Injector Harness Adapters.
Old 03-24-2008, 12:35 PM
reddroptop's Avatar
Default Injector Harness Adapters.
I have a set of BNIB 550cc RX7 Injectors.
They are not PNP, they are high impedance but they have the square (EV1, correct me if I am wrong) connectors.
We have the oval type connectors on our injectors (denso, again correct if wrong)
I could spend 17.25 x 4 + shipping to buy adapters from FM, but IMO that is WAY too much money to spend for a simple adapter.
I am not going to hack up my harness, or risk a 70k mile motor by shoving in wires/pins into terminals, I want the adapters with the proper connectors.
I have been looking around for a good deal, and have found the following:
http://www.fiveomotorsport.com/Injector_CONNECT.asp
It is the connectors on the far right. 39$ + shipping.
Are these the ones I need? Any place cheaper I can order/assemble them from? I have no issue ordering the proper pins and connectors and assembling them myself.
reddroptop is offline
Old 03-24-2008, 12:44 PM
MX5-4me's Avatar
I think it's the NipponDenso Male to EV1 Female that you want.. Have you tried calling them to find out of they know?
MX5-4me is offline
Old 03-24-2008, 12:53 PM
reddroptop's Avatar
I thought I made it clear that it was Denso male -> EV1 Female, guess not.
I will call FM when I have some time and confirm. I just feel like a dick calling about a product only to gather information so I can buy it cheaper somewhere else.
Old 03-24-2008, 12:59 PM
MX5-4me's Avatar
I wouldn't call FM about this. Call the place you are thinking about Purchasing them from.
MX5-4me is offline
Old 03-24-2008, 07:27 PM
Call injector rehab our forum sponsor. They sell all kinds of adapters, cheaper than anywhere else i've looked.
Old 03-24-2008, 10:49 PM
miataz's Avatar
You try automotive warehouse
miataz is offline
Old 03-24-2008, 11:21 PM
cardriverx's Avatar
those square connectors are on alot of old hondas and such (how I got mine), go to the junkyard and you could get them reall cheapp.
cardriverx is offline
Old 03-24-2008, 11:28 PM
reddroptop's Avatar
DSM's too, I just don't want to hack up my stock harness to splice them in, and you are not going to find male injector connectors at a junkyard.
Old 03-24-2008, 11:35 PM
cardriverx's Avatar
oh right, I skimmed your post too much. For the money, really.. spliceing into the harness is no big deal, hell you dont have to even solder like I did, just use crimp connectors.
Old 03-25-2008, 12:03 AM
reddroptop's Avatar
Soldering isn't an issue, I just like the fact at any point I can return completely to stock with minimal effort. If I ever chose to sell the car, I wouldn't have to explain anything.
I keep all the stuff when I replace it. The only thing I have done that can't be returned to stock is rolling the fenders, big deal.
I have spare bumpers and body pieces so I can hack up whatever I choose basically.
Old 03-25-2008, 06:56 AM
KGP
KGP's Avatar
we have just about any connection and adapter you have to use any injector with any harness. http://injector-rehab.com/outpatient/electrical.htm
you can buy connectors individually, or jumper harness
KGP is offline
Old 04-17-2008, 01:17 PM
reddroptop's Avatar
So, bringing this back.
My injectors are 195500-1370 , there are 2 types of these injectors, low z and high z.
Mine are the high z, which means the center keyway is offset. Should I just order the regular bosch style ev1 centered keyway connectors?
Old 04-18-2008, 06:43 AM
KGP
KGP's Avatar
you can sand down / cut off the off-set key and an ev1 clip will work. I have never been able to source the high z clips new, nor really had a reason to have them made as they were not on many injectors... have some used around... but not new.
KGP is offline
90 Turbo
19
10-19-2015 03:23 PM
Trent
10-01-2015 12:15 PM
The Gleas
10-01-2015 09:30 AM
Quick Reply: Injector Harness Adapters.
