my LeMons car
Old Nov 2, 2008 | 05:01 PM
  #101
KPLAFIN's Avatar
The 24 Hours of Lemons can be a somewhat rough-n-tumble endurance race. You remember the final scene in Mad Max Beyond Thunderdome?
I'm guessing they're putting it there to keep it out of harm's way, as a busted radiator due to a front-end collision would pretty much end your day.
I can only imagine how un-goddly hot it's going to be in that car for an extended period with the rad ~1 foot from you. Guess you have to make sacrifices though...
On a side note....should I be embarrassed that I've never seen Mad Max?
Old Nov 3, 2008 | 02:11 AM
  #102
eyesoreracing's Avatar
Total Cats: 16
Have you ever been to Thunderhill in December? Our car will be the most comfortable place for 100 miles in any direction.
-D
Old Nov 3, 2008 | 02:15 AM
  #103
Total Cats: 16
Fired her up for the first time today. No turbo at first, onaccounta I got the wrong thread pitch for our turbo oil line fitting.
Click on the fireball for a video and at least a little sound...
I think the little white sparky things in the fireball are dead spiders. The exhaust spent the last 4 years in the back yard...
-D
Old Nov 3, 2008 | 11:10 AM
  #104
JKav's Avatar
Total Cats: 47
Here's what the exhaust looked like after it was dug out of the backyard, a small pile of dirt shaken out, and installed:
Old Nov 3, 2008 | 01:57 PM
  #105
JKav's Avatar
Total Cats: 47
One thing we noticed while running the engine for the first time--during warm idle, the idle would intermittently drag down every few minutes, and then recover, like some big load just switched on.
Electrical accessories are minimal on our car. No HVAC, just the gauge cluster. Its not the radiator fans cycling on and off because we installed a switch override and were running them constantly. Stock 1.6 ECU, injectors, etc. Harness is from an auto trans 1.6; we now have a 5spd manual.
Any ideas on what to check?
Old Nov 3, 2008 | 03:04 PM
  #106
o2 sensor open/closed loopage shenanigans?
Old Nov 3, 2008 | 04:30 PM
  #107
Total Cats: 16
Well it was all happening at idle, so that seems unlikely. Unless there's some strange open-loop idle thing I don't know about.
-D
Old Nov 7, 2008 | 09:09 PM
  #108
DragonsMaw's Avatar
-D
I've got the same thing with a stock car and also no idea what's going with it. My plan is just to go standalone and see if it still happens.
Or swap engines.
What did you guys end up deciding for engine management?
Old Nov 8, 2008 | 01:26 AM
  #109
Total Cats: 16
We've got a fuel pressure regulator and a magic spark box. Tomorrow we try it. Wish us luck...
-D
Old Nov 8, 2008 | 09:15 PM
  #110
Total Cats: 16
baseline run, no turbo. First time this pile of parts has done anything under load. Not bad at all.
Old Nov 9, 2008 | 12:08 AM
  #111
Total Cats: 16
Much progress...
Little things, like the oil feed line, finally.
And the downpipe support brace (Hood hinge on the engine side bolts to a parking brake cable bracket on the exhaust side)
Old Nov 9, 2008 | 12:11 AM
  #112
Total Cats: 16
And the big exciting things, like this intercooler. It came from a blue car.
The inlets and outlets weren't where we wanted them, and we have no aluminum welding skillz, so we gave it to a homeless guy to weld for us.
Then we used some of these
and some of those
to put it in the car.
Old Nov 9, 2008 | 12:13 AM
  #113
Total Cats: 16
Words are unnecessary...
Old Nov 9, 2008 | 12:33 AM
  #114
Total Cats: 16
And now the problems...
1: pinhole leak in the brazing where we attached a -4 AN fitting to the stock Mexican Dodge oil line. Observe wet frame rail and active mopping operation...
2: Wacky fuel pressure.
In naturally-aspirated form, the fuel pressure was running a near constant 47 psi. it should go down with manifold vacuum, but it didn't. It waggled around a little on transients, but didn't really behave correctly. A/F on the dyno was still a happy 13:1.
We noticed the periodic idle stumble a couple of times, but not while we had the fuel pressure gauge hooked up. We're starting to think there's a relationship...
At one point (still before the fuel pressure gauge) the car died, and there was this strange thump-thump-thump-thump sound coming from under the car. Just before I turned the key off, Sarah spotted the fuel line pulsating in time with the noise.
Periodically there's a strange low buzzing noise that sounds like its coming from under the dash (only audible from the driver's seat) that corresponds with weak fuel pressure and a familiar idle stumble. I can best describe the sound as similar to bubbles rushing through a small, orifice. Yea, I know, no hydraulics or fuel lines under the dash, I'm just sayin that's what it sounds like...
And, with the turbo in place, (and a bipes box installed and possibly wired correctly), fuel pressure drops to nearly nothing (10-20 psi) and the car dies as soon as it sees any load (like trying to pull off the lift and drive over to the dyno)
Now that I'm fed and watered and sitting comfortably on my ***, this all clearly points to the fuel pressure regulator. Probably operator error. Anyone know which way the fuel flows in these things? I assumed it flowed out of the stock regulator, into the center of the vortech, out the side of the vortech, and back to the tank. Did I do it backward? Seems like that might explain a lot of what's going wrong.
-Dave
Old Nov 9, 2008 | 12:44 AM
  #115
Total Cats: 16
Yup. That was it. Just looked up some instructions for a Vortech Mustank supercharger that uses the same regulator. I got my in and my out mixed up. Things should run better tomorrow...
101hp ain't bad with your fuel pressure regulator hooked up backwierd!
-D
Old Nov 9, 2008 | 09:45 AM
  #116
Total Cats: 327
Hmm... I've been saving this one for a special thread.
Old Nov 9, 2008 | 12:57 PM
  #117
curly's Avatar
Cpt. Slow
Total Cats: 1,417
sigh...when I sold you that vortech, I was hoping it would go to good use, not be installed incorrectly.
kudo's on the intercooler though, keep us posted on fixing that leak, I'm thinking goobs of jb weld
Old Nov 9, 2008 | 09:45 PM
  #118
Total Cats: 16
I guess you should have thrown in instructions for another $5...
fuel pressure regulators for dummies.
-D
Old Nov 9, 2008 | 10:19 PM
  #119
turbobluemiata's Avatar
I really like your purple vacuum tubing
Old Nov 9, 2008 | 10:42 PM
  #120
curly's Avatar
Cpt. Slow
Total Cats: 1,417
read the greddy turbo faq newb! haha! omg jk hic lolz hic...
