How much will i need to change maps
Old Jan 20, 2007 | 06:12 PM
rockdoc's Avatar
Default How much will i need to change maps
Just completed my install of my base kit to my 12psi JRSC 1.6, with a TDR A/A I/C,
I have the nozzle positioned on the stainless pipework from the I/C just before the connection with the dummy throttle body.
I have a temp probe drilled /tapped into the middle of the intake chamber -and have been seeing some temps up to 160degF at full boost.
I already have an aggresive timing map , with base timing at 14deg, i dont pull any timing ,in fact i,m pushing all the way from idle to redline ,just pushing 2deg around 4000rpm -5000rpm,
My Q is - how much will i have to change my fuelling map and will i be able to gain any more timing advance.
Old Jan 20, 2007 | 07:29 PM
yes you should be able to add in more timming, as far as fueling you might need to compensat 3-5% depending on your nozzle and methanol content.
Old Jan 21, 2007 | 02:56 PM
lukydvll's Avatar
Guest
In my experience, I had to take away about 5% when running a meth/water mix. Without any changes to the fuel map, the car would run about 0.5 AFR richer.
Don't take my word though... there's a thread that touches on the issue over an M.net:
http://forum.miata.net/vb/showthread...8&page=2&pp=25
Ben and JMan would disagree with me.
**** m.net...
Bunch of PHONIES
Old Jan 21, 2007 | 04:57 PM
This coaberates what i have seen. just tweak it a hair past your activation point and see how it goes.
Old Jan 22, 2007 | 04:42 AM
rockdoc's Avatar
Thanks Chaps
Need to get down to model shop to get mi self some Methanol then
ihiryu
33
Oct 8, 2015 04:56 PM
MiataGarage
Sep 29, 2015 11:04 PM
brandonbkd
Sep 28, 2015 11:52 PM
