Transient Throttle
Old 09-16-2009, 11:29 PM
TravisR's Avatar
Total Cats: 13
Default Transient Throttle
EVERYTHING IS CORRECTED... Lets hope, that last manual was crap. My appologies for the horrible write up. This one is better. Promise. Please let me know if you see any errors (typo's or otherwise)
File Type: pdf
TravisR is offline
Old 09-17-2009, 08:46 AM
TravisR's Avatar
Total Cats: 13
I have some edits to do after rereading it today. I never can write things well the first time through it seems...
TravisR is offline
Old 09-17-2009, 10:04 AM
that's what proof readers are for!
Old 09-18-2009, 09:51 PM
TravisR's Avatar
Total Cats: 13
Updated!!
TravisR is offline
Old 09-21-2009, 05:55 PM
sv650_ck's Avatar
Has anybody with a turbo gotten the predictive map working? If you have, can you post a screen shot of your settings - thanks.
sv650_ck is offline
Old 09-21-2009, 06:02 PM
neogenesis2004's Avatar
This is what I'm running. Gives me amazing response on my stock 1.6.
neogenesis2004 is offline
Old 09-21-2009, 06:37 PM
TravisR's Avatar
Total Cats: 13
I know man, isn't that throttle response sick? It was never that good stock I know that for a fact.
TravisR is offline
Old 09-22-2009, 11:10 PM
sv650_ck's Avatar
I attempted to get Kpa points to fill in the table but it doesn't seem possible. How do you get to 6k rpm @ 2% or 5% tps or 2k rpm @100% tps, etc.?
sv650_ck is offline
Old 09-22-2009, 11:32 PM
its an educated guess. It will always be vacuum there.
Old 10-14-2009, 03:18 PM
swimming108's Avatar
Total Cats: 11
can anyone else with good results post their data? i am still having a tough time getting things perfect.
swimming108 is offline
Old 10-14-2009, 08:07 PM
sv650_ck's Avatar
I spent some time with it with so-so results. My map sensor has been getting flaky so that could have been part of the problem. Will try again after the new sensor is installed.
sv650_ck is offline
Old 12-30-2009, 06:51 AM
Total Cats: 3,481
So you guys tried the map Neo posted and its so so?
18psi is offline
Old 12-30-2009, 11:25 AM
it's a reasonable starting point. just do some normal driving and run a datalog the whole time and see if it's close enough and if it's not, fix it
Old 01-04-2010, 02:34 PM
Jabbah's Avatar
Thanks for the tutorial, just set this up now. One thing though is that Rob_k over on the adaptronic forum recommends 80-100% for Async gain. Using it at 100% atm with good results, although havent tried 30% or less to compare...
Edit: Just re-read the v2.0 user manual, the 1-30 gain value is for the old transient throttle method.
Jabbah is offline
Old 01-04-2010, 09:49 PM
sv650_ck's Avatar
Good info - mine is currently set to 30% for gain and 500ms transition time. Will have to try 100%.
sv650_ck is offline
Old 01-04-2010, 10:17 PM
TravisR's Avatar
Total Cats: 13
Good discovery! Thank you! I will update the manual.
TravisR is offline
Old 02-03-2010, 12:32 AM
PhantomRoadster's Avatar
Is anyone still having problems with their transient throttle? I fine tuned my map using my data logs and neos map but got lean tip in. To resolve the issue I made it rich by increasing the kpa +20-30 in most cells but am now getting lean tip in and rich right off throttle. My gain is at 100% and trans time at 300 ms. Any advice?
PhantomRoadster is offline
Old 02-03-2010, 12:37 AM
Total Cats: 3,481
I am having MAJOR problems this this. No matter what I do with the table it has INSANE lean tip in and then goes pig rich after like 1-2 seconds. So its ******* HORRIBLE.
I turned off the table and am trying to mess with it the old fashioned way, but have little luck with it.
If somone could chime in with a little more information on how to get rid of this **** I'd be very thankful
18psi is offline
Old 02-03-2010, 02:34 AM
Total Cats: 3,481
I re-read the tutorial for the 10th time and will try messing with the table 1 more time tomorrow. Wish me luck
18psi is offline
Old 02-03-2010, 03:03 AM
bellwilliam's Avatar
Turned off "use map prediction", and it fixed most issues for me.
bellwilliam is offline
Quick Reply: Transient Throttle
