old volvo turbo in a miata?
there's a free volvo turbo up for grabs on my local CL. i'm wondering if it's worth trying to apply it to my 91? i'm thinking it should be pretty low boost, so i'm wondering how much (if any?) fuel management would be needed, and what i'd need for parts. i'd probably get the cheapo OBX manifold and downpipe from eBay. does a turbo like this need to be intercooled, or could i go without?
so 150 bucks for manifold and downpipe and free turbo... could i really get a (mildly) successful turbo set up?
:n oob:
:n oob:
Go to the NEWB section of the forum and read a few threads from there. It's on the main page, just scroll down. You'll quickly find out that newbs that fail to search and learn on their own don't last long here. Read all the faqs and stickies. See you in a few weeks.
sorry about that, i should've known better. i'll go do that. mods, please delete or lock this thread. it's of no use to anybody until i learn more about turbos.
thank you
thank you
Aww, look a humble noob! skiboy, I'm sure after doing some learnding, you will be welcome here with open arms. (just don't drop the soap)
That cheap-*** cast manifold is a t3 flange.
That said, T3s weren't the only turbo to come on Volvos.
Nobody mentioned anything about "just bolting it on".
Dude, just go away or something ... all one would need to adjust the boost is a manual boost controller of some sort. That manifold will work just fine, theres a few peeps running that one w/o problems. Just gotta stay away from the tubular manifolds.
I'm positive these things used to be sold as T3 flange's a few years ago. Regardless, it was the OP himself that suggest a OBX manifold, where we said use the ilovetacotaco manifold in it's stead.
sorry I don't keep up with the latest eBay manifold offerings. What im trying to figure out is how i ran my volvo t3 wastegate at 6psi, when of course it's a 9.6psi wastegate.
get over yourself dude, you really dont know **** about anything man.
Volvo had multiple turbo offerings per model. In the dealer documentation they mention "low pressure" and "high pressure" turbo options. That applies to the older model line up, (up to the mid 90s) where I would assume a free turbo would come from. So the older ones (T3's, .69 A/R 45 trim) could very well have had two different wastegate setups....
--Alex
--Alex
right- OP said that, Brainy offered up the cast which is t3.
Most- not all. And which does the OP have?
You can pick up used lower psi wg cans on for cheap on eBay.
You'd be better off having the facts vs. shooting down all the suggestions as wrong.
None of this complicated.
And most volvo oem turbos are t3.
Most of use weren't privy to all the background information you acquired before you started posting here.
http://forum.miata.net/vb/showthread.php?t=301657
Regardless of the flange, I don't believe many of our members here would recommend an OBX or SSAutoChrome manifold. I was always under the impression the OBX was a T3, as I was looking at a cheap replacement when my first log manifold cracked.
As regards the fueling and the rest, also I don't believe many of our members wanted to sit here and writeup the exact parts steps the OP should take either.
The only reason you posted in here was you were trying to make us look stupid. The OP was told to go read up before continuing. I gave him a freebie and simply told him to look into the cast manifold, then another member agreed. Only then did you come in at this post trying to stir muck; your first post have you. Who knows how the this discussion would have panned out if you hadn't stepped in.
Show us where akaryrye said the mbc would lower boost pressure. He did say it would control it.
Show us where akaryrye said it would "bolt up". He said "tacotaco manifold". Add to that a free t3, DIY downpipe and fuel. Why won't that work? It will bolt up. T3 will bolt to a t3 manifold. DIY will bolt to a t3 turbo and exhaust... And fuel is a requisite. He even suggests avoiding the tubular OBX type manis.
My point is, you're shooting down suggestions that are legit. You'd be better off replying to the OP with your own recommendation vs. knocking all the other suggestions.
I wonder how many brain cells I lost reading this
Originally Posted by haverty
he's not including oil and coolant lines, where to tap those off of, fabrication of an exhaust system to mate with the downpipe (albeit possibly creating a downpipe to mate with it, but it would suck *** and boost spike like crazy), controlling compressor surge, timing retardation, the fittings for the turbo, clamps, hoses, EGR block off, a stronger pcv valve, and whatever other little things I may be forgetting.
Granted he's speaking in generalities, but he's also speaking to a guy who has never done anything with turbo's before, so generalities lead to a false sense of complacency to which the OP can get him self in trouble with.
elesjuan
11-14-2018 12:18 PM
