TD04H turbo on a 1.8?
Old 03-07-2007, 10:21 AM
Ataim's Avatar
Default TD04H turbo on a 1.8?
I have a greddy kit that was on my 1.6 and want to switch it over my 1993 with a 1.8 motor. The turbo is a TD04H. I have two questions. Is the turbo big enough to get to around 220 hp without too hot of an intake tempeture.
And does anyone make a manifold to fit the 1.8 and the TD04H turbo?
FYI my current setup has:
Blue Emanage
Walbro fuel pump
starion IC
Vetech fuel presure regulator
ect.
Ataim
Ataim is offline
Old 03-07-2007, 10:43 AM
you'll need to use the HKS manifold and modify the DP
Old 03-07-2007, 11:27 AM
Ataim's Avatar
What kind of modification? How 'bout size of turbo?
Ataim is offline
Old 03-07-2007, 01:23 PM
the turbo will make 220rwhp on 1.8 at 12-15psi.
the main thing is the placement of the turbo, as the block in longer, and they don't both sit in the eact same spot. the reason I recommend the hks manifold is that the turbine flange is horizontal like the greddy, so the only modification may only be extending the DP, but you wont need to rotate the flange and reweld it all.
01-03-2016 07:18 PM
JxPhan
10-02-2015 02:17 AM
10-01-2015 11:25 AM
JesseTheNoob
09-30-2015 02:44 PM
Quick Reply: TD04H turbo on a 1.8?
