00 DIYPNP crank but no start help!
Old 05-16-2017, 09:26 PM
Christian Tibbetts's Avatar
Angry 00 DIYPNP crank but no start help!
Hello all, first time poster! ill just get right into it. I am in the process of going to forced induction and purchased a new diypnp 1.5. Upon completing the soldering, i cant get it to start. I uploaded the latest firmware and dowloaded a base map. All im getting is crank but no start, i am getting fuel(i can smell it) but no spark. Im starting to believe i may have missed a step or forgotten a step. Ive searched and searched unto no avail. Ill include pics of what ive done if someone could point me in the right direction. PS in completely stock engine wise as of now. I did the edge pin connections according to diyautotune.com. Thank you all!
Attached Thumbnails 00 DIYPNP crank but no start help!-image1.jpg   00 DIYPNP crank but no start help!-image2.jpg
Christian Tibbetts is offline
Old 05-17-2017, 06:34 AM
hector's Avatar
Total Cats: 163
Post log of start attempt, composite log of triggers, and tune.
hector is offline
Old 05-17-2017, 07:41 AM
Total Cats: 4,080
you didnt install the necessary pull-ups.
Braineack is offline
Old 05-17-2017, 09:04 AM
Wow, youre right! i didnt even see those. Would that cause me to not get rpms on tunerstudio and not get spark? Do you happen to know what those pull-ups are? Its an 00.
Old 05-17-2017, 09:43 AM
mmmjesse's Avatar
Total Cats: 44
it tells you the pullups in the tutorial. trubokitty.com
mmmjesse is offline
Old 05-17-2017, 12:00 PM
Total Cats: 4,080
yes.
yes.
it's in the docs you followed...
Old 05-17-2017, 12:01 PM
Total Cats: 4,080
I don't condone using DIYPNPs on NBs, therefore I don't offer the instructions to do it :P
Old 05-17-2017, 01:22 PM
Why is that? Other than the alternator reason.
Old 05-17-2017, 01:23 PM
Total Cats: 1,681
It has an extremely limited number of inputs and outputs, that can't really control everything that the NB can do, or should do.
shuiend is offline
Old 05-17-2017, 01:50 PM
I'm only planning on running a simple turbo set up. I should be good right? I've seen plenty of stuff that says it works.
Old 05-17-2017, 02:02 PM
Total Cats: 1,681
I mean it "works", you just won't have much more then normal spark and fuel control. One of the big things is you won't be able to set up AC to work "nicely".
shuiend is offline
Old 05-17-2017, 02:10 PM
Oh if ac is the biggest drawback then I'm good. I don't care too much about ac. As long as I can make it run I'm good
Old 05-17-2017, 02:30 PM
Total Cats: 1,681
It's not only the AC. There is a lot of picking and choosing of what you want and or don't want.
shuiend is offline
Old 05-17-2017, 02:41 PM
Can you elaborate a bit on what exactly you mean?
Old 05-17-2017, 02:42 PM
Total Cats: 4,080
my biggest reason: Controlling the alternator
Old 05-17-2017, 03:02 PM
The alternator is already taken care of. I swapped to a 97 alt and wired it to bypass the ecu. Very easy if you ask me so that's not a problem anymore. It's much easier than building the alternator control deal on the proto area.
