Efihardware.com e85 compatible fueltank bulkhead connectors - $26(pair) plus shipping
Old 02-03-2018, 05:57 PM
Chiburbian's Avatar
Total Cats: 202
Default Efihardware.com e85 compatible fueltank bulkhead connectors - $26(pair) plus shipping
See here:
https://www.efihardware.com/products...head-terminals
I was a bonehead and only bought one connector. I had to pay almost $20 for shipping to the U.S. so before I order more, I am just looking to see if anyone else wants some of these. I can ship them flat rate envelope (to you) when they arrive.
They sell for $15 australian dollars each, so figure about $26 US dollars plus shipping from Illinois?
Q&A:
Why do you want these? A: to upgrade your fuel pump to use heavy grade (8-10ga wiring) and bypass your stock connector.
Is that really necessary? A: Probably not. But I am copying Savington's build for the most part, and it's the most elegant solution I have found thus far.
Can I source these parts locally for much less money? YES (Probably). The problem is I haven't found a supplier that can verify that the internal components to this bulkhead connector are e85 compatible. If you can find a source for all the parts locally I would be happy to cancel my order and buy through you. Heck, I'll even pay the same price and not pay to ship them from Australia.
When will I be placing my order? A: How about Sunday the 11th of February? I will commit to waiting that long. If a significant number of people are interested I will make two orders but if nobody expresses interest I won't wait any longer than next Sunday.
When will I expect to receive my parts? A: I had my last shipment sent via international post which took seven days from the time of my order to arrive at my post office. Add a day for me to get my **** together and figure a couple days on top of that for the part to arrive wherever you are. Figure just under two weeks from when I place my order? I think I can hit that number.
File Type: pdf
Chiburbian is offline
Old 02-03-2018, 07:05 PM
bahurd's Avatar
Total Cats: 314
I’ll go in for a pair. PM me when you know the final price you need.
bahurd is offline
Old 02-04-2018, 05:00 AM
mrmonk7663's Avatar
So you need a pair of these for one fuel pump? Also it might be ben facial to post a direct link to Savington’s post.
Thanks!
mrmonk7663 is offline
Old 02-04-2018, 10:48 AM
bahurd's Avatar
Total Cats: 314
Thanks!
@EO2K original post in the thread; Submersible bulkhead terminals
bahurd is offline
Old 02-04-2018, 10:50 AM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Dam, looks like I need to machine a few dozen chunks of delrin with little o ring grooves.
hi_im_sean is offline
Old 02-04-2018, 11:11 AM
bahurd's Avatar
Total Cats: 314
Easy enough for sure. I can see some easy improvements at the same time.
bahurd is offline
Old 02-04-2018, 11:45 PM
Chiburbian's Avatar
Total Cats: 202
As I mentioned in my original post, if you have a source for the same materials I am more than happy to buy stateside. I just don't have the time nor the expertise to source or fabricate it myself.
Old 02-05-2018, 12:44 AM
Chiburbian's Avatar
Total Cats: 202
Ok, so it's more expensive (but not per fastener). How does this look as an alternative?
Electrical Bulkhead Stud Kit, 6 Pack
If I use that connector instead I can offer two people a pair for $20 plus shipping?
EDIT: Already ordered. Bahurd, if you want a pair of the radium bulkhead studs let me know.
Old 02-05-2018, 04:24 AM
afm
afm's Avatar
Total Cats: 508
One of the requirements for the Radium studs: Material Thickness: 0.262"-0.322". Hard to use out of the box for a Miata tank.
afm is offline
Old 02-05-2018, 06:12 AM
Gee Emm's Avatar
Total Cats: 184
Default the other thread had another idea
They sell others, for thinner material.
But I just bought one of these Racetronix tank harness, I am sure someone is going to tell me that I shouldn't have ...
Gee Emm is online now
Old 02-05-2018, 09:30 AM
matrussell122's Avatar
Total Cats: 516
Im in for a set.
matrussell122 is offline
Old 02-05-2018, 09:48 AM
SadFab CEO
hi_im_sean's Avatar
Total Cats: 1,142
Ill play around with some stuff and see what i can come up with. Dont wait up though...
Old 02-05-2018, 07:28 PM
Chiburbian's Avatar
Total Cats: 202
Yeah, I saw that. I wasn't sure what the thickness was on the Miata fuel pump hangar(?). I figure I can find a way around the thickness thing. If not I can just donate them to a friend who has a fabrication shop and he might be able to use them at some point.
Old 02-05-2018, 08:36 PM
miata2fast's Avatar
Total Cats: 174
If only you made this thread a month earlier. I already received mine at like 40 bucks.
As as far as thickness, I plan to weld washers on the topside of the hanger assembly to put it in the desired range.
miata2fast is offline
Old 02-05-2018, 09:10 PM
mrmonk7663's Avatar
This might be an option too. Bulkhead fitting it can be bored out slightly to accept 10gauge wire or tefzel wire if desired.
FAB
Fab9 Tuning - Miata Performance Parts
02-17-2015 11:05 PM
Iroquois Pliskin
12-28-2014 11:21 PM
rlogan
09-17-2013 09:14 PM
drftem2
10-29-2008 12:05 AM
BoostCreep
08-18-2008 11:29 PM
Quick Reply: Efihardware.com e85 compatible fueltank bulkhead connectors - $26(pair) plus shipping
