Boost Addicts SR20det engine conversion
Old Dec 16, 2010 | 12:25 PM
Probably not since the DET never made it to the US.
I'm actually a bit curious about a KA-T setup on a miata now that we're talkin nissans: 2.4L, tons of torque, and its really not expensive or hard to build one up. I've seen plenty of 400whp KA-T cars around here, and those engines are dirt cheap. even cheaper than the BP
Old Dec 16, 2010 | 12:26 PM
Total Cats: 4,370
I have a KA24DE. it's burning oil and I cant find the source.
Old Dec 16, 2010 | 12:27 PM
just buy another one for like 30 bux lol
Old Dec 16, 2010 | 12:31 PM
chriscar's Avatar
Total Cats: 16
Originally Posted by hustler
Can you get parts for this engine at the neighborhood parts store?
Most of the parts are the same as a FWD SR20, so effectively, yes. And some of the turbo bits can be found on the 300ZX. But realistically, what are you going to buy at the parts store anyway besides spark plugs and maybe hardware.
C
Old Dec 16, 2010 | 12:46 PM
Boost_addict's Avatar
I'd say that's dependent. Still lots online though.
Old Dec 16, 2010 | 12:50 PM
Remember the ka24 is an iron block. I bet the sr20 with it's turbo hardware comes im about the same weight as the bp.
Old Dec 16, 2010 | 12:52 PM
chriscar's Avatar
Total Cats: 16
The SR20 also has ALLOT more aftermarket support than the KA, and the DET came boosted from the factory, so it has things like piston squirters, sodium filled valves, and slightly lower compression.
Drool - http://www.mazworx.com/
C
Old Dec 16, 2010 | 02:43 PM
Alright guys, starting welding in 1:15 mins. Just going with a 4"x4" 2" tall box around the pickup with drainage area underneath. Any better ideas?
Old Dec 16, 2010 | 02:45 PM
Splitime's Avatar
Miotta FTW!
Total Cats: 31
Easy example with lots of pics.
http://www.jhpusa.com/store/pc/viewP...idproduct=7069
Old Dec 16, 2010 | 02:55 PM
CPSmith's Avatar
Good luck with your build. In for lots of pictures
Old Dec 16, 2010 | 03:31 PM
C
Sensors and seals. I own a 20-year old Miata, things like this are important to me.
Old Dec 16, 2010 | 03:39 PM
wildfire0310's Avatar
70+% maintenance parts for the SR are the same between the DE and DET. The parts that are different are the few parts an auto-parts store doesn't carry for boosted cars to start with.
The only issue I see so far with the oil pan is that is looks like it doesn't slope back towards the pick-up tube.
Old Dec 16, 2010 | 03:40 PM
paNX2K&SE-R's Avatar
Total Cats: 24
Boost_Addict, how making a 2nd copy of everything and selling it to me?
Old Dec 16, 2010 | 03:44 PM
chriscar's Avatar
Total Cats: 16
^ what he said. My Miata would be happy with a DET drivetrain,
C
Old Dec 16, 2010 | 03:50 PM
chriscar's Avatar
Total Cats: 16
Modifications are more likely to break than OE parts, so I don't know why you're concerned about this.
It's a simple OBDI engine, so for sensors you have WT, o2, knock and cam sensor, which are all the same as a FWD DE except for the cam sensor. Seals? Valve cover, and a few o-rings maybe. Nothing you couldn't easily keep in stock.
Ok, I thought of ONE thing - coil packs.
C
Old Dec 16, 2010 | 03:51 PM
Total Cats: 24
C
Hell yeah! I still have that sweet rwd O2induction intake manifold and Boost Logic equal length exhaust manifold/wategate/downpipe setup that I bought before deciding to go LS1 on the S13. I'd love to put it on a Miata.
Old Dec 16, 2010 | 04:46 PM
C
you are a bitch, here is a list of **** that's broken on my car recently that makes me consider / worry about that crap:
  • water temp sender plastic cracked and won't hold the contact
It's a pretty long list as you can see.
Old Dec 16, 2010 | 04:47 PM
twail's Avatar
I was going to do this conversion before I decided to just turbo the 1.6.
Over here in Ireland there are endless amounts of sr20's, and aftermarket go fast bolt on bits! All for cheap.
The only reason I didnt do it was because it as going to be a pain in the *** to fab up a sump! But seeing as you work in a machine shop and have access to all the tools, and obviously have the skills, then I think its a very good alternative to turbo'ing the original lump.
The SR is a great engine, and very very tunable, with bolt on bits you could see 400bhp easy.
Good look with the build, and keep the updates and pictures coming.
Old Dec 16, 2010 | 04:50 PM
longer than your ****
Old Dec 16, 2010 | 04:55 PM
chriscar's Avatar
Total Cats: 16
Ok, you're right. This isn't the swap for you.
C
