Godspeed Radiator Install
Old 11-07-2007, 10:39 PM
levnubhin's Avatar
Default Godspeed Radiator Install
Allright guys it's in! It looks great amd most of all it works! Not keep in mind that this is a sub $200 radiator so it deffinately falls into the "you get what you pay for" category. The reason I say that is because it is not a direst bolt in. It wasnt difficult to put it in just a little time consuming. So 1st step is to obviously remove the stock radiator and remoce the fans from the radiator. To install the fans onto the new radiator I had to elongate the top mounting holes.
After I mounted the fans I noticed that there were rather large gaps between the radiator and fans. To fix that i went to Home Depot and picked up some self adhesive pipe wrap insullation tape.
I cut the wrap into about 1" strips and lined the edges of the radiator.
On the outside edges I put 3 strips and down the center between the 2 fans I put 1 strip. Then I mounted the fans.
Next was to attach the mounting brackets. Before you do this check to see how your brackets line up with tho hols in the radiator. With my radiator I had elongate the holes on one side.
For some reason on the other side the holes lined up perfectly. I also noticed that because this radiator has those lips on the sides I needed to cut 2 pieces out on each side for the bracket to fit flat against the radiator.
When I went to slide the radiator into the car I noticed that because of how thick it is that it wouldnt just slide down because of the shape of the frame wings near where the radiator sits. What I did was remove the pass side radiator mount from the radiator and then put it in place in the car and then I slid the radiator in. It still took a little muscle but it went in.
After you get it in just install the top bolts, reattach the hoses and fill it up. One problem I had was where the bottom hoses conectos to the radiator was slightly closer to the center of the radiator i had to use some flex hose in order to get aroung my charge pipe.
Here are some more pics.
Size:  44.6 KBName:  IMG_5130.jpg
Size:  45.6 KBName:  IMG_5127.jpg
Size:  51.7 KBName:  IMG_5121.jpg
Size:  39.1 KBName:  IMG_5124.jpg
If anyone has any questions please feel free to ask.
levnubhin is offline
Old 11-07-2007, 10:44 PM
Looks like you have some great swaybar clearance which is something a bunch of us were worried about. Could you measure the actual core thickness for me?
Old 11-07-2007, 10:53 PM
levnubhin's Avatar
2.25"
Old 11-07-2007, 11:12 PM
OK, install looks easy enough. For less than half cost of a PWR I can deal with enlarging a couple bolt holes.
So is there enough sway bar clearance for an oversized bar?
Old 11-07-2007, 11:22 PM
levnubhin's Avatar
I have the 1" FM bar in there and there is still a small gap between the bar and the fans.
Old 11-07-2007, 11:30 PM
Great, Thanks. I have the same bar. Except mine's gray
Old 11-08-2007, 08:22 AM
TurboTim's Avatar
Total Cats: 399
What type of drain fitting is that? just a bolt?
TurboTim is offline
Old 11-08-2007, 08:29 AM
levnubhin's Avatar
I looks like just a bolt. I didnt bother to mess with it.
Old 11-08-2007, 08:51 AM
Atlanta93LE's Avatar
That thing is huge. Looks like the chances of it fitting with my over-the-rad IC setup are about zero.
Atlanta93LE is offline
Damn it's a big ol bizotch.
Old 11-08-2007, 09:42 AM
Zabac's Avatar
sweet...slim fans anyone?
Zabac is offline
Old 11-08-2007, 09:53 AM
Loki047's Avatar
Total Cats: -5
group buy
Loki047 is offline
Old 11-08-2007, 10:01 AM
levnubhin's Avatar
I need a temp sensor adapter to put in the upper rad hose. Anyone know where to get one cheap?
Old 11-08-2007, 10:07 AM
neogenesis2004's Avatar
Originally Posted by Loki047
group buy
You can get slim fans all day long on ebay for sub $30 each. Thats what I'm running on my 3" coolradiator.com radiator.
neogenesis2004 is offline
Old 11-08-2007, 10:08 AM
http://trailtech.net/vapor_vector_te...e_sensors.html
Old 11-08-2007, 10:17 AM
Here are the same fans I have in my setup. They work perfectly.
http://cgi.ebay.com/ebaymotors/10-Un...spagenameZWDVW
Old 11-08-2007, 10:33 AM
plus they look good:
Old 11-08-2007, 10:37 AM
Zabac's Avatar
i think im gonna go with these...
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
group buy? ill see what i can do!
Zabac is offline
Old 11-08-2007, 10:44 AM
at 1600CFM only need one.
Old 11-08-2007, 10:51 AM
LOL, thats the same damn link I just posted.....I have 2 on mine as you can see in the pic scott posted. They are wired together and when they turn on they are never on for more than 15sec before temp is down again.
Quick Reply: Godspeed Radiator Install
