Sponsored by: 949 Racing
brake duct prawns
Old Oct 28, 2011 | 05:36 PM
Total Cats: 2,106
Default brake duct prawns
You're welcome.
Old Oct 28, 2011 | 05:45 PM
dgmorr's Avatar
It's about time someone sells these. What is the length, diameter and material of the hose that you will be supplying with the full kit?
Thanks.
Old Oct 28, 2011 | 05:58 PM
MartinezA92's Avatar
Did I miss something? Are you supplying a full kit?
EDIT: Apparently you are.
Old Oct 28, 2011 | 06:04 PM
Total Cats: 2,106
Thanks.
Kit will come with 11ft of high-temp (500*F) 2" hose, hose clamps, and a handful of zipties to keep everything out of the way.
They will install without removing the hub, but the old dust shields are a PITA to get off with the hub in the way. You really want to just buy two new nuts and dustcaps and remove the hubs - trust us on that. It's $20 well spent.
There's a GB link in our sponsor section, but I wanted to make sure the track crew saw these.
Old Oct 28, 2011 | 08:11 PM
Seefo's Avatar
Total Cats: 48
cool stuff, any pictures of them installed? just as a visual aide?
Old Oct 28, 2011 | 09:03 PM
billybobster's Avatar
Very nice. I will add to my list of things to acquire (growing ever larger).
I found a good picture illustrating why pulling the hub is recommended for removing the OEM shields. So if you don't pull the hub, how is even possible to do the swap?
Old Oct 28, 2011 | 09:17 PM
Seefo's Avatar
Total Cats: 48
nm, that picture actually explains it all!
Old Oct 28, 2011 | 09:19 PM
240_to_miata's Avatar
Total Cats: 16
I hate you. You take all of my money.
Old Oct 28, 2011 | 09:28 PM
ILoveOffRamps's Avatar
how long is the GB open for?
Old Oct 28, 2011 | 11:52 PM
curly's Avatar
Cpt. Slow
Total Cats: 1,403
I've cut the dust shields off without removing the hub. Used a warn down (small diameter) cut off wheel, took a while but possible. Just gotta know it'll be in a dozen pieces when you're done.
Old Oct 28, 2011 | 11:56 PM
Mobius's Avatar
Total Cats: 365
Very nice!
Old Oct 29, 2011 | 02:01 AM
Total Cats: 2,106
You use a box wrench to undo the three bolts, then use a pair of tin snips and a healthy dose of adult language to cut the shield and bend it off the spindle.
Through November 7th.
Old Oct 29, 2011 | 03:44 AM
emilio700's Avatar
Total Cats: 2,618
Why aren't a set of those in my hands now? Please fix this problem.
Crusher need duct poarnz
www.facebook.com/SuperMiata
949RACING.COM Home of the 6UL wheel
.33 SNR
Old Oct 29, 2011 | 04:30 AM
curly's Avatar
Cpt. Slow
Total Cats: 1,403
I need pics of 15x10 6ul, 11.75" BBK, 245 tires, and these ducts. Assuming you can get all those pieces in one shot.
Old Oct 29, 2011 | 06:22 AM
NiklasFalk's Avatar
Total Cats: 63
Photoshop, all parts on the ground, or mounted together?
Old Oct 29, 2011 | 08:13 AM
curly's Avatar
Cpt. Slow
Total Cats: 1,403
Mounted of course. We have some amazing hardware available for bargin prices between 949 and TSE, were lucky to have two dedicated track ***** who also happen to sell the parts they develop.
Old Oct 29, 2011 | 08:57 AM
hornetball's Avatar
Total Cats: 697
Easy now . . . need to keep this at least R-rated. A picture like this would endanger keyboards across the land.
Old Oct 29, 2011 | 09:02 AM
flying_solo's Avatar
Ohh, something else to do this winter. Very nice.
Old Oct 29, 2011 | 09:38 AM
Oscar's Avatar
Total Cats: 120
By all means, don't post any pics of these mounted and hooked up to some hoses
Now come with an easy solution for the duckfaced brakeducts on the R-package lip kthnxbai x0x0
Old Oct 29, 2011 | 12:28 PM
codrus's Avatar
Total Cats: 884
Any idea if they fit with Goodwin brakes? Looks like they ought to, but...
thanks,
--Ian
