Road Race Project
Old Jul 7, 2010 | 10:46 PM
Call me when the stock calipers **** the bed. Nice build.
Old Jul 7, 2010 | 10:52 PM
shlammed's Avatar
Total Cats: 51
most sanctioning bodies only allow 4 bends in the rollbar main hoop.... you have 6.
Besides that, i like the build... very along the lines of something i would do.
Old Jul 7, 2010, 11:38 PM
This message has been deleted by Braineack. Reason: cleanup
Old Jul 7, 2010, 11:48 PM
Old Jul 7, 2010, 11:51 PM
Old Jul 8, 2010, 02:05 AM
Old Jul 8, 2010 | 02:37 AM
turotufas's Avatar
Total Cats: 7
Awesome. Which tracks do you plan to race at? I didn't see a location,
Old Jul 8, 2010, 07:27 AM
Old Jul 8, 2010 | 08:50 AM
Originally Posted by buffoon01
With a 3076?
It probably has a tiny turbine housing.
Old Jul 8, 2010 | 09:14 AM
webby459's Avatar
With the right fueling this combo is win. Not everyone goes down to the local Mobil to buy 91-93.
OP, what are you fueling with? In for plots when you get them.
Old Jul 8, 2010 | 09:34 AM
m2cupcar's Avatar
Total Cats: 372
Great build IMO. Though I'd put the door bars out to the door skin and ditched the interior panels IF I was going to compete in this car.
To shlammed's point- it pays to build/prep for safety following an established sanctioning body's guidelines per their rule book. I've seen similarly built car/cage get denied at a regional. Safety is really the primary concern when getting a log book.
re: lap times
Personally I cut my quickest laps when I'm competing. So throw me out at a track (HPDE) event and I'll run 2 seconds a lap slower. I know when I put my current street Miata on the track I won't come close to pushing like I do an ITA/Spec Miata. My guess is the same thing holds most back when tracking their project cars. It's balancing act- saving a second or two off a lap time at a far greater risk of wadding up a lot of work. Also need to consider that lap records in Spec Miatas are exactly a "stock" Miata- not when a front running example is $30-40k turn-key new from a builder.
Old Jul 8, 2010 | 11:07 AM
PSI2HI's Avatar
straightlinespecialties
Turbine housing is a TIAL .63AR
Located in the Midwest so will run @ BIR, Mid America, and possibly Road America. We have a handful of customers we work closely w/ that run the RTA series tuhs was the motivation behind this build but since they have moved the majority of the events down on the lower west coast idk that that will happen anymore.
The thoughts crossed my mind of going full blown race build and gutting out the doors and such but i decided for this build to be able to keep it a little more subtle and be able to keep the panels/windows etc thus being able to take it out on the streets and screw around. I have another chassis that suites better for a completly gutted/cut up project that is not in nearly as good a shape as this one.
Fueling is done w/ Walbro 255HP, ID 1000's on E85.
Old Jul 8, 2010, 11:11 AM
Old Jul 8, 2010, 11:12 AM
Old Jul 8, 2010, 11:21 AM
Old Jul 8, 2010 | 11:27 AM
Splitime's Avatar
Miotta FTW!
Total Cats: 31
Originally Posted by Feus
Good job, you still have a bit to go before you beat the a spec miata (non-turboed) times
Guess what... i was NOT running a turbo... and it was my first time EVER out on Full course and EVER running the car naturally aspirated.
My turbo times are already well below SM times. Thanks for playing though.
Old Jul 8, 2010 | 11:31 AM
Splitime's Avatar
Miotta FTW!
Total Cats: 31
Originally Posted by chris101
Nicely done! I still have more learning to do myself. My best time as a Spec Miata is 2:57.816 on the full track. Meanwhile, Brian Domont holds the current NASA full track spec miata record with a 2:51.996. (yup, I have a ways to go before I can hope for a podium finish on the full track :( )
Were you running 205 50 15 Toyo RA1 tires too? I was able to get better lap times with 205 50 15 hoosiers for an HPDE day but then it isn't technically a spec miata any more
By any chance are you running spec miata suspension? When you were running in NA form, is your engine totally stock (no overbore pistons or other engine or exhaust mods)? Do you also know what weight you are at? (curious to know if you are under or over spec weight with your very respectable times)
From the sounds of it, you'd have a good chance of getting to the podium if you ever decided to try w2w racing with a Spec Miata with such a great 1st time your fist session running NA on the full track!
Last year weight was 2144, this years should be just hair lower without passenger seat.
Suspension is revalved bilstein and 750/400, front bar and no rear. So its close.
Motor is 100% stock, 96k on the clock. Borrowed obx header/oem cat. My custom intake manifold that is all likelyhood is hurting me due to it all breathing through a giant Intercooler... worst intake tract ever.
225/nt01, so almost a 205 RA1, basically the same tire. That is also with hefty cheap wheels and what not also.
Old Jul 8, 2010 | 11:34 AM
PSI2HI's Avatar
um... Do you plan on driving a fully caged miata in the street? Were you planning on wearing a helmet when driving in the street with that cage around you? It isn't exactly wise (or safe) to drive 'in the streets' on a normal basis fully caged like that
I said take out and screw around, not daily drive. This project is a "toy" and will be treated as such. The car as is only has 45k on it and its a 90.
Old Jul 8, 2010 | 03:55 PM
Total Cats: 4,368
I hate having to clean up threads...
Old Jul 8, 2010 | 05:20 PM
ok
Old Aug 2, 2010 | 11:04 AM
PSI2HI's Avatar
First round of tuning 20psi on E85:
Old Aug 2, 2010 | 11:07 AM
Bond's Avatar
What gearing and trans are you running
Old Aug 2, 2010 | 11:59 AM
PSI2HI's Avatar
4.10/5spd
Old Aug 2, 2010 | 01:42 PM
jtothawhat's Avatar
Great power, awesome build...what was your duty cycle on the E85 and ID1000's?
Old Aug 2, 2010 | 02:31 PM
Originally Posted by PSI2HI
4.10/5spd
That should last a lap or two.
Old Aug 2, 2010 | 04:44 PM
NA6C-Guy's Avatar
Total Cats: 44
Maybe it will be one of those magical 5 speeds that holds up fine, forever. I wouldn't plan on it though.
Awesome build, and awesome numbers. It probably goes through the gears in the blink of an eye with 4.1 rear.
Old Aug 2, 2010 | 05:37 PM
PSI2HI's Avatar
Running a fairly taller rear tire so the gearing as isnt to bad. 3rd gear graph was ran out to 7k, 4th gear was ran out to 7500rpm.
Old Aug 2, 2010 | 06:00 PM
ftjandra's Avatar
Total Cats: 8
I'd like to know this as well.
Thanks,
--Ferdi
