir...-boards-86884/
Y yo no hablo aleman, mein herr.
hector is offline
Old 02-03-2017, 09:09 PM
Bara83's Avatar
Well I pulled the trigger on main engine parts today. Wiseco pistons and rings, king bearings, arp head studs, cometic head gasket. Other parts are getting ordered once the machine shop matched the bores and got the engine built. Now to shop for megaSQ. Let's start reading all these helpful links.
EXCITED!
Bara83 is offline
Old 02-03-2017, 09:38 PM
Bara83's Avatar
I like that, but cant quite understand. So I just buy this:
https://www.diyautotune.com/product/...th-black-case/
And it fits into franks board?
Bara83 is offline
Old 02-03-2017, 09:44 PM
afm
afm's Avatar
Total Cats: 508
No, this:
https://www.diyautotune.com/product/ms3-pro-module/
afm is offline
Old 02-03-2017, 09:46 PM
Bara83's Avatar
850 Looks a little steep for some turbo action. Gosh, I guess, Ill go the harder and cheaper route and probably have some systems failing...
Bara83 is offline
Old 02-04-2017, 10:07 AM
bahurd's Avatar
Total Cats: 314
You had the best advise in the 2 posts linked. If you're looking at MS2 then you won't get much help on this site because everyone either has or plans to move on to the MS3 based. Franks stuff is nice and has some good features but is overkill I'd guess for you.
So, here's the list of stuff you need, from the other 2 links and now all you need to do is price + buy + build = enjoy life.
bahurd is offline
Old 02-04-2017, 05:35 PM
Bara83's Avatar
yeah, ordered everything last night.
Bara83 is offline
Old 02-09-2017, 08:28 PM
Bara83's Avatar
Well the least needed part showed up as first.
Bara83 is offline
Old 02-15-2017, 07:01 AM
Bara83's Avatar
Got my pistons, rods, rings, bearings, studs, HG, wideband, fuel pump, injectors and the MS kit.
Bara83 is offline
Old 02-15-2017, 07:35 PM
Bara83's Avatar
So I built the Jimstim and built the daughter board. Was wondering if the jimstim should be lighting up without being connected to the MS board as I turn it on. Didnt dare plugging it in yet...
Tried, the LEDs aren't working either from the test. Somebody?
Bara83 is offline
Old 02-18-2017, 06:34 PM
Bara83's Avatar
Ive read a bunch, and dont know who's wiring harness build should I follow? Help?
Also still waiting on the jimstim troubleshoot help....
Bara83 is offline
Old 02-18-2017, 06:37 PM
bahurd's Avatar
Total Cats: 314
bahurd is offline
Old 02-18-2017, 10:07 PM
Bara83's Avatar
On the expansion board connector side there is two times X 24. Means I should solder two wires on the same connector?3ULow Battery Warning LightX - 24White/Red 2NVariable Tumble Control System (VTCS)X - 24Lt Green/Blue
Found I need x24 three times?? I cant get 3 wires on one pin...
VVT
X - 24
NTRS1
Bara83 is offline
