6 speed trans - needs TLC
Old 09-08-2010, 07:35 PM
dvcn's Avatar
Total Cats: 18
Default 6 speed trans - needs TLC
The memory is failing but I think it's a 2001 trans with approx. 195k on it. The good: it made the car move in both directions when removed. The bad: it works very poorly. So poorly that the crap 5sp (w/ bad synchros and a 2nd gear that sometimes isn't there) that I put in is better.
Features:
-the synchros are bad
-3rd gear is REALLY bad
-it does odd things, twice it wouldn't roll with the clutch in and I could only take it out of gear with the motor shut off. Some sort of slider/shift fork/rod problem I'd guess.
It works but do not use it as is. It NEEDS to be opened, fixed and freshened up. If it doesn't sell then I might rebuild it or more likely, have a pro do it.
I'll include the sloppy shifter that came with it.
$300 shipped in the USA. The usual massive discount for active duty.
dvcn is offline
Old 09-08-2010, 10:53 PM
gospeed81's Avatar
Total Cats: 26
Crap.
Wish I had a couple of hundred to throw at a local pickup.
What a deal.
Repeat: Don't need a built motor...don't need a built motor...
gospeed81 is offline
Old 09-08-2010, 10:58 PM
dvcn's Avatar
Total Cats: 18
Originally Posted by gospeed81
Crap.
What a deal.
For you? If you are at all interested I'll give you a smokin' semi-local deal. I'd even take things in trade. Why do you want a POS trans? I did mention that it's a POS right?
dvcn is offline
Old 09-09-2010, 12:53 AM
chicksdigmiatas's Avatar
Where are you at in texas? I love taking **** apart and fixing it. Active duty discount? Please pm.
chicksdigmiatas is offline
Old 09-09-2010, 09:44 AM
dvcn's Avatar
Total Cats: 18
Yay for local active military!
dvcn is offline
Trent
10-01-2015 12:15 PM
zephyrusaurai
09-28-2015 10:59 PM
Greasyman
General Miata Chat
09-28-2015 10:44 AM
ProjectDDoS
09-09-2015 01:52 PM
Quick Reply: 6 speed trans - needs TLC
