Dyno later today - Suggestions!!!???
Old 07-21-2008, 03:30 PM
cueball1's Avatar
Default Dyno later today - Suggestions!!!???
Heading to a dyno today. Plan on a couple of hours. It's a 1750 mustang load unit. Shop is a Ford shop, but has worked on a number of turbo Miata's in the area. Tuner is running Megasquirt in his turbo'd Mustang.
Suggestions to get prepared for this? My 1st trip to a dyno. I don't know what to expect! Anything I can do to help be prepared to cut down on dyno time is a good thing!
cueball1 is offline
Old 07-21-2008, 03:41 PM
reddroptop's Avatar
2 bottles, big ones.
reddroptop is offline
Old 07-21-2008, 03:44 PM
wes65's Avatar
Put new plugs in before you go.
wes65 is offline
Old 07-21-2008, 03:52 PM
cueball1's Avatar
Just installed new cooler plugs NGK 7's gapped to .25, fresh oil change, fresh oil in diff and tranny.
2 bottles? No NOS for me! Here in the NW we are the world's Microbrew capitol though. Maybe a couple of growlers? except I have to drive home too!
I din't know if I should copy some different spark maps from here to try, if they just work with what I have. I don't know what to expect. This seemed like the only shop in my area that had any real Miata or Megasquirt experience. Don't know how good they really are.
I just received but haven't installed my Knocksense. Should I bust my butt to get that in?
cueball1 is offline
Old 07-21-2008, 03:55 PM
jwx
jwx's Avatar
Bring plugs with you, make sure that the car is 100%, change the oil before you go, and not long after you get done.
jwx is offline
Old 07-21-2008, 03:57 PM
KPLAFIN's Avatar
2 bottles? No NOS for me! Here in the NW we are the worlds Microbrew capitol though. Maybe a couple of growlers!
I would highly reccomend being 100% sober throughout the entire dyno seesion....and even more than that,make sure your tuner is as well.
KPLAFIN is offline
Old 07-21-2008, 04:30 PM
Stein's Avatar
Total Cats: 166
When I read this, I assumed two bottles of booze. Sometimes goes a long way when they tally up the final time. I.E. billed for two hours when it was really three or four, or not charging for tuning time between pulls.
Stein is offline
Old 07-21-2008, 04:35 PM
Saml01's Avatar
I dont know whats the rule for 99's, but 6's are the recommendation for anything 97 down.
Saml01 is offline
Old 07-21-2008, 04:58 PM
cueball1's Avatar
Saml01,
I've always heard 6's or 7's. I was having trouble with popping/hesitating with the 5's and my car is going to see a fair bit of track time this summer. I went with 7's. Still getting some issues with the 7's gapped down. Might be too rich under accel. That's one reason I'm hitting the dyno.
cueball1 is offline
Old 07-21-2008, 05:47 PM
omg hit it already!
bkr7 for 1.6L bkr6 for 1.8L
Old 07-21-2008, 08:41 PM
cueball1's Avatar
Just got back. I'm a happy boy!
I'll make another post in the prefabbed section with the sheet.
Made 240 rwhp and 211 ft/lbs on a Mustang dyno at 10+psi. It's a strong little Miata!!!
Didn't really tweak the tuning I already had much. My hesitation/ popping under boost was my fault! The overboost cut out was set too low!
cueball1 is offline
Old 07-21-2008, 08:51 PM
sweet!!! sounds great!
Old 07-21-2008, 09:11 PM
SeanE's Avatar
Those are great numbers. Any dyno graphs for us to look at?
SeanE is offline
Old 07-21-2008, 10:56 PM
cueball1's Avatar
Dyno chart is posted in the Prefabbed dyno and timeslip section here...
https://www.miataturbo.net/forum/sho...060#post286060
cueball1 is offline
Old 07-21-2008, 11:18 PM
why? Do you change the oil in your car every day?
Old 07-22-2008, 09:59 AM
jwx
jwx's Avatar
Its just recommend. Dyno tuning a car puts some pretty heavy loads on the engine, and as such creates a lot of heat. Not to mention, if you are running really rich and the fuel leaks past the rings it will eat your bearings for breakfast, lunch, and dinner.
Obviously, it is less of a problem without a turbo.
jwx is offline
Old 07-22-2008, 12:07 PM
I drive my turbo car as hard as if it where on a dyno on a day by day basis. And for a longer time under high laod realy. And i still manage bot 1k miles or so on a oil change, with non amsoil synth etc.
Old 07-22-2008, 12:44 PM
jwx
jwx's Avatar
So you hold it at one load cell for a couple mins 10-20 times a day?
Thats just what I've heard recommended, it wasn't meant to be some sort of dyno gospel. I wouldn't even change it before and after. Bring spark plugs, yes, change oil no. Would I run the average 6k on it? No, of course not, but I try for every 3k for all of my oil changes.
You change your oil every 1k miles?
jwx is offline
Old 07-22-2008, 12:50 PM
cueball1's Avatar
I'm running full synth. Changed the oil/ filter yesterday before going out. Don't think I'm going to swap out the full synth before it's due.
If it has spent a couple hours making runs and full boost under various loads and speeds to do a lot of fine tuning it might have been another story. As it was the car made 3 baseline passes and maybe another 1/2 hour of messing around trying to get things better. Bottom line was it was running really well when I brought it in and nothing significant was changed.
cueball1 is offline
Old 07-22-2008, 12:52 PM
cueball1's Avatar
Next adventure this week is the late night drags! The following week is my 1st boosted track day. Yee haw.
cueball1 is offline
Quick Reply: Dyno later today - Suggestions!!!???
