1.6 16g turbo kit for sale, emb/Autotune/harness included
Old 01-08-2008, 10:32 AM
VRTSid's Avatar
Default 1.6 16g turbo kit for sale, emb/Autotune/harness included
My turbo kit doesnt have a home, wont you give it one?
16g turbo, with oil feed line. (turbo is used not brand new)
2.5" downpipe
2.5" cat (with the downpipe it bolts up to stock location cat back exhaust!)
Intercooler, I dont have exact measurements but I'll get them
all piping (needs connectors)
330cc injectors
450cc dsm injectors
mitsu evo fuel pump (190lph without the walbro noise)
greddy emanage blue
emanage tuning cable
boomslang pnp wire harness (no splicing required)
old guys autotune (needs pressure switch, I accidentally left it in my car... then sold the car...)
laptop with emanage software loaded
oil return bung
will throw in Maximum boost book, and fuel injection system books if you want.
1300$ +s/h obo
great deals yo.
VRTSid is offline
Old 01-08-2008, 10:41 AM
xveganxcowboyx's Avatar
It might be good to specify which 16g turbo it is. If you don't know at least post numbers or pics.
The evo fuel pump is solid. It is indeed much quieter than the Walbro with similar flow, but if it is an evo VIII the fuel pressure cuts out early, the IX does not cut pressure high up.
xveganxcowboyx is offline
Old 01-08-2008, 04:39 PM
VRTSid's Avatar
I posted this from work, I have to go home and get the info later tonight.
I didnt know that about the evo 8 and 9 pumps. When I bought it the guy said "evo 9" but now that you've said that I'd like to make sure... Do you have more information about that?
VRTSid is offline
Old 01-08-2008, 10:24 PM
No sorry, I don't remember the details about it. They both flow similar numbers (about the same as the walbro 190 as you said), but I remember reading that the Evo VIII pump cut flow or limited pressure at some point. Maybe in the 70-80 psi range (don't remember where but that's probably the ballpark. The evo IX pump does not limit pressure like this and can pump much higher. It's not an issue for most vehicles (I use the Evo VIII pump in my 23psi Talon with no issues) but it for guys wanting to use a FMU or something else that bumps pressure very high they would want to be sure it's the Evo IX pump.
*edit* http://www.dsmtuners.com/forums/bolt...stock-fpr.html
Check post 11. AMS says the VIII pump has a relief valve that opens between 65 and 68 psi.
Old 01-10-2008, 01:00 PM
mike019's Avatar
might be getting into a miata soon so please keep updating this thread for the status of the sale... thanks... btw would i need anything else for this set up to work?
mike019 is offline
Old 01-10-2008, 05:50 PM
VRTSid's Avatar
intercooler pipe couplings, tuning, I would have the injectors rebuilt for piece of mind, nice water and oil return hoses for the turbo (I used rubber and tossed them) but thats it.
kit is still for sale, includes oil pan drill bit, and tap if you need them.
VRTSid is offline
Old 01-13-2008, 02:59 PM
mike019's Avatar
did you ever figure out which evo fuel pump it was... also with a proper tune, what hp numbers can you estimate that i would be seeing?
mike019 is offline
Old 01-14-2008, 06:17 PM
99NBMia's Avatar
willing to part with the boomslang, emanage blue, and tuning cable? I can pick up, just lmk how much if you are willing.
99NBMia is offline
Old 01-18-2008, 06:01 PM
VRTSid's Avatar
I bought it as a evo9, I havent had internet in a week and half. Im going to try and find out this weekend. I was shooting for solid 200whp when I was building it with room to grow. Im no expert but look at other setups that are similar, I would put it at around 230-250whp, maybe more? I honestly wasnt thinking in that direction when I was putting it together.
VRTSid is offline
Old 01-26-2008, 04:08 PM
gompers's Avatar
Still for sale?
gompers is offline
Old 01-26-2008, 07:34 PM
msydnor's Avatar
Will you sell the 330 injectors seperate?
msydnor is offline
Old 02-06-2008, 03:14 AM
mike019's Avatar
sorry i couldnt reply i needed 10 post all of a sudden to post in this thread... anyway is the kit for sale? if so where are you located? and the missing pressure switch mentioned, what kind is it and where can i purchase one?
pm me please with the info bc it said that i cant pm unless i have 15 post or something like that
thanks
mike
mike019 is offline
Old 02-20-2008, 08:54 PM
slomx5's Avatar
how much hp does it make
slomx5 is offline
Old 02-22-2008, 01:29 PM
leshok's Avatar
Is this kit still for sale? Im interested in just the kit. Seems like you have buyer for everything if sold seperate.
Let me know.
leshok is offline
Old 03-18-2008, 12:32 PM
VRTSid's Avatar
2.5" downpipe
330cc injectors
450cc dsm injectors
greddy emanage blue
oil return bung
1300$ +s/h obo
great deals yo.
I'm going to make a new for sale post, I haven't been on in a long time for outside reasons...
VRTSid is offline
btabor
10-05-2015 02:04 PM
Dustin
09-23-2015 10:34 PM
Andifer
09-23-2015 05:43 PM
DonPlatt
09-19-2015 10:23 AM
Quick Reply: 1.6 16g turbo kit for sale, emb/Autotune/harness included
