Old 06-05-2017, 08:33 PM
  #9941
Total Cats: 553
sonofthehill is offline
Old 06-05-2017, 09:01 PM
  #9942
mmmjesse's Avatar
Total Cats: 44
haha. pat says your a B and need to up it.
but seriously, this car has so much left in it. its time for 15psi on the street.
mmmjesse is offline
Old 06-05-2017, 09:08 PM
  #9943
I have. No reason to push past that without a dyno.
Old 06-05-2017, 10:05 PM
  #9944
patsmx5's Avatar
Total Cats: 490
Originally Posted by 18psi
Pat would call that "vacuum"
I remember when I ran 30lbs of boost.
patsmx5 is offline
Old 06-05-2017, 10:14 PM
  #9945
Did you miss this?
Old 06-05-2017, 11:38 PM
  #9946
Total Cats: 1,149
Originally Posted by aidandj
Highest EGT on the street i've seen was like 1250. Even at 15+psi.
Track I'm seeing 1450 at 5-7psi.
Great data point for track driving. Street/drag is just a different world. Even at 5psi, throw the keys to Eddie and he'll break **** in 3-4 laps.
curly is offline
Old 06-06-2017, 12:21 AM
  #9947
I'm pretty solid at breaking **** myself.
Found a pair of 800lb front springs. Still hunting for 500lb rears. These vr1s seem to have more grip than the rs3s I had before.
I'd like to get a bit more out of the car before I turn up the power. Maybe catch up to @stormin'norman with a 1:28.* Or something
Old 06-06-2017, 02:35 AM
  #9948
Lexzar's Avatar
Total Cats: 41
Just wanted to ask about your opinion on the vr1 as a street tire with good power (lots more than I'll have for a while)
Lexzar is offline
Old 06-06-2017, 05:58 AM
  #9949
Total Cats: 857
Just now got to my tune. Yeah, quite retarded. Especially at high RPM's. Disclaimer: I have no Det cans. That said, I went to a map that keeps increasing advance from 4000 up to 7500, and found that I could pull fuel up there, using pulls (not steady loading). It will be very interesting how your map looks after dyno. I am guessing you will add timing and then need to retouch fuel.
EDIT: I looked at log. You are also running super rich up there. IIRC, 11.5 target, 10.4 actual.
Last edited by DNMakinson; 06-06-2017 at 06:13 AM. Reason: Added Picture and AFR comment
DNMakinson is offline
Old 06-06-2017, 08:49 AM
  #9950
245 vr1 has more straightline grip that a 225 rs3. That's all I really know right now.
Yes I'm running very rich. Helps with egts, keeps knock away, and again, I haven't had time to go to the dyno.
Old 06-06-2017, 12:18 PM
  #9951
Total Cats: 857
I'm thinking that the low advance coupled with rich mixture is helping with knock, but increasing the EGT. That's all I'm saying. Theory is that some of the mixture is burning in the manifold. Looking forward to dyno results.
Old 06-06-2017, 12:21 PM
  #9952
Rich is probably helping with EGT. Lean burns hotter.
I'm not surprised at all about the high EGTs. They are expected with a map this retarded.
I bet if I pulled fuel the EGTs would go up.
Old 06-06-2017, 04:49 PM
  #9953
nbfather's Avatar
Thumbs up
That is some serious torque to MPH so quickly!
Any thoughts on when you will be getting it on a dyno?
The EGTs on that 25 PSI run must have been up there with your current timing?
Nice to have that information isn't it!!??
I am always blown away when I see a turbo car without an EGT gauge....IMHO literally running blind.
The car is a beast aidandj !
nbfather is offline
Old 06-06-2017, 05:06 PM
  #9954
I need to get VVT fixed before I hit the dyno. EGTs aren't horrible on single pulls. Its the long continuous pulls that really hurt.
I have a warning set at 1600*F, and I've never hit it.
Old 06-06-2017, 06:19 PM
  #9955
Total Cats: 3,019
Oil vapor causes detonation. I'm glad you aren't being risky.
sixshooter is offline
Old 06-06-2017, 06:46 PM
  #9956
lol you know how I know you're old?
Old 06-07-2017, 12:02 AM
  #9957
Padlock's Avatar
Total Cats: 563
ignorance is bliss
you dont need a boost gauge either if you have big enough *****
Padlock is offline
Old 06-07-2017, 12:36 AM
  #9958
Total Cats: 856
Originally Posted by Padlock
ignorance is bliss
You aren't going to stare at a boost gauge while on track -- they're really tuning tools, not driving tools. Given that context, no, an analog boost gauge isn't particularly useful, the MAP sensor in the ECU (being displayed on your laptop in TunerStudio while tuning) is actually a lot better..
codrus is offline
Old 06-07-2017, 12:38 AM
  #9959
Personally I've found that gauges are useless for me on track. Warning lights only.
Old 06-07-2017, 12:53 AM
  #9960
ignorance is bliss
What do you actually use a boost gauge for?
