Newby? HOW DO I INCREASE MY BOOST???
My set-up is in my sig....and I have an IC on the way....So, between the 1.8 injectors, Bipes and the IC I would like to increase from stock boost...maybe to 7-8 PSI.....
Is it all in shorting the rod?
Is it in changing the vacume?
Do you have to open it up and play with the internal wastegate?
Thanx
Thanx
Cpt. Slow
Total Cats: 1,146
inline on the vacuum line going from the compressor housing to the wastegate. with your current setup you'd probably be safe with 6-7psi of boost, 7-8 once you install your intercooler. although set your bipes to pull 8* of timing at 6psi, and 10* at 7psi. you could set it back to pulling 6* once you install the intercooler.
reducing boost?! :gay: you can't reduce boost....you're getting somwhere with regulating...or controlling, hense manual boost controller....you manually adjust your boost level.
you need to learn yourself some son...http://www.autospeed.com/A_107770/cms/article.html
if you understood exactly how a turbo works, then you would know how a MBC...let alone the wastegate works.
I understand that a turbo increases the air density thus effecting the air/fuel ratio....and a wastegate allows the exhaust to bypass the turbo to regulate boost, increase spool up and reduce the temperature of the turbo......but all turbos are different some with internal, external and no wastegate...
What I don't understand is the best way to increase boost on the GReddy and how the wastegate is controled....I assume vacume controls the wastegate......
Say I have an arbitrary MBC set to 15psi and the actuator of the internal WG of my Greddy turbo is only 5psi. The MBC would not allow the actuator to see ANY positive pressure (PSI) until the MBC has come close to or surpassed 15psi. It is much like a series circuit. You have to go through the MBC before you can reach the actuator.
Danimal. I have one you can test out. or better yet, order this thing.. http://cgi.ebay.com/BLU-TURBO-BOOST-...QQcmdZViewItem I have the same one and i plan on running 8psi and My set up is identical to yours, im just waiting for a good deal on a fuel pump : / Give me a call sometime tommorrow 916 370 8395
If you really want to splurge, go for a 2 stage MBC. 1 stage MBC just bleed air that should have helped the turbo spool up and avoids turbo boost spikes. On a 2 stage MBC, the first stage is controlled by a stiff ball/spring. This will get you into your target boost ball park. Then the 2nd stage lets you fine tune the boost by 1/2 psi.
I've been using one for two years, and never had a boost spike that could have killed my motor. Bought it from a guy on eBay, who still answers my support email today. ebay listing #300127883674
92 yella yes you can it is just a rubber diapghram dealy.
You can reduce boost but that is another story. A MBC reduces the boost signal to the WG by either delaying its action or bleeding it off, via a small port. A EBC or electronic boost controller drives a solenoid that regulates the WG signal allowing you to tailor your boost level to what ever you like so long as the turbo can support that much boost at that rpm. Seriusly dude spend about 3-4 hours rooting around here and you will see why we joke so much. This stuff is simple it is just that some people have trouble invisioning it, and get frustrated etc. But that is ok to we all get abit sometimes and stuff into a million pieces. The important thing to tell yourself is this is simple make a basic mental checklist from the faqs etc hell write **** down, to stay organized and you will likely surprise your self. GL man
