Turbo Blankets!!!!
Old 12-04-2006, 12:08 PM
Kelly's Avatar
Default Turbo Blankets!!!!
Ok guys, I had talked about trying to set something up so we could get some of these nice turbo blankets for around $110 shipped. I got it all set up with Alamo and called and ordered 2 already. They are available in black and silver.
You can call them at 817-860-4300 and reference the "Kelly Deal" for the turbo blankets. Here is a pic of mine.
Kelly is offline
Old 12-04-2006, 12:11 PM
BrokeEnthusiast's Avatar
what sizes?
BrokeEnthusiast is offline
Old 12-04-2006, 12:15 PM
Kelly's Avatar
They fit T3 and T4 based turbine housings no problem but they will also work on a lot of the smaller stuff as well when you cinch them up. You can see in my pics it fits well on my old T3 with room to cinch it up even more.
Kelly is offline
Old 12-04-2006, 02:15 PM
rmcelwee's Avatar
Did you find out the dimensions or should we ask when we call?
rmcelwee is offline
Old 12-04-2006, 02:35 PM
Kelly's Avatar
Shoot them a call and see what they say. I think it will snuggle down on your T25 no problem though.
Kelly is offline
Old 12-04-2006, 10:07 PM
boostinsteve's Avatar
Would you recommend the t3 for the td04h on the greddy kit. Also, how long will this group buy be open for, I just found a smoking deal for a turbo tony dp, and will have to jump on it, so, I will have to wait until the 15th to get the blanket. Sound good
boostinsteve is offline
Old 12-04-2006, 10:29 PM
Kelly's Avatar
This is no group buy or anything. I needed a blanket and so did a buddy so I figured I would make a call to see if a bunch of people wanted them if we could get a small price break.
They only offer one blanket and it fits T3's and T4's but should work on the T25/26/and 15g
Kelly is offline
Old 12-06-2006, 08:43 AM
Exactly how well does this thing work? I understand it will lower underhood temps, but by how much? Does it improve with scavenging? Are there ANY drawbacks?
Old 12-06-2006, 09:09 AM
you'll be able to rest your hand on top of the blanket.
All the heat stays in the housing, which likely results in improved turbine efficiency.
Lower underhood temps are good for lower final intake temps at the manifold if the sourced air isn't as warm.
No need for being super creative with metalwork and making heat shields.
DIY Bling Factor
Old 12-06-2006, 10:23 AM
Kelly's Avatar
Brain pretty much summed it up. They do a great job keeping the heat in.
Kelly is offline
Old 12-06-2006, 10:34 AM
That's what I thougt... maybe after Christmas. Car money this month goes to dyno.
Old 12-06-2006, 01:30 PM
Any issues regarding trapping moisture against the turbo?
Old 12-06-2006, 01:47 PM
It's not acting like a sealed header wrap, so I would assume no worries.
Old 12-06-2006, 01:59 PM
Kelly's Avatar
I don't think so.
Kelly is offline
Old 12-06-2006, 04:09 PM
rmcelwee's Avatar
After taking a second look at my turbo I just don't see how I would mount this thing. The WG hookup and large dp flange would make my install comletely different than what you have pictured on your turbo. Ugh!
rmcelwee is offline
Old 12-06-2006, 04:22 PM
turbored's Avatar
someone with a GReddy buy one and install it, so us risk adverse guys can see how it fits on a GReddy'd kit
turbored is offline
Old 12-06-2006, 04:23 PM
Kelly's Avatar
I'll send mine to someone if they wanna test fit.
Kelly is offline
Old 12-06-2006, 04:42 PM
I don't think it would fit on the Greddy turbo because of the location of the wastegate actuator, might have to modify it some what.
jayc72 is offline
Old 12-06-2006, 04:43 PM
send it to me with the vaculator. i can test it on my t3 and brads greddy and take pics. Which will in turn probably convince me to buy one.
Old 12-06-2006, 05:08 PM
Kelly's Avatar
Ok. It will probably be next tuesday when it ships out unless my blanky shows up sooner.
Kelly is offline
Quick Reply: Turbo Blankets!!!!
