Dorman 610-416 longer wheel studs
Old May 2, 2019 | 04:01 PM
Landrew's Avatar
Total Cats: 29
Default Dorman 610-416 longer wheel studs
If you are looking for longer REAR wheel studs these work.
Dorman 610-416
They have a 14.86mm knurl (OEM 14.94mm) and are 52.2mm long (OEM are 41mm long) but the last 3mm are not threaded.
You get a genuine 8mm more threads or enough for varied width of spacers. Around $2 CDN each so cheaper than ARP and easily stocked.
They went in very tight and the rotor does need a slight tap to seat.
Old May 2, 2019 | 04:08 PM
Landrew's Avatar
Total Cats: 29
I'm trying the 610-323 in the front that have 0.129mm less knurl diameter but are 12mm longer. Won't be installing those for a few weeks.
soviet
Mar 31, 2015 11:48 AM
hustler
29
Jun 26, 2013 11:45 AM
Nate99
Wheels and Tires
35
Sep 28, 2011 09:12 PM
rider384
Jun 15, 2010 10:56 AM
Cspence
11
Mar 6, 2010 11:52 AM
