Download msns-extra firmware
Old Oct 20, 2006 | 05:42 PM
bfd_henriksson's Avatar
Default Download msns-extra firmware
OK here is a embarrassing question. I have been away from my MS-projekt for a month or so and now I canīt remember where I was supose to put in a jumper( boot jumper) before downloading msns-extra firmware. I have forgotten what the boot jumper is. Please help...
/Fredrik
Old Oct 20, 2006 | 06:35 PM
Al Hounos's Avatar
its two little holes on the board that say 'boot' next to them. above the prototype area. just put a folded staple in the holes.
Old Oct 20, 2006 | 06:45 PM
Aussie Driver's Avatar
I use EasyTherm to download the software to the MS and that doesn't require the boot jumper to be used.
Old Oct 20, 2006 | 07:06 PM
Reverant's Avatar
Total Cats: 369
If you already have the msnse firmware in your MS and you are just upgrading to a newer version, then you don't need to cap the boot jumper at all. Msnse does this internally for you!
Old Oct 20, 2006 | 07:11 PM
Thanks guys! I managed to miss those holes...
Hmm Might as well download and use Easytherm though Iīm gonna need it anyway to get the right values for my stock CLT.
Again, thanks!
/Fredrik
Old Oct 21, 2006 | 08:52 AM
richyvrlimited's Avatar
Again, thanks!
/Fredrik
remember not to have ignition hooked up when your burning the firmware, It can fry your coils apparently!
Old Oct 21, 2006 | 09:39 AM
Thanks! Lucky for me that I have done a PnP-box with switches for coils and injectors.
Old Oct 21, 2006 | 03:18 PM
Arkmage's Avatar
THAT is a fantastic idea... I'll likely do the same, added convenience AND security.
Old Oct 21, 2006 | 05:13 PM
like to take the cred for it but I stole the idea from "Reverant". My box is a semi-solution compare to his, but itīs nice to be able to go stock if something goes wrong.
Old Oct 22, 2006 | 06:10 AM
Reverant's Avatar
Total Cats: 369
I for one, thank myself all the time for building the pnp box. I would do it time and time again if need be.
Jim
Old Oct 22, 2006 | 08:29 AM
Jim
I wished I had the patience to do a PnP box before I fitted it!!
Old Oct 22, 2006 | 05:15 PM
Reverant's Avatar
Total Cats: 369
I don't have a garage or some other form of parking space at which I can do stuff on the car, much less solder or crimp in a tight confined place. There grew the need for a pnp box: Solder and arrange in the comfort of my workbench @home, open car door, install box, turn key, tune.
Old Oct 22, 2006 | 06:42 PM
iWeasel410's Avatar
I am doing something similar, I just made a pass-through harness for the 97 so that I can cut without hacking up the stock wiring harness. I'm using insulated bullet connectors to make it all PnP.
navalhawkeye
Oct 7, 2015 07:10 PM
The Gleas
Oct 1, 2015 09:30 AM
brandonbkd
Sep 28, 2015 11:52 PM
EErockMiata
6
Sep 24, 2015 09:49 AM
Dobzeh
ECUs and Tuning
Sep 17, 2015 02:56 PM
