Thread sealant when it has to work
Old 02-08-2010, 09:37 AM
miatauser884's Avatar
Total Cats: 11
Default Thread sealant when it has to work
I made my block off plate and tapped it for 1/4 npt. I used the tape type thread sealant. I'm worried that I should used something else. IF it leaks, then it will be a pain to get to. Should I used some type of loctite sealant instead of the thread tape?
miatauser884 is offline
Old 02-08-2010, 09:44 AM
hustler's Avatar
In my experience, Resbond is the best thread sealant I've ever used. Its worked flawlessly on brake, fuel, water, and exhaust fittings.
hustler is offline
Old 02-08-2010, 10:23 AM
dustinb's Avatar
It's good to 10,000 psi.
dustinb is offline
Old 02-08-2010, 10:33 AM
Total Cats: 11
Thanks guys. I just happen to have a small tube of resbond. I will use it.
Where do you buy the great white compound? Looks like it would be good to have a can on hand.
Old 02-08-2010, 10:41 AM
dustinb's Avatar
I think Home Depot carries it. It's sort of the standard in the natural gas industry. It's always supposed to stay moist, and after a year on my turbo water fittings, it was still wet.
dustinb is offline
Old 02-08-2010, 12:02 PM
Total Cats: 4,080
npt + tape sealant = fine
Braineack is offline
Old 02-09-2010, 12:20 PM
Boost Pope
Joe Perez's Avatar
Total Cats: 6,593
Yep. Ace, HD, Lowes, etc. you can get it in a smaller tube as well, which is what I use.
Good stuff. Messier than tape, but IMO easier to get a proper seal with.
Joe Perez is online now
Old 02-09-2010, 08:38 PM
flipt86's Avatar
Total Cats: -1
There is also thread compound in the parts store next to the thread locker. It's in a white tube instead of a blue one. (permatex)
flipt86 is offline
Old 02-09-2010, 08:42 PM
Ben
Supporting Vendor
Ben's Avatar
Total Cats: 134
What he said. But for permanently mounted fittings like this, I usually will get a little JBWeld on the threads.
__________________
Chief of Floor Sweeping, DIYAutoTune.com & AMP EFI
Crew Chief, Car Owner & Least Valuable Driver, HongNorrthRacing
91 Turbo | 10AE Turbo | 01 Track Rat | #323 Mazda Champcar
Originally Posted by concealer404
Buy an MSPNP Pro, you'll feel better.
Ben is offline
Old 02-09-2010, 09:24 PM
Reverend Greg's Avatar
Total Cats: -26
Tape is fine,we use it on all our tapered threads.JB weld for the super strong,silver brazed for permanent...I used silver brazing.
(G)
Reverend Greg is offline
Old 02-09-2010, 09:32 PM
hustler's Avatar
My fuel line fittings are leaking on my rail from the shitty Jeg's crap I bought. I'm going to redo them. FYI.
hustler is offline
Old 02-10-2010, 06:38 AM
timk's Avatar
Total Cats: 37
I made the mistake of using it on an oil pressure sender, the thread tape just broke down and it started leaking. Used some Stag jointing compound and it has been fine since.
timk is offline
Old 02-10-2010, 10:08 AM
wrxnova's Avatar
Total Cats: 4
Very strong but messy. Also has to be done correctly the first time as this stuff is near impossble to break free. i used this to seal the fittings on my oil cooler, and patch a gas leak before.
wrxnova is offline
Old 02-10-2010, 12:31 PM
sn95's Avatar
Wear nitrile gloves when using this stuff; it doesn't wash off your fingers, it wears off over time! BTDT
sn95 is offline
Frank_and_Beans
Supercharger Discussion
13
09-12-2016 08:17 PM
Trent
10-01-2015 12:15 PM
lsc224
10-01-2015 09:17 AM
mx592
1
10-01-2015 12:45 AM
shooterschmidty
Engine Performance
8
09-30-2015 10:28 PM
Quick Reply: Thread sealant when it has to work
