DIY - Raspberry Pi Racedash
Old May 31, 2017 | 05:48 AM
Barton's Avatar
Total Cats: 58
Just the standard NB gearbox sensor.
Old Jun 1, 2017 | 11:45 PM
Barton's Avatar
Total Cats: 58
Also if anyone is interested in inputting the fuel level signal into megasquirt you can use the following circuit. I tried just using a 5V pull-up resistor but the tank sender only goes from around 10-120 ohms so it doesn't give you a lot of resolution. This circuit just amplifies the small voltage difference into a much great ~0.5-4V signal.
Not the neatest but it works
Old Jun 5, 2017 | 05:35 AM
Barton's Avatar
Total Cats: 58
Turns out that the fuel sender resistance reading is a bit higher than I thought at the gauge cluster wire so the circuit I posted will need adjusting since it goes out of range and you end up with a fuel level reading that doesn't move till there's about 20L left in the tank. Will come back with the correct values once I do some testing.
Old Jun 9, 2017 | 02:13 PM
Teejay187's Avatar
Total Cats: 48
Those are great contributions Barton! For a few of the kits I have made I have been using a 90-0ohm fuel gauge. It seems to read pretty accurate.
I updated the Thingiverse page with parts for the NB as well. https://www.thingiverse.com/thing:2252864
Old Feb 6, 2018 | 10:52 PM
acedeuce802's Avatar
Total Cats: 175
Any update on the new resistance values?
Old Feb 7, 2018 | 07:37 AM
KilrSmrf's Avatar
Default Print cost
What would it cost to print one of these dash panels? I'm using a RaceCapture data logger and will be connecting a Raspberry Pi and screen to it rather than an Android tablet. This panel makes my life way easier!
Paul
Old Feb 16, 2018 | 07:59 PM
Barton's Avatar
Total Cats: 58
Sorry I haven't bothered changing the circuit yet. It functions fine to let me know when I need to fill up and an approximate fuel level but it needs a lot more smoothing of the signal since it moves a fair bit when going around corners etc. I think it really needs some software averaging to take care of that.
A mechanical gauge like what Teejay has been using is the easy solution.
Old Feb 16, 2018 | 08:24 PM
KilrSmrf's Avatar
You could try this, it's got dampening to prevent gauge bounce, it's what I intend to use for my Arduino.
ICM Fuel Sender
Old Feb 20, 2018 | 10:56 PM
Ben AZ's Avatar
I'm interested in doing this setup after I get the Megasquirt up and running (within the next 2 months). I do have a few questions. Car is a '91. Cars purpose is weekends/HPDE/nice weather cruiser.
Is this setup to use a GPS based speedometer, or would I have to get an NB VSS? I would like to also be able to have an odometer, but do not view it as a must.
Does this require any wiring into the factory harness other than the fuel gauge, or is everything straight from the ECU? I'd like to run LED's for blinker, high bean indicator, and parking brake light so I figured those were a given. I'm debating picking up an extra factory harness just in case.
How accurate is the 0-90 ohm fuel level gauge compared to stock? I haven't found the resistance values for the stock sending unit. I admittedly haven't looked very hard..
The car will be pretty well stripped of unnecessary circuits depending on how much of a pain in the *** that is as well. Car currently does not have ABS, PS, AC, or power windows. I will be removing the airbag system as well.
Any other tips from those that have this or a similar setup up and running?
Old Feb 26, 2018 | 03:39 AM
Barton's Avatar
Total Cats: 58
ICM Fuel Sender
Yeah but that's extremely expensive. I could easily just use an Arduio to read the raw input and then average that in software and send the averaged value out on a 0-5v analog output. Would cost next to nothing to do.
Old Feb 26, 2018 | 03:43 AM
Barton's Avatar
Total Cats: 58
It is possible to use a GPS for speed but I would strongly advise against it. You'll lose your speedo in tunnels etc. Using the NB gearbox sensor and a VR conditioning board is the best way to do it.
I am only using the factory wires for the fuel sender with mine for the moment although I do plan on wiring up LED indicators for the indicators etc.
You just stated the resistance values of the stock sender.... The stock gauge isn't hugely accurate anyway.
Old Feb 26, 2018 | 09:36 PM
WildKarrde's Avatar
Any guidance on getting Tunerstudio installed on Raspbian? I have been working on a project like this, but have very limited experience with Linux. I was able to get everything I want working, except Tunerstudio. =\
Old Feb 28, 2018 | 05:13 AM
BEAVIS's Avatar
Total Cats: 68
This should help you out with the install and setup process WildKarrde:
Old Aug 8, 2018 | 06:03 PM
iantboyd's Avatar
Total Cats: 7
Anyone have the dash bezel file? The links provided 404 on me.
Old Aug 20, 2018 | 10:48 AM
cj9694's Avatar
Total Cats: -15
I do! PM me with your email and Ill get them over to you. Do you have a printer that will make the parts? Ill exchange the files for parts made
Old Sep 16, 2018 | 09:43 AM
Barton's Avatar
Total Cats: 58
Just though I'd post some more info on the digital fuel level input. I realised (took me long enough) that the signal return for the fuel sender is grounded at the rear of the chassis with the brake lights, indicators and parkers which means when they're switched on it creates a voltage shift which is why the reading varies so much when they turn on. To get it to work properly you would need to move the signal return to the ECU signal ground.
Old Oct 23, 2018 | 10:38 AM
miatagirl's Avatar
Looking for the 3D printer file if anyone still has it???
Old Dec 26, 2018 | 10:10 PM
BigEasy's Avatar
Question about the set up of a Pi Dash with an MS3 basic, hoping that this thread would be the right place to post it.
Im planning on using ShadowDash to display on the dash, if my PiDash is pulling data from my MS3, do i need to disconnect the Pi Dash from the MS3 in order to connect to TunerStudio to do actual tuning on my computer? Not sure if i can have both connected simultaneously (one through USB output, one through the serial data output). Or do i need to disconnect the Pi Dash in order to connect to TunerStudio on my computer?
Old Dec 27, 2018 | 07:39 AM
Barton's Avatar
Total Cats: 58
Shadow dash only runs on android though? Is there an android OS available for RaspberryPi now?
As far as I am aware, yes you will need to disconnecet the dash in order to connect another device to the MS.
Old Dec 27, 2018 | 01:02 PM
BigEasy's Avatar
Sorry about that, will be using a dashboard in Tunerstudio on it. You are correct that Shadow dash runs on Android OS.
That is what i assumed, but wanted to double check if anyone else that has already done this knew for sure. Most likely going to try and use some sort of USB switch to make it cleaner than having to unplug and plug the wires to the different devices when I want to switch.
