View Poll Results: How much Wheel Power on a Stock Engine? Are you over?
250Hp on a stock B6 (1600cc Engine)
12.88%
300Hp on a stock B6 (1600cc Engine)
0%
250hp on a stock 94-97 BP Engine (1800cc Engine)
12.88%
300hp on a stock 94-97 BP Engine (1800cc Engine)
1.52%
250hp on a stock 99-00/Mazdaspeed BP Engine (1800cc Engine)
6.06%
300hp on a stock 99-00/Mazdaspeed BP Engine (1800cc Engine)
3.79%
250hp on a stock 01-05 BP/vvt Engine (1800cc Engine)
5.30%
300hp on a stock 01-05 BP/vvt Engine (1800cc Engine)
1.52%
Make over 350Hp on my Stock Engine!
0.76%
I make less than 250hp on my stock engine. WIMP!
55.30%
Voters: 132. You may not vote on this poll
How much are you making on a 100% STOCK MOTOR?
Old 05-06-2008, 11:01 AM
Guest
M-Tuned's Avatar
Default How much are you making on a 100% STOCK MOTOR?
What is your setup..
Engine Year
Turbo
Management etc.
Max RPM
Post a dyno chart if you have it... How long have you been running with this setup?
M-Tuned is offline
Old 05-06-2008, 11:09 AM
Guest
M-Tuned's Avatar
I made 360hp on a stock 95 BP and ran it for 8 months like that.
Was using a custom Turbo setup with a T3/T4 50 Trim. 18-19psi.
3" Exhaust
FJO 341B ECU (Also did the same on a TECII)
Max RPM was 7650. More and I would blow Oil pumps.
Trying to decide how much I want to push my 2000 Engine with the Megasquirt. I don't like swapping motors when I have a car with A/C, PS, ABS etc..
M-Tuned is offline
Old 05-06-2008, 11:11 AM
Prospero's Avatar
Before:
All stock, and I mean nothing has ever been touched... got 99 WHP with my Automatic 1999 Miata.
After:
BEGi-S, custom IC, BEGi FMU, 315cc injectors, O2 Clamp, AEM UEGO, and some other goodies. HP... dunno yet. Still pinging at 8 PSI with WG adjusted all the way out. Solution is on the way this month in the form of new ECU thinggie. Hoping to be over 200 WHP...
Cheers,
Prospero
Prospero is offline
Old 05-06-2008, 11:13 AM
Can only estimate, but somewhere ~275 on a stock b6.
Old 05-06-2008, 11:16 AM
1.6L - Frankenstein motor
DiY Headwork (unshrouded valves, port matching, blending, etc.)
Garrett T3 (Super 60) .48 A/R
BEGi Manifold and 2.5"-2.75" BEGi Downpipe
18"x12"x3" Intercooler
2.75" - 3" Test Pipe
3" Enthuza Budget Racer with Magnaflow Muffler
MSnSE 029v
Old 05-06-2008, 11:23 AM
Atlanta93LE's Avatar
small 16g, 8.5psi
MSPNP
~190rwhp
Atlanta93LE is offline
Old 05-06-2008, 11:59 AM
2001 motor
hydra ecu
9.5 psi on a GT2876R
257 rwhp
daily driver or i'd have clicked a higher power button.
Old 05-06-2008, 01:14 PM
ThePass's Avatar
Total Cats: 1,216
wow y8s... 257 whp with less than 10psi? amazing.
Me:
15g turbo
greddy manifold and dp
custom FMIC (large - 12x25x3)
Vortech fmu
Greddy knock-off bypass valve
10* timing, no pulling under boost
6.5 psi
Setup is very cobbled together right now - the greddy dp and vortech need to go. As-is I'm just hoping to be in the 150 whp range.
In a month or two with a MSPNP, 460cc inejctors and Begi DP and 9 psi I'm probably looking for more like 190 whp.
Ryan Passey
ThePass is offline
Old 05-06-2008, 01:26 PM
paul's Avatar
me:
gt2560r
custom turbo manifold
BEGi turbo intake manifold
70mm throttle body
custom 3" turbo-back
STOCK 99 motor
MSI
18x12x3 ebay-cooler
rx7 550s
14-15 psi
paul is offline
Old 05-06-2008, 01:53 PM
macanha's Avatar
I don't know how much power y got. no dyno yet. (I Prefer use this money in more parts or gas )
- 1997 miata (1800cc).
- Custom made intake, Header and 3" exhaust.
- TD04, 460cc injectors and MS@10 Psi.
macanha is offline
Old 05-06-2008, 02:14 PM
urgaynknowit's Avatar
92 na
greddy kit,
turbo back,
intercooler
injectors ,
fmu,
hallman mbc
10 psi
no clue on power,
but i pull on evo's sti's and cars of that nature that are pretty dam fast
urgaynknowit is offline
Old 05-07-2008, 11:08 PM
Guest
M-Tuned's Avatar
Looks like the majority is really not making much power at all! Yikes!
M-Tuned is offline
Old 05-07-2008, 11:11 PM
elesjuan's Avatar
Total Cats: 43
God.. I feel so insignificant..
I guestimate maybe if I could ever get my **** tuned... maybe 110rwhp. Soon to change!
elesjuan is offline
Old 05-09-2008, 02:36 PM
TurboTim's Avatar
Total Cats: 399
270rwhp at 12psi
stock '94 block
AEM EMS
two GT1548's
dyno plot is somewhere in the most recent MT dynoday thread.
TurboTim is offline
Old 05-09-2008, 02:43 PM
Yikes? Not everybody is making more than 2.5 times stock power on a stock block...that's wimpy? I'd say smart.
Old 05-09-2008, 02:58 PM
Guest
M-Tuned's Avatar
Cool
Sorry.... I disagree Our engines are built for a ton of power. Every Miata needs 250hp. I miss my old 350+ setup like mad.
WIMP!!
M-Tuned is offline
Old 05-09-2008, 03:00 PM
Zabac's Avatar
You need a sub 150whp button, I'd hit it...
Zabac is offline
Old 05-09-2008, 03:06 PM
miatamania's Avatar
WIMP!!
Tool.
miatamania is offline
Old 05-09-2008, 03:28 PM
Guest
M-Tuned's Avatar
Originally Posted by miatamania
Tool.
You don't even have a turbo You should not be allowed to post here ....
Have a good weekend... Just kidding..
M-Tuned is offline
Old 05-14-2008, 09:28 PM
oreo's Avatar
Total Cats: 95
218 Hp with a stock 96 engine.
limiting this was the stock cat and 2-1/4 exhaust.
expecting to top 250 with my new 2001 engine and 3" exhaust.
oreo is offline
Quick Reply: How much are you making on a 100% STOCK MOTOR?
