What Turbo do I have?
Old 12-20-2010, 10:06 PM
yellowihss's Avatar
Default What Turbo do I have?
I was told it is a t-28, but that is it. I know there are many variations of the T-28 but I don’t know which one I have. Here is what I know:
The turbo came off an early FM kit, but I was told the turbo was upgraded.
Compressor
Says A/R 48
Inducer diameter = 40.97mm
Exducer diameter = 50.98mm
=64.6 trim
Turbine
Says A/R 64
Inducer diameter = 52.7mm
Exducer diameter = 42.09mm
=63.5 trim
I’m trying to see what the power potential of this turbo is.
I can add pics if necessary.
yellowihss is offline
Old 12-20-2010, 10:13 PM
yellowihss's Avatar
Sorry, posted in the wrong area. Mods please move to DIY Turbo Discussion. Thanks.
Old 12-20-2010, 10:42 PM
RotorNutFD3S's Avatar
Total Cats: 30
Does it have a tag on the CHRA?
RotorNutFD3S is offline
Old 12-21-2010, 12:48 AM
yellowihss's Avatar
No.
Old 12-21-2010, 12:56 AM
yellowihss's Avatar
If it helps.
Old 12-21-2010, 01:01 AM
WonTon's Avatar
smaller than a 2650, i think!
There is only 4 bolts that hold the turbine housing to the CHRA, i only see 4. My 2560 had 6 (wait no, my 2860 has 6.....FAWK idk.) I dont know **** about AR and all that crap...
WonTon is offline
Old 12-21-2010, 01:28 AM
ScottFW's Avatar
Total Cats: 17
Your compressor wheel measurements are a hair smaller than a 2554, and also those currently have a .80 A/R. I believe the .48 compressors were common on the small T25s used on the 300ZX but don't quote me on that. The turbine side sounds close to a 2554 or 2560 but again yours has a more puny compressor. Maybe good for 200 whp? Just a guess.
ScottFW is offline
Old 12-21-2010, 01:40 AM
chriscar's Avatar
Total Cats: 15
Doesn't match up directly with anything here.
http://www.turbobygarrett.com/turbob...ison_sheet.htm
C
chriscar is offline
Old 12-21-2010, 08:08 AM
miatamike203's Avatar
looks like the comp is close to a GT2252 good for 180-260 is what garrett says on there sit so proby max 220
miatamike203 is offline
Old 12-21-2010, 08:41 AM
was the compressor measurement supposed to say 60mm? Cause then it would make sense as a T28 with a 50 trim compressor wheel.
Old 12-21-2010, 09:34 AM
91rps13's Avatar
kinda looks like a nissan ca18 turbo and they are both .48 too.
91rps13 is offline
Old 12-21-2010, 10:51 AM
!!! NOT CONFIRMED !!!
elderc's Avatar
I don't think its a nissan S13 1.8 turbo, cause it doesnt look like this:
http://cgi.ebay.com/ebaymotors/Turbo...Q5fAccessories
elderc is offline
Old 12-21-2010, 12:07 PM
yellowihss's Avatar
Could it be a hybrid?
T25 cold side
T28 hot side
Old 12-21-2010, 12:26 PM
Oscar's Avatar
Total Cats: 120
Thought it looked like the tb2525, but now I'm not so sure anymore
Oscar is offline
Old 12-21-2010, 12:28 PM
more like T25 hotside, T20 "cold"side
Old 12-21-2010, 01:03 PM
91rps13's Avatar
was thinking more like a ca18et (not sure if its the same as the one above though)
http://cgi.ebay.com/ebaymotors/Nissa...item33638faca7
the image sucks so its hard to tell.
91rps13 is offline
Old 12-21-2010, 01:26 PM
lazyguy's Avatar
Looks exactly the same as a sr20 stock turbo t25......Exept for the compressor ind. and exd. fittings.....
lazyguy is offline
Old 12-21-2010, 05:14 PM
Rennkafer's Avatar
Looks pretty much identical to my SR20 T25... I'll have to double check to see if my A/R's are the same though.
Rennkafer is offline
Old 12-21-2010, 09:12 PM
kenzo42's Avatar
Total Cats: 13
Del. Already mentioned.
kenzo42 is offline
Old 12-21-2010, 09:54 PM
sr20 T25 is 52.5mm exducer compressor wheel.
Quick Reply: What Turbo do I have?
