New Miata Junk 2 Intake
Old Sep 21, 2017 | 09:47 AM
  #101
Alternative's Avatar
Total Cats: -25
As soon as emilio and/or andrew give it a thumbs up -- it's going to sell like crazy.
Good chance they will not, I haven’t seen many positive review from either on something they didn’t develop.
Old Sep 21, 2017 | 09:48 AM
  #102
both of them use the flattop.
Old Sep 21, 2017 | 10:06 AM
  #103
Stealth97's Avatar
Emilio recommends the Racing beat 4-1 as the best current, OTS header for Rotrex/NA builds
Old Sep 21, 2017 | 10:10 AM
  #104
Or Skunk2 throttle bodies as long as you do the mods to make it reliable.
Old Sep 21, 2017 | 10:40 AM
  #105
Goingnowherefast's Avatar
Total Cats: 36
What's the OTS header? Sorry for the ignorance. Looking forward to 949's results.
  #106
k24madness's Avatar
Total Cats: 95
I was hoping for a slightly shorter one for track performance. How long are flat top runners? Look forward to seeing more dyno results.
I would not run it without a brace. I fought crack on mine without one.
Old Sep 21, 2017 | 10:47 AM
  #107
Steve Dallas's Avatar
Total Cats: 71
Off The Shelf.
Emilio also recommends the K&N intake as OTS and the Koyo Hyper-V radiator, should you not buy the SuperMiata CSF. The associated statement is patently undeserved.
Old Sep 21, 2017 | 11:15 AM
  #108
vteckiller2000's Avatar
Total Cats: 68
The cracking is likely irrelevant as this manifold is cast as one piece, not welded together. From what I recollect, the welding anneals the metal around the bead causing it to become harder and more brittle.
Old Sep 21, 2017 | 11:27 AM
  #109
Total Cats: 2,621
Shorter for less torque with a Rotrex?
I'll take long runners thank you. I thought I read a post somewhere that the runners are 10" on the Skunk2 (have not confirmed this myself). That's exactly the right length for this type of manifold. Gordon (trackdayhookey) did a bunch of testing with runner lengths and ended up within 1/4" of OEM with his 450whp Rotrex car.
It's a function of the displacement, RPM and cams. Peak power wins drag races. Area under the curve wins road races.
.33 SNR
Old Sep 21, 2017 | 02:12 PM
  #110
Originally Posted by yossi126
And regarding pricing on squaretop, the one I sold recently I got 300$ shipped for it. I would guess it would drop another 100$ if skunk will be even in performance.
lol looks like you're unloading your stash sooner rather than later, eh?
Old Sep 21, 2017 | 03:25 PM
  #111
Stealth97's Avatar
lol. If it turns out this manifold is junk they'll go back up. Anyone care to speculate on the intake manifold futures market?
Old Sep 21, 2017 | 03:26 PM
  #112
Engi-ninja's Avatar
Total Cats: 40
Just to clarify, it's the weld bead itself that is hard and brittle and prone to cracking. The heat from welding does anneal the material around the bead (known as the heat affected zone), but annealing makes a material softer and therefore weaker. Regardless, the effect is still the same. Welds are highly prone to cracking, especially in cantilevered joints like the Skunk IM.
That being said, I agree that the one piece cast design should be far less prone to cracking than the welded design, though not impervious. A poorly designed or poor quality casting can be prone to cracking too, especially in a high vibration situation.
Old Sep 21, 2017 | 03:38 PM
  #113
k24madness's Avatar
Total Cats: 95
I am not sure of my current honda skunk 2 runner length. It sure looks shorter that the 10" Miata one. I was hoping to keep the same length as it really works well with the rotrex. The torque curve I have is flatter (5k-7k) than I expected it to be with 99 head and rotrex. I agree area under the curve (5.5k-8k in my case) is what I want.
I followed Gordon's intake manifold work. He did go really short with one of em and made a peaky HP monster. I have no desire for that. If my current Honda skunk 2 is really 10" I'd be thrilled with this new Miata setup. Looking at the posted dyno it looks like HP was really starting to take off at 7k.
Old Sep 21, 2017 | 04:59 PM
  #114
yossi126's Avatar
Total Cats: -13
Haha, if test shows squaretop is on top then I win, but either way it's cheaper. The one I sold earlier this year simply reflects demand at the time, who knows.
Old Sep 22, 2017 | 08:33 AM
  #115
Mazdaspeeder's Avatar
Total Cats: 70
I have a square top that I picked up, was ready to port it for my skunk 2 TB but I will wait for results on these. Like some others said, it would have to perform a good bit better than a square top on a 300whp car for me to buy it. Prefer the look of the OEM one more than the bling and branded Skunk 2. I haven't had any issues with their Throttle Body, but apparently others have, so it kind of turns me off from the brand a bit. Not even sure what these issues are
Old Sep 26, 2017 | 03:47 PM
  #116
Lincoln Logs's Avatar
Total Cats: 64
Just showed up, don't think we'll have time to test and tune this before Miatas @ MRLS.
Looks pretty decent.
Weighing in at 10.1lbs.
Old Sep 26, 2017 | 03:48 PM
  #117
Total Cats: 1,870
Any way to adapt the stock brace?
Old Sep 26, 2017 | 03:54 PM
  #118
Total Cats: 36
Anyone got a stock intake manifold laying around they can weigh? Doesn't look too bad.
Old Sep 26, 2017 | 04:02 PM
  #119
Total Cats: 64
Won't know until we get in there, here is a shot of the bottom of it.
Going to weigh some here shortly.
Old Sep 26, 2017 | 04:10 PM
  #120
damir130's Avatar
Flat top manifold weighs 11.5lbs without a throttle body or brace.
