Project Cheap
Old Apr 4, 2012 | 06:02 PM
  #261
UnknownPerson's Avatar
That thing is awesome. So, just how cheap is project cheap at this point?
Old Apr 4, 2012 | 06:42 PM
  #262
Faeflora's Avatar
Total Cats: 130
Needs mkre zip ties. Also needs more of mu caulk in you
Famnit i am drunk
Old Apr 23, 2012 | 10:21 AM
  #263
Techsalvager's Avatar
Old Apr 23, 2012 | 10:25 AM
  #264
costly not cheap
if I were to redo it
I wouldn't of gotten a megasquirt, I would of saved for better EMS
better turbo manifold or ran the turbo in the rear.
I would of stayed with 2inch piping all around.
Old Apr 23, 2012 | 10:40 AM
  #265
hangs a bit low
Old Apr 23, 2012 | 11:00 AM
  #266
Jeff_Ciesielski's Avatar
Total Cats: 31
I don't mean to thread crap, but god damn I'm tired of hearing that.
I'm not saying that MS is _the best_ by any stretch of the imagination, but what makes you think that with a 'better' ECU you'd stand to gain anything with a setup like yours?
Old Apr 23, 2012, 11:15 AM
This message has been deleted by Braineack.
Old Apr 23, 2012, 11:36 AM
Old Apr 23, 2012, 11:47 AM
Old Apr 23, 2012, 11:53 AM
Old Apr 23, 2012, 11:59 AM
Old Apr 23, 2012, 12:10 PM
Old Apr 23, 2012, 12:13 PM
Old Apr 23, 2012, 12:14 PM
Old Apr 23, 2012, 12:21 PM
Old Apr 23, 2012 | 01:11 PM
  #267
many reasons, it can be made to work, it just its lacking certain items I perfer to see for a daily driven unit.
error outputs\codes
limp home strategies
sensor fail safes, in case a sensor takes a ----\dump.
features that are said to be in there but are half done or need more work to them.
I've had a GM IAT sensor fail on me that I was using and it just made the ecu dumb ---- tons of fuel because of how the ideal gas law code is configured which I disagree with as well. I don't disagree with the physics of it, just that there is so much more to an engine. the fact that will take out fuel non stop above 80f~ can be determintal to an engine, esp a F\I very quickly if people aren't aware about it, which seems a lot that start tuning and buy these things aren't. Of course there are lot of people that want something on the cheap. I was one, I learned, I realized, forum poltics among other things.
Also its not open source despite what people like to think of it as.
Also the data logging speed is bit all over the place ( ms2extra ) using tunerstudio
and my inputs were limited for ADC's
if\when I were to get another ecu I like to see at least 100hz logging.
For a daily driven car to me I'm really not excited about it.
for a track car I"m not sure I would want it controlling my setup, esp without sensor bounds in case a sensor fails.
With what I want to do I have to keep adding to the systsem, over time I might as well just gotten a system that could of done what I want with no more additions needed.
Heres an example I have a complete 16x16 table that is entriely useless to me in the current state. It sits there doing nothing filled with 100s
Also the closed loop AFR target table is shared with the main fuel map.
so you can't use wide band closed loop unless you share it with the fuel map.
And if you use incorprate AFR target the closed loop map shares itself with the commanded AFR map for the main fuel ve table under speed density.
Which say if you just cruising around and lightly accelerating you may want to keep stoich into boost 2-4psi or so depending on engine setup and turbo, but if you want to get on it you want to drop out of closed loop to your main commanded fuel map. Which can't be done using wide band closed loop operation. You can do it with narrow band CL operation though.
Old Apr 23, 2012 | 01:15 PM
  #268
this I absolutely agree with.
Old Apr 23, 2012, 01:20 PM
Old Apr 23, 2012, 01:24 PM
Old Apr 23, 2012, 01:29 PM
Old Apr 23, 2012, 01:30 PM
Old Apr 23, 2012 | 01:40 PM
  #269
Total Cats: 31
I'll bite on the sensor failsafe / limp home mode. I've had an IAT come unplugged while driving and it was a bad experience for sure (obviously my bad on that one).
Old Apr 23, 2012 | 01:41 PM
  #270
rb26dett's Avatar
Total Cats: 92
It's great to see the progress in understanding that you've made over the years, Hentai! Keep up the good work :-)
Old May 1, 2012 | 05:39 AM
  #271
triple88a's Avatar
Total Cats: 1,830
This is how I see this thread :P
Attached Thumbnails Project Cheap-540285_10151598905470377_212641675376_23856046_2147170116_n.jpg
Old May 4, 2012 | 09:15 PM
  #272
Old May 6, 2012 | 12:10 PM
  #273
happy and sadden at the same time.
My first test of the AEM AQ-1 for the accelerometers.
Old May 13, 2012 | 05:16 PM
  #274
Old May 13, 2012 | 05:32 PM
  #275
Oscar's Avatar
Total Cats: 120
Every time this thread gets updated, I expect to see pushrods, carbs or a distributor have found their way onto the car
Old May 13, 2012 | 06:06 PM
  #276
Pen2_the_penguin's Avatar
Total Cats: 97
dont forget spikes and steel body panels like it was straight out of a post apocalyptic movie.
Old May 13, 2012 | 06:18 PM
  #277
I'm starting to wish I had a MAF on my cars...basically anything that gets me closer to GM style engine management.
Old May 13, 2012 | 06:28 PM
  #278
Oscar's Avatar
Total Cats: 120
Why? Elaborate. We're not too familiar with GM over here.
Old May 14, 2012 | 05:34 AM
  #279
Noxiousb4c's Avatar
Total Cats: -2
I liked tuning my MAF equipped NA LS1.
Old May 14, 2012 | 06:39 AM
  #280
chpmnsws6's Avatar
Funny. A bunch of us ditch them and just run SD.
