Revving on its own.
Old 07-07-2008, 11:49 PM
miataspeed1point6's Avatar
Default Revving on its own.
With a ton of help from the_pipefather my MS is up and running. There is one problem we couldn't figure out. Sometimes I will start the car and it will rev from 1k-2k up and down up and down. Other times it will go about a 1/2 mile and start doing it. When it does that it drives normal and everything, it just revs up and down. So far there is no pattern it is just random. When it does it I can just turn off the car and restart and it is fine.
I did some research and found it could be a vacuum leak or a faulty TPS. I have double checked that it is not a vacuum leak, and if it was I think it would always happen. I'm still on the 5 speed on/off TPS. I will be putting in a VTPS as soon as I can get one.
This happens maybe 1 out of 5 starts, so it is pretty annoying. My IAT sensor is right before the throttle body, is that poor placement? Any ideas?
miataspeed1point6 is offline
Old 07-08-2008, 12:03 AM
wes65's Avatar
Run HR code.
wes65 is offline
Old 07-08-2008, 12:05 AM
The_Pipefather's Avatar
Total Cats: 14
It IS running HR10g code. it can't be either of those because i'm running a different TPS and a different IAT, yet the same thing happens to my car.
The_Pipefather is offline
Old 07-08-2008, 12:12 AM
wes65's Avatar
Hmm.. interesting. Well tell me if you figure it out because actually mine does it to but it didnt on hr code. Now that i am back to low res, it does it.
wes65 is offline
Old 07-08-2008, 01:15 AM
Total Cats: 6,593
Mine did that when I had the Recovery Speeds in Idle Control Continued set too quick.
Joe Perez is offline
Old 07-08-2008, 06:45 AM
zoomzoom's Avatar
Mine does it too when cold and sometimes when warm too, with it set to steady no less. Though mine has some other issues, including a nb manifold/idle valve and fairly lumpy cams...
zoomzoom is offline
Old 07-08-2008, 07:42 AM
ArtieParty's Avatar
I had this problem too. It turned out to be the IAT sensor heat-soaking. Paul adjusted some settings for me and its been running perfect since.
ArtieParty is offline
Old 07-08-2008, 08:04 AM
zoomzoom's Avatar
Pretty sure thats not the case with mine, it is still N/A and IAT sensor is only in a bit of pvc pipe
zoomzoom is offline
Old 07-08-2008, 08:08 AM
ArtieParty's Avatar
What are the intake temps when it does this? Do you have a WBO2? Have you noticed that when it does it, its going really lean?
My car is NA right now too... until Tim finishes the AbsurdFlow manifold.
Old 07-08-2008, 08:46 AM
gotta be an idle valve thing.
Old 07-08-2008, 10:19 AM
Lincoln Terns's Avatar
OR TPS...my Link was doing the same thing and it turned out to be the TPS...tried cleaning, waiting to see how it works now...might need new one.
Lincoln Terns is offline
Old 07-08-2008, 11:28 AM
Total Cats: 14
is it possible for you to log this when it happens so we can change the recovery settings to match the rpm oscillations?
These are the settings we are using right now:
Deadband : 50 rpm
Upper limit: 280 rpm
Lower limit: 100 rpm
Fast recovery: 15
Slow Recovery: 100
Closure Speed: 2
Startup Delay: 2
Old 07-08-2008, 03:09 PM
Not sure of intake temps, but AFR is normal for whatever rpm the engine is at(I have an LC1).
I can try getting my laptop to link up. It happened last night on my way home. The injector settings are working, it started right back up.
Old 07-08-2008, 03:29 PM
cardriverx's Avatar
I should try to adjust the recovery speed, I think thats what causeing mine.
cardriverx is offline
Old 07-08-2008, 03:37 PM
Mine does the same idle-bouncing with MS as it did with the stock ECU. If messing with the idle recovery doesn't help, I can bet you it's the IAC going bad as it eventually does on almost every Miata.
Head over to m.net and search "idle droop" in the NA/NB forums. There's an easy way to clean the passages and test the voltages to see how healthy the unit is. A new one is like $350 or you can get one off a parts car for cheap... or you can just deal with it. Mine's done it for 30k miles and I don't even notice it anymore.
Additionally, how would one go about adjusting the IDLE RECOVERY settings. What does each one of those settings do?
Old 07-08-2008, 03:45 PM
maybe one of your screws on your butterfly valve is missing.... oh god i fail.
bruss
1
08-31-2015 10:45 AM
Saml01
Insert BS here
23
02-24-2009 11:28 PM
momo182
12-06-2008 08:51 PM
davechaletzky
Prefabbed Turbo Kits
15
10-11-2007 11:57 PM
Quick Reply: Revving on its own.
