Oil supply restrictor
Old 08-31-2006, 04:29 PM
Kirby's Avatar
Default Oil supply restrictor
Hey guys i just got my turbo running, but it seems my oil supply line is too big and is putting too much oil pressure into the T-25 turbo. Im running a -4an line and i need to run a -3an. Does anyone know where i can get a 10mmX1.5 to -3an adapter to use on my block? Or something that would reduce the pressure on a -4an line. Im so close to finishing this turbo and it's killin me to have these little problems.
Thanks!
Kirby is offline
Old 08-31-2006, 04:39 PM
Buy a restrictor.
I run this one personally:
http://www.atpturbo.com/Merchant2/me...egory_Code=OIL
or if you are gung-ho on running a -3an line then:
Old 08-31-2006, 05:30 PM
Kirby's Avatar
how does the oil restrictor hook up? Does it attach to the turbo? Will this work on my -4an line?
Kirby is offline
Old 08-31-2006, 05:38 PM
Sirnixalot's Avatar
Total Cats: 17
screw the adapter into the turbo and screw the -4an line onto the adapter...
Sirnixalot is offline
Old 08-31-2006, 05:50 PM
Kirby's Avatar
My T25 uses a 7/16 inlet thread that restrictor uses a 1/8 npt though so i think i might have a problem
Kirby is offline
Old 08-31-2006, 06:49 PM
K, what about this instead.
http://www.extremepsi.com/store/cust...cat=336&page=1
screw that into the turbo and the line right into that. Might want to get a 90* fitting
Old 08-31-2006, 10:04 PM
Kirby's Avatar
I just ordered that restrictor, Thanks Braineack for the help, it was much appreciated
Kirby is offline
Old 09-01-2006, 07:11 AM
Sirnixalot's Avatar
Total Cats: 17
atp had what you were looking for as well, shoulda found it if you looked in the oil supply section
Quinn
Cars for sale/trade
6
10-23-2016 07:58 AM
Aroundcorner
10-01-2015 03:20 PM
JesseTheNoob
09-30-2015 02:44 PM
Quick Reply: Oil supply restrictor
