AEM UGEO on Adaptronic
Old Jan 8, 2010 | 05:14 AM
nismo502's Avatar
Default AEM UGEO on Adaptronic
Anyone running AEM UEGO on your adaptronic?
If so, are you running off spare or serial? Are your readings accurate?
Old Jan 8, 2010 | 08:38 AM
Stein's Avatar
Total Cats: 166
I ran mine serial, worked great.
Appeared to be accurate.
Old Jan 8, 2010 | 11:09 AM
sv650_ck's Avatar
^ Same here
Old Jan 8, 2010 | 12:11 PM
nismo502's Avatar
Thanks guys, I am running on spare now. Will try serial and see if it differs
Old Jan 8, 2010 | 07:45 PM
Prospero's Avatar
Running Serial and have no issues...
Old Jan 31, 2010 | 09:14 AM
nismo502's Avatar
guys,
I am tying to run serial but couldnt get a reading, It must be something stupid I have done. Is there any other settings I have to do?
I am tapping ground for the serial from the AEM gauge and pin 2 from blue AEM wire. The color of the serial pin wires are brown to 5v AEM and yellow to ground.
Have I done anything wrong?
Old Jan 31, 2010 | 02:32 PM
serial here too...works like a charm...
Read the instructions again carefully. There's a thread here where this specific gauge is installed. Made by Stein I think. Follow it to the T. Also read my thread (one of them lol) I think I had different color wires from steins if I remember correctly.
Old Feb 9, 2010 | 12:03 PM
nismo502's Avatar
guys,
are you all running the latest firmware and wari software?
What did you set for oxyen sensor and second serial port in adaptronic?
I am getting a reading from the hyperterminal but not adaptronic:(
Also,
did u hook up the white wire to spare and the blue wire to serial or both or vice versa?
Old Sep 8, 2011 | 06:47 AM
jamesa5771's Avatar
How did you wire the ground for the serial was it chassis ground or other any one got pictures / diagrams?
Old Jul 28, 2012 | 06:44 AM
timg's Avatar
Hey guys, the new e420d has a 'mini headphone port' for the serial now. I know I wire the blue from the AEM to one of the connections on the headphone jack, but which one? Also, the other connection should be grounded.. should this be just a chassis ground (for clean signal) or a sensor ground from the ECU?
Thanks!
Old Sep 21, 2012 | 06:17 PM
Lokiel's Avatar
All-round "Good Guy"
Total Cats: 266
Late reply I know but may help others in future:
Either buy a stereo 3.5->2.5mm jack converter or connect via analog input.
I used the analog input for my PLX AFR sensor since it does not have a serial connector like the Innovate LC1 I had previously. You SHOULD use ECU GND rather than another GND source for the greatest accuracy.
The PLX AFR sensor module only provides a 0-5V analog output which needs to be wired into the Adaptronic's "Spare Analog Input" (0-5V Analog In) on its 6-pin connector so I had to crack open the e440 and connect it to the PLX AFR Sensor Module's Wideband 0-5V output, as shown here:
satisfied
144
Nov 5, 2018 04:05 PM
Goldwar
Sep 29, 2015 09:20 AM
eunosgippa
Sep 9, 2015 05:19 PM
