Built Turbo F20C Time Attack Miata
Old Oct 20, 2014 | 10:41 AM
  #141
1BAD96's Avatar
Total Cats: 45
Have some more updates. My fabricator is moving shops in the next few weeks and the car should be rolling by this weekend! Cage is officially done and looks nutty, I will be going with a different seat to get in and out easier. Fabricated the wing mounts into the frame as well as the cage to make it super rigid! Quarters and fenders are now cut for the new flares.
Put the top on and hood to get an idea what it will look like! We will be able to run the car super low due to the drop spindles and clearance we made. Getting excited to get in on the ground.
Sorry for the cell phone pictures.
Attached Thumbnails Built Turbo F20C Time Attack Miata-img_1214_zps0be7c7a6.jpg   Built Turbo F20C Time Attack Miata-img_1215_zps81b96bc3.jpg   Built Turbo F20C Time Attack Miata-img_1213_zps610fd776.jpg
Old Oct 20, 2014 | 03:43 PM
  #142
Mansalad's Avatar
Total Cats: -15
my god you're car is AWESOME! I was excited to see it run before but now it's just ridiculous lol.
Are you also running an F-series trans? My friend has a f20 in his shop and I'm super tempted to put it in!
Old Oct 20, 2014 | 04:37 PM
  #143
1BAD96's Avatar
Total Cats: 45
Yes for now! Might end up with a dogbox or sequential
Old Dec 29, 2014 | 09:08 AM
  #144
1BAD96's Avatar
Total Cats: 45
Making slow progress as usual, my fab shop moved shops closer to a sheet metal shop that he will be working with on a future project. He will be learning how to use many new sheet metal tools and really looking forward to nice quality pieces for the firewall, rear firewall, rear floor, flat bottom, and diffuser.
After talking it over and over I am having him redo my a-arms. I wasn’t happy with the ones I have and rather than altering the current ones we will be making new ones.
Fuel system is taking shape; we offset the tank slightly to the passenger side. With the ATL fuel cell and Nuke Performance surge tank we should have no problems with fuel starvation. Some pictures for you guys.
The car will be at fab for a few more months. Material for my exhaust will be coming in sometime in February. This will be very exciting project that I have been dreaming of.
Attached Thumbnails Built Turbo F20C Time Attack Miata-img_1319_zps8a66862c.jpg   Built Turbo F20C Time Attack Miata-img_1317_zpsa4114cb8.jpg   Built Turbo F20C Time Attack Miata-img_1318_zpsf4197ae4.jpg   Built Turbo F20C Time Attack Miata-img_1327_zpsc4c8ac7f.jpg   Built Turbo F20C Time Attack Miata-fullsizerender_1_zps59d7dbe3.jpg
Built Turbo F20C Time Attack Miata-fullsizerender_zps3f3b21e6.jpg   Built Turbo F20C Time Attack Miata-fullsizerender_2_zps60449153.jpg
Old Dec 30, 2014 | 01:48 AM
  #145
hingstonwm's Avatar
Personally,I would like to see the fuel cell placed towards the middle of the car. Why would you position it so far to the rear of the car?
Old Dec 30, 2014 | 10:49 AM
  #146
1BAD96's Avatar
Total Cats: 45
Better weight balance because we pushed the motor back!
Old Dec 30, 2014 | 11:19 AM
  #147
shlammed's Avatar
Total Cats: 51
You still want to keep the weight between the axles if you can, in my experience.
this way the weight balance would be adjusted for feel with the chassis setup (ride height, alignment and aero compensation)... getting the 50/50 isn't as beneficial as keeping the car planted about the center of the car for the neutral feeling.
I would personally move it as far forward as possible like was mentioned. It just means you will need a bulkhead fitting and hose to connect for re-fuelling vs taking the trunk lid off.
Old Dec 30, 2014 | 12:19 PM
  #148
1BAD96's Avatar
Total Cats: 45
Noted, position isn't finalized yet.
I will be finalizing a lot of stuff this weekend with the fabricator.
Appreciate the input!
Old Dec 30, 2014 | 01:41 PM
  #149
Total Cats: 3,591
The idea of having the mass as close to the center of rotation as possible is the same as the one for flywheels. The same weight further from the center resists changes in rotation about the center more than when further inward. It will turn more nimbly if you keep it in.
Old Dec 30, 2014 | 03:34 PM
  #150
1BAD96's Avatar
Total Cats: 45
Well said. Final placement will be made this weekend as well as new a-arm design. Car should be on the scales in a few weeks.
Old Mar 6, 2015 | 08:39 AM
  #151
1BAD96's Avatar
Total Cats: 45
Little update. I plan on changing all the a-arms to our own design.
Subframes are all finalized and motor placement is finalized.
Should start moving pretty quickly now.
Attached Thumbnails Built Turbo F20C Time Attack Miata-fullsizerender_1_zpssdia6s6y.jpg   Built Turbo F20C Time Attack Miata-img_1615_zpsw1gdlu2q.jpg   Built Turbo F20C Time Attack Miata-fullsizerender_zpsi5spvxt7.jpg   Built Turbo F20C Time Attack Miata-fullsizerender_2_zpsaoefpidn.jpg
Old Mar 6, 2015 | 08:52 AM
  #152
Zaphod's Avatar
Total Cats: 106
This must be a wet dream coming true... Props given!
Old Mar 6, 2015 | 09:02 AM
  #153
pretty much custom from the ground up, but with x20 more awesome. also propped
Old Mar 6, 2015 | 09:44 AM
  #154
Total Cats: 1,870
Old Mar 6, 2015 | 10:06 AM
  #155
cyotani's Avatar
Total Cats: 117
I can't imagine hours have gone into this and how many more are still left to be done. I need a badass project like this in my life.
Old Mar 6, 2015 | 10:14 AM
  #156
1BAD96's Avatar
Total Cats: 45
NO, NO YOU DON'T.
This is the second shop, 3rd time down to bare chassis.
Going on 3 years.
Luckily I finally found a true and passionate fabricator that cares about his work. Too many hack shops out there.
Old Mar 6, 2015 | 10:29 AM
  #157
cyotani's Avatar
Total Cats: 117
NO, NO YOU DON'T.
Going on 3 years.
ya, you're probably right...
The fabrication work really is art on this car.
Old Mar 9, 2015 | 08:32 AM
  #158
OGRacing's Avatar
Total Cats: 33
if you could mail me that tubular rear subframe. that would be great. thanks.
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Originally Posted by Mobius
Old Mar 9, 2015 | 08:38 AM
  #159
1BAD96's Avatar
Total Cats: 45
Went up to take a look at the car this weekend and finalize some suspension items and other options! Looks like I will be upgrading to 17" wheels eventually. This is just the mock-up subframes as we are changing a few thing for the final subframe!
Attached Thumbnails Built Turbo F20C Time Attack Miata-img_1668_zpsyyfqvkkj.jpg   Built Turbo F20C Time Attack Miata-img_1669_zpsssix4vl4.jpg   Built Turbo F20C Time Attack Miata-img_1666_zpsdlguj5bu.jpg   Built Turbo F20C Time Attack Miata-img_1667_zpsv1ndxze5.jpg
Old Mar 9, 2015 | 11:35 AM
  #160
dcamp2's Avatar
Total Cats: 69
So rad.
I can't believe you have the patience to suffer through this project... It looks like it'll be worth it in the end.
