Walbro 190hp Install
Old 12-03-2006, 07:48 PM
Originally Posted by UofACATS
Could someone enlighten me on the "zis wheel?"
Compact handheld pnuematic circular saw. Cuts through the metal fuel tube like a torch through butter.
Old 12-03-2006, 08:00 PM
UofACATS's Avatar
Well that sounds good.
UofACATS is offline
Old 12-03-2006, 08:16 PM
miatamania's Avatar
I don't think I've ever even seen one...sticking to the dremel
miatamania is offline
Old 01-17-2007, 11:00 AM
Mimime's Avatar
I've installed my Walbro still maintaining the funnel on the stock hosing.
taken out the factory pump plactice spacers and O rings. Although the Walbro pump was abit longer than the OEM pump, but I was manage to get the unit in the bottom bracket without the soft plastic bushing.
Attached Thumbnails Walbro 190hp Install-fuelpump1.jpg   Walbro 190hp Install-fuelpump3.jpg   Walbro 190hp Install-fuelpump4.jpg
Mimime is offline
Old 01-17-2007, 03:14 PM
that7guy's Avatar
Total Cats: 9
Sweet, now come help me install mine....
that7guy is offline
Old 01-17-2007, 03:51 PM
dude it takes 15-30mins. Bring it down to the meet on sunday and I'll do it.
Old 04-02-2007, 05:45 PM
Just put mine in (190HP), pretty easy. Mine's a '93 so I had to cut off the funnel, other than that it's a breeze.
Remember to de-pressurize before you start. Also plan for a little fuel to leak out of the lines when you disconnect them up top. I angled them upward and they stopped leaking.
kotomile is offline
Old 04-03-2007, 06:03 PM
  #28
cueball1's Avatar
Easy Easy Easy. For the mechanically disinclined this is simple. I've replaced these on other vehicles that were sickeningly difficult. Had to drop the gas tank, etc.
Question. Bought mine 2nd hand. On the stock pump the bottom of the unit is cast metal. On the walbro it's plastic. My 2nd hand unit had the bottom post for the little retainer broken off. Think running a little screw into the plastic would be a problem to hold the filter sleeve intake unit?
cueball1 is offline
nick470
7
06-16-2017 01:53 PM
lsc224
10-01-2015 09:17 AM
Quick Reply: Walbro 190hp Install
