Devil's own kit installed
Old May 30, 2009 | 02:31 PM
wes65's Avatar
Default Devil's own kit installed
So, i got my WI kit installed over the weekend. A buddy of mine fabbed up a very ballin' bracket to hold the pump. I also relocated the washer bottle to the firewall. I will snap a picture of the nozzle placement later today. I drilled and tapped the intercooler outlet.
Old May 30, 2009 | 03:14 PM
tyson87's Avatar
why does ur hose there say LOL?
edit: looks good.
so u used the washer tank for it?
Old May 30, 2009 | 03:15 PM
wes65's Avatar
edit: looks good.
Haha, I've gotten comments on that before. That's the coolant reroute hose that begi sent me. Why it says "LOL" I have no idea.
Old May 30, 2009 | 03:16 PM
wes65's Avatar
Yeah, I removed the stock washer fluid pump and the bulkhead fitting went right in.
Old May 30, 2009 | 03:19 PM
94mx5red's Avatar
Is it not a gravity fed pump?
Old May 30, 2009 | 03:20 PM
wes65's Avatar
They are self priming up to 8 feet.
Old May 30, 2009 | 03:50 PM
Total Cats: 7,549
I LOLed at the LOL hose.
I do like what you wound up doing in terms of mounting the pump. I'm thinking that since I've freed up some space over there, I might move mine up from its current location in front of the right front wheel. I've always been a tad nervous about having the water lines running through harm's way down there.
Did you relocate the fuse box?
Old May 31, 2009 | 03:26 AM
wes65's Avatar
Sort of. We did away with the stock bracket that holds the washer bottle and fuse box and made a bracket to go in its place.
Old May 31, 2009 | 08:17 AM
And now i dont feel so alone go forth and preach the gains Wes
Old May 31, 2009 | 08:49 AM
94mx5red's Avatar
Have you driven it yet?
Old May 31, 2009 | 01:20 PM
wes65's Avatar
So, i pulled a LOT of fuel out of my map, upped the boost to 18psi and put in 28* of timing and holy ****. This car is MUCH faster. I probably picked up 40whp at least. No sign of knock. The car is scary fast now. Roll into boost and lose traction. I cant wait to go to the 1/4 mile and bust out a mid 12's pass.
Old May 31, 2009 | 02:58 PM
thesnowboarder's Avatar
28*? What were you at before the WI?
I'm sold.
Old May 31, 2009 | 03:02 PM
wes65's Avatar
I'm sold.
I was running around 17* before WI
Old May 31, 2009 | 03:15 PM
Total Cats: 7,549
Would you mind posting the timing map that you've worked so hard to perfect? I'd like to see how much more you've been able to run than mine (which I still have not dyno-tuned.)
Old May 31, 2009 | 03:19 PM
wes65's Avatar
Haha not exactly perfected. I basically typed in 28's in all the cells above 140kpa and 4000 rpm.
I will post it up later.
Old May 31, 2009 | 05:03 PM
Total Cats: 7,549
No ****? Well, I've clearly got a ways to go then. If I ever wind up being back home for long enough to get out to the dyno I found, I'll see just how far we can push this bitch. Still a bit worried just how far I want to go on the stock rods.
Old May 31, 2009 | 05:16 PM
BenR's Avatar
You go until they break, then rebuild it, faster, stronger. If nothing else, it will give you a new reason to play with cars.
Old May 31, 2009 | 05:37 PM
wes65's Avatar
So, this is what it looks like when someone just guesses at a spark map.
Old May 31, 2009 | 06:16 PM
pdexta's Avatar
Total Cats: 184
That's really impressive. I had no idea water injection would allow you to add that much timing. Just out of curiosity, how many psi were you running before the WI? I know it says "stock motor" in your sig... but, I have to ask, this really is a stock motor right? Congrats on the gains!
Old May 31, 2009 | 06:42 PM
wes65's Avatar
I was running 14psi before. it peaks at 19 and steadies out at 18. Yes. It is the stock motor. 87k miles never had the head or oil pan off. I am on a quest for 400whp on the stock motor.
