Where is the Tach Signal wire
Total Cats: 7,549
Depends on the year.
From '90-'93, the tach signal comes from the igniter, specifically the yellow/blue wire at position D.
For '94-'95.5, it comes from both coils, the black/white wire at each in parallel.
For '96-'97, it comes from the ECU, a black/white wire at position 4L.
For '99-'00, it's at the ECU, green/orange at position 2K.
For '01-'05, the green/orange wire is at position 3O.
On the NA, there is a single-wire sensor on the back of the head to feed the dash gauge, and a separate two-wire sensor for the ECU. On the NB, both sensors are combined into a single housing with a three pin connector- two wires for the ECU sensor and one for the dash gauge. (In all years, the dash gauge sensor grounds through the body of the device, whereas the ECU sensor has an isolated ground.)
I need info also what sensor the temp gauge on the cluster reads from.
Zaphod
47
Oct 26, 2018 11:00 PM
