TDR i/c allows way more air to the radiator
I changed my i/c from the AVO to the TDR. I measured airflow by taping a sheet of paper above the mouth hanging down, weighted down with 8 quarters. Then turned the fans on. I took a video before and after. Result: waaaay more airflow with the TDR. I expected a difference but not this much. The reason is that the TDR has much more opening area than the AVO i/c. Which is the whole reason I changed over. I anticipate much better cooling. Will measure temps later. See pics below.
Left is AVO, right is TDR.
Top is paper test, bottom is i/c frontal pic.
Its basically a comparison between bar/plate and tube/fin. Bar/plate cools better, but is more disruptive to flow through it (to radiator and somewhat to motor), while tube/fin flows better (both ways) and doesn't cool quite as well. Typically tube/fin is also quite a bit lighter than bar/plate.
It's all a matter of picking your poison
User datapoints and claims on the TDR i/c is that it has about the same outlet temperature and slightly better pressure loss performance as the AVO. We'll see.
The car feels noticeably faster at the topend, but it may be because of the cool weather today. I will wait for warmer weather to make a datalog.
Results:
- spoolup, no change
- topend, slight discernible advantage to AVO (~2%, could be meas error, AEMlog acceleration function)
- temp rise during a 2nd gear run: 4°C vs. 6°C, advantage AVO i/c, BUT the temps drop back down more quickly with the TDR. The AVO appears to have more thermal mass but heatsoak, the TDR airflow cools it down quick. Peak temps on the track, unknown.
I have yet to measure pressure loss.
