Running heater without the original blower
Old 12-09-2014, 12:31 AM
Baker99miata's Avatar
Total Cats: -3
Default Running heater without the original blower
I removed the Dash so that i can relocate my ECU to the Glove box. While I have it open I thought about taking out the OEM blower, blend/mode doors, and the climate control switches. I want to keep my heater so I was thinking about attaching a 12 volt fan to the heater core. The fan will blow the air across the heater core to the defrost ducts. the fan will have an on/off switch, and i will try to use aluminum foil/sheets to direct the air to the ducts. Please give feedback on the Idea or any suggestions.
Baker99miata is offline
Old 12-09-2014, 12:33 AM
Total Cats: -3
This is what my car looks like now and generic picture of the fan
Attached Thumbnails Running heater without the original blower-sku_138608_1.jpg   Running heater without the original blower-wp_20141208_003-.jpg
Old 12-09-2014, 04:12 AM
JesseTheNoob's Avatar
Your going to need a MUCH more powerful fan than that to do anything noteworthy and defrost/warm up the car.
JesseTheNoob is offline
Old 12-09-2014, 07:57 AM
rwyatt365's Avatar
Total Cats: 128
In just to see what (if any) suggestions come through.
I've deleted the A/C on my car and have even gutted the plenum chamber where the heat exchanger used to live, but that's a big, bulky piece of plastic between the squirrel-cage fan and the heater core that I'd like to eliminate. I'm tempted to just try some air ducting from Lowes and see how that works, but I'm interested to see if anyone has some solid experience to go from.
rwyatt365 is offline
Old 12-09-2014, 08:55 AM
Total Cats: -3
I want to order a fan, or decide if i want to use my OEM blower. how about this fan Bitfenix Spectre Pro 200mm Case Fan - Black at Xoxide! its flow rate is 148.72 CFM ±10%.
Old 12-09-2014, 09:06 AM
Total Cats: 4,080
order the OEM box and fan...
Braineack is offline
Old 12-10-2014, 01:21 PM
loudes13's Avatar
Total Cats: 4
My miatacage doesn't play well the stock heater box, so i'm looking for ideas too.
Attached Thumbnails Running heater without the original blower-skillicorn-turbo-miata-roll-bar-cage_zps9c242110.jpg
loudes13 is offline
Old 12-10-2014, 02:01 PM
NiklasFalk's Avatar
Total Cats: 63
IF you plan to test with computer fans, use 2-3 in series to get some flow with the back pressure.
3" marine engine bay fans have been known to work (the same that work well for brake duct hoses and other tricky cooling locations).
Also, don't forget to use cold external (dryer) air to make defogging work well (especially if running with windows).
Making it work as stock-like as possible reduce the number of brain-farts.
NiklasFalk is offline
Old 12-10-2014, 09:00 PM
Total Cats: -3
I'm now trying to use OEM blower but eliminate the Blend/mode doors. I will let you guys know how it works out. I didn't think about the external door, thanks for pointing it out
Old 12-11-2014, 10:35 AM
rwyatt365's Avatar
Total Cats: 128
This is the OEM part from Mazda that goes between the stock squirrel cage and the heater core;
It think that's the way I'm going.
Attached Thumbnails Running heater without the original blower-5933bfaa5af03cb53670aec981721cfd__51403_std.jpg
Old 12-11-2014, 07:39 PM
Total Cats: -3
Wow I'm a little late, I wish if I knew that earlier. Didn't even cross my mind.
My coworker is building a custom heater box with ducts. I love the part number you have.
Old 12-11-2014, 07:48 PM
Total Cats: -3
Default Here are some pics
Here is how far he got, What do you guys think.
Attached Thumbnails Running heater without the original blower-v__9fb1.jpg   Running heater without the original blower-v__98a0.jpg
Old 12-12-2014, 05:55 PM
Leafy's Avatar
Total Cats: 104
Is... Is that part of a down spout for gutters?
Leafy is offline
Old 12-12-2014, 06:10 PM
cyotani's Avatar
Total Cats: 116
This is a fan my FSAE team has used for a radiator in the past. It's about the right size and seems to move alot of CFM.
https://advancedsportvehicles.com/sp...-a101-83a.html
cyotani is offline
Old 12-13-2014, 08:50 AM
Total Cats: -3
yes it is, $3 at home depot.
I hope it all going to work, It's all very light except for the OEM blower motor. The main reason I kept the Oem Blower is to have outside air. This weight reduction has done very little to the weight in the Dash. the dash is still the heaviest part and can't seem to be able to take much of the weight out
Old 12-13-2014, 08:04 PM
flounder's Avatar
Total Cats: 31
is ET pointing at the ducting?
flounder is offline
Quinn
Cars for sale/trade
6
10-23-2016 07:58 AM
JesseTheNoob
09-30-2015 02:44 PM
interestedofold
09-29-2015 01:42 PM
ihiryu
General Miata Chat
09-28-2015 10:22 AM
Quick Reply: Running heater without the original blower
