AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering
Old Jan 25, 2013 | 06:52 PM
Total Cats: 2,106
Default AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering
I'm a big fan of Amsoil fluids, and I use them almost universally in both of the race cars, but a lot of members probably don't know that I'm also an Amsoil dealer. I can get their entire line of fluids and greases, but I stock a few particular items that seem to work the best in Miata-specific applications. I've used and tested plenty of alternatives and always end up coming back to Amsoil.
Contact me via email or PM for a quote on AMSOIL products. I stock individual quarts, and I can give a larger discount for case-quantity purchases (12/case).
AMSOIL MTG - Manual Transmission Gear Lube (75w90 GL4)
This is the go-to transmission fluid for both 5-speeds and 6-speeds. Smooth shifting when cold, butter smooth when hot, and able to cope with the extremely high transmission temps that most track cars see. 2 quarts will fill a 5-speed+turret or a 6-speed.
AMSOIL SVG - Severe Gear Lube (75w90)
Perfect for OEM Torsen LSDs. I've tried other synthetic fluids, and nothing can beat Severe Gear's ability to hold up to the high fluid temps seen on track. 1 quart will fill an OEM differential (1.6 or 1.8).
AMSOIL Dominator 15w50
AMSOIL Dominator maintains adequate oil pressure even in cars without oil coolers. Back-to-back tests between popular diesel-spec oils and Dominator showed a 10-15psi increase in oil pressure when hot, which was enough to convince me to switch.
AMSOIL 2000 GRG Race Grease
Perfect for brake slider pins, wheel bearings, and anything else that needs a high-temp general purpose grease. Won't burn or separate like other popular greases.
Attached Thumbnails AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering-nntisfzm.jpg   AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering-dqwirggm.jpg   AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering-yqfb6p8m.jpg   AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering-iwfejium.jpg
Old Jan 17, 2015 | 09:18 PM
EO2K's Avatar
Total Cats: 1,924
Another happy customer here. I'm on my second or third Amsoil order from Trackspeed.
Attached Thumbnails AMSOIL Trans/Diff/Motor Oil/Grease at Trackspeed Engineering-phone-pics-035a.jpg
Leave a poscat 1 Leave a negcat
Old Jan 17, 2015 | 10:08 PM
Total Cats: 2,106
Stocked up for the new year. 10w30 and 15w50 Dominator, SAE30 Break-in oil, SVG diff and MTG tranny fluid all in stock. Also have engine assembly lubricant and 2000 Race Grease.
Old Jan 21, 2015 | 04:20 PM
aidandj's Avatar
SADFab Destructive Testing Engineer
Total Cats: 1,870
PM'd
Old Jan 21, 2015 | 04:34 PM
Chiburbian's Avatar
Total Cats: 204
What amsoil product would you recommend for engine oil in a turbo daily? I am running Rotella T6 but I am reading more and more that this is not really a good choice. What weight?
Old Jan 21, 2015 | 04:49 PM
curly's Avatar
Cpt. Slow
Total Cats: 1,412
I'd love to hear reasons why the T6 isn't good? And I'm interested in Andrew's input.
Andrew: too lazy to look, do you carry the motorcraft trans fluid for the 6-speeds?
Old Jan 21, 2015 | 05:01 PM
Chiburbian's Avatar
Total Cats: 204
From a facebook group - take it for what it's worth:
Diesel Oil ?Lab Test? and ?Wear Test? Results ? Speed Talk
Stephen Carr
on my car you literally could feel it break down after a single autocross event. I did some "grassroots" testing by taking samples of new, daily use (about 2k miles), and after an autocross. and the new and daily use use had a noticable difference (I swished them around glass tubes, to see how well they flowed) and then the after an autocross tube was like water... ok not THAT bad.. more like extra virgin olive oil.it felt thin to the touch, etc. and visibly was thin.
and the "after an autocross" was changed on friday, raced on sat and then again on sunday, and a sample pulled on sunday after the event. so it was about... 25 miles total.
hard use destroyed it.
but like I siad, think about what it is engineered for: low heat, low RPM vehicles. not high heat, high RPM vehicles.
Basically it seems that it seems to break down at a very low temperature and while it may protect your engine well when you first put it in, it won't protect it well for long. I am interested to hear other's opinions.
I for one don't have the trust in T6 that I used to.
Old Jan 21, 2015 | 06:33 PM
Total Cats: 2,106
I stock Dominator 10w30 for stock engines and Dominator 15w50 for built engines.
Old Jan 21, 2015 | 06:51 PM
Chiburbian's Avatar
Total Cats: 204
Perfect, thanks!
Old Jan 21, 2015 | 07:22 PM
EO2K's Avatar
Total Cats: 1,924
No Blackstone UOA, No care.
Leave a poscat 2 Leave a negcat
Old Jan 21, 2015 | 07:49 PM
curly's Avatar
Cpt. Slow
Total Cats: 1,412
So, he had a bunch of water or gas in his oil. That tells me nothing.
Old Jan 22, 2015 | 12:00 PM
Girz0r's Avatar
Moderator
Total Cats: 323
This^
I'm also on the T6 kick. I have yet to beat on the car but it's been great as a DD go to oil (cheap refills, trubo sappin may oil) But I too would like a better opinion.
Old Mar 31, 2015 | 11:29 PM
wannafbody's Avatar
Total Cats: -369
Any reason to not use MTG as a rear diff fluid, as it's a 75w90 fluid.
Old Apr 1, 2015 | 02:22 AM
Schuyler's Avatar
Total Cats: 87
Originally Posted by Girz0r
This^
I know SOMEWHERE I have seen a blackstone report where they guy ran amsoil dominator and rotella T6 in his car and sent both samples to blackstone, then photoshopped them side by side showing the strengths/weaknesses of each. I can't seem to find it now though.
Old Mar 11, 2016 | 08:45 PM
Girz0r's Avatar
Moderator
Total Cats: 323
Sav, contemplating an order from you.
Previous posts you said 10w30 for stock and higher for built. Would this be race motors on the higher weight?
I just DD my built motor but would like to see how amsoil handles with my BE oil pump +1 shim. Currently I've been running castrol gtx 5w30, other option is mobile1 0w40 but I'd like to see how amsoil runs. If it's anything like going from redline to amsoil mtg in the trans, I'm sold.
Old Mar 12, 2016 | 02:19 AM
Total Cats: 2,106
If you've been using 5w30 in the engine and you're happy with the oil pressure, 10w30 is fine. For some mega-power built motors with big bearing clearances, the 15w50 is a better option, but for stock-ish clearances, the 10w30 is good.
Old Mar 24, 2016 | 12:42 AM
slug_dub's Avatar
Total Cats: 40
Is this particular Amsoil grease the equivalent these days to the 2000 GRG race grease mentioned in the original post?
Old Mar 24, 2016 | 12:52 AM
Total Cats: 2,106
Yes, Dominator is the new name for their 2000 grease.
Old Apr 16, 2018 | 10:09 AM
ridethecliche's Avatar
Total Cats: 146
I saw the GL-4 transmission fluid on your site, but had recently been told that they're getting rid of it and moving to a GL-5 version that's safe on bronze transmission parts. Do you know if there's any truth to that?
Old Apr 17, 2018 | 01:45 PM
Total Cats: 2,106
No, there is no truth to that.
nick470
7
Jun 16, 2017 01:53 PM
90 Turbo
19
Oct 19, 2015 03:23 PM
