CLT & TPS noise
Old Jul 28, 2010 | 09:25 PM
240_to_miata's Avatar
Total Cats: 16
Default CLT & TPS noise
So I have been experiencing some of the random RPM spike issues that have been seen by others. I have been researching and getting ready to do the Abe NB mod. Due to this thread:
https://www.miataturbo.net/megasquirt-18/misfiring-while-cruising-seems-get-worse-when-hot-46772/
I looked back at my log and found A LOT of noise in my CLT and TPS. I believe this is related. What is causing this noise and how can I fix it?
Old Jul 29, 2010 | 12:51 AM
redrider706's Avatar
Try the cap on the boot jumper on the mail board mod. I helped me a lot.
-Raj
Old Jul 29, 2010 | 06:11 AM
Total Cats: 16
Yeah I would like specifics on that mod. I have MS1 and looking thru the info it seems like this is a MS2 fix. Does it install on the daughter board?
Old Jul 29, 2010 | 07:19 AM
Total Cats: 16
You know I was thinking thismorning. ... All 3 of t he signals I have noise on are the ones i am sharing with the stock ecu
Old Jul 29, 2010 | 08:23 AM
...which all share the same ground.
Old Jul 29, 2010 | 08:26 AM
Total Cats: 16
Bingo! My iat has no noise but it is grounded locally I think
Solutions????
Old Jul 29, 2010 | 06:43 PM
The cap is supposed to go across the boot jumper on the main board. I don't know if it will work for MS1.
Old Jul 29, 2010 | 06:49 PM
Total Cats: 16
What size?
Old Jul 29, 2010 | 06:52 PM
try a .1uF, .22uF or .33uF
Old Jul 29, 2010 | 06:55 PM
Total Cats: 16
I'll give it a shot. How does putting a cap across the boot jumper help clean the signal? Won't that essentially short it out?
Old Jul 29, 2010 | 06:58 PM
I put a .22uF. I also have a .22uF and a 3300uF across the 12V coming in.
Old Jul 29, 2010 | 08:30 PM
electronics run on magic.
Old Jul 29, 2010 | 08:38 PM
Total Cats: 16
Good enough answer for me lol
Old Jul 29, 2010 | 11:46 PM
Greenie's Avatar
I'm pretty sure they run on smoke.
Every time I let the smoke out of electronics they stop working.
Old Jul 30, 2010 | 09:28 AM
Matt Cramer's Avatar
Total Cats: 67
Try grounding the sensors to the MS instead of the stock ECU; what's the stock ECU need an accurate reading for?
Matt Cramer
www.diyautotune.com
Old Jul 30, 2010 | 09:32 AM
Total Cats: 16
Haha. The grounds are currently all tied together in the harness. How should I separate them?
Old Aug 1, 2010 | 05:00 PM
Total Cats: 16
AN UPDATE:
-I tried installing Abes NB input mod...it didnt work. I looked over my circuit and it looks fine. I went back to my original circuit and the car started right up.
- Separated stock and MS grounds. Made a better connection... ms has 6awg wire all the way back to the battery ground.
- Installed .22uf cap across boot jumper
I am bumed out the nb circuit didnt work. IDK why. It wouldn't crank, oem tach didn't work, ms tach showed about half of the actual value.
The CAP seemed to work... sorda. I took it for a 5 minute drive getting on boost and bringing it into high rpm. It didnt break up or anything, but the log shows there was still SOME noise. Should I try a different size cap?
Old Aug 1, 2010 | 05:17 PM
a larger 3300uF cap fro.m 12v to gnd might help too
Old Aug 1, 2010 | 05:24 PM
turotufas's Avatar
Pics please? I'm intrigued by this but I'm a visual learner.
Old Aug 1, 2010 | 05:26 PM
Total Cats: 16
I'll post screen shots and pics later
