What is the quietest 3" straight through muffler I can get?
My 3" with the megablaster on the back. IS DEAFENING! All the teenagers at my little brother's school love it!
I let him be the man and drive it to school. He was letting the BOV blow off and showing off.
Anyhow. I'm 30, I don't want to wear ear plugs everywhere. I love the response of the 3". But I need to quieten it down.
I wouldn't care if it was silent at this point. But I doubt that will happen.
I prefer it as quiet as possible, but free flowing and straight through.
Which is the quietest straight through 3" muffler.
Does a resonator help much?
I need to swap the muffler this weekend.
Thanks.
Thanks.
lol
You need to do some research on how mufflers reduce sound. Resonators and glasspacks reduce sound through absorption. They will help. General rule is have at least 12" of straight pipe before the exhaust exits the car to make it quiet. Hard to do, but helps.
I have a magnaflow and it's too loud. I'm gonna swap to some muffler that actually has baffles in it. I don't care if it hurts spool a spec. It's too loud the way it is now. (and I have 3 long *** glasspacks before the muffler)
lol
even without a cat, im happy enough with my resonator/muffler combo.
The key is the largest muffler can you can fit. Going from a 5x8x14 to a 4x9x14 made a big difference in the overall dB level of my exhaust. The 4" depth doesn't give the sound waves enough room to bounce around and cancel out. Enough so I had to add the resonator to get it back within acceptable levels. Stuff the biggest physical straight through muffler you can manage to fit and you'll be happy. That and never let the wastegate open
I have a new 3" 400 honey comb cat for my truck in the closet. I thought about throwing it on there. But I changed my mind.
How big of a muffler will fit in the NA?
I guess I need to go to my muffler shop and see what type of deal I can work. I want a muffler nice and new in the box, off craigs list of course. lol
I quess I'll search here and on CL for a magnaflow or borla.
if you want a Magnaflow muffler use performancepeddler.com they are the largest online magnaflow dealer and give you the absolute lowest prices.
look at y8s' car above.
you can fit the 5x8x18 in there no probelm, you just need to start getting creative....example:
actually I like this better than the typical two 90* bends.
vs my standard 5x8x14:
and my now 4x9x14:
you has plenty of room to work with...
and my now 4x9x14:
http://autospeed.com/cms/article.html?&A=0883
A butterfly valve after the muffler, that is very partially closed in vacuum, and opens under boost. The partially closed valve will only add 1-2psi of backpressure during cruise, and significantly reduces noise (IIRC > 8 dB in their testing!)
