Please not another crankcase ventilation thread.
Old 07-26-2017, 01:03 PM
  #201
kero's Avatar
Total Cats: 8
Originally Posted by Ryan_G
Are you running an efr? How big is your drain line?
No on the EFR. We actually have 2 cars with similar issues.
Both B6 with Chinachargers.
Car A
Motor rebuilt 3000 miles ago, 180ish compression
T3 turbo with .48 a/r hotside
Oil feed restrictor (not sure on size, looks about a 1/16th)
5/8 ID hose for the drain
3/8 hose from PCV to catch can
3/8 hose with check valve from intake to catch can
Air filter/breather on the exhaust side VC port
Around 17psi of boost
Car B
Motor rebuilt a few hundred miles ago, compression in the 180s as well.
GT2871 Churbo
No restrictor
3/8 hose from PCV to catch can, vented
Around 18-19psi of boost
So more or less similar setups, but both cars have an issue with smoking after boost, due to excessive crankcase pressure is my theory. I think enlarging the holes on the VC is the way to solve this, but I am not sure. Input?
oil
Oil seal, piston ring seal on the shaft, whatever you want to call it.
kero is offline
Old 07-27-2017, 10:43 PM
  #202
kero's Avatar
Total Cats: 8
Went ahead drilled out a spare valve cover.
Exhaust side baffle before
Enlarged to 1/2" and added another hole connecting to center baffle
Drilled and tapped exhaust side port with 3/8" npt, installed 5/8" hose barb fitting
The cover had a crack in the front as it came out of a wreck
Chopped it, tapped PCV hole with 1/2" npt
Cleaned it and reinstalled the baffles
Primed, ready for paint tomorrow
kero is offline
Old 07-27-2017, 11:11 PM
  #203
Bronson M's Avatar
Total Cats: 217
Here's my slightly different approach to the same thing.
I drilled out the existing baffle hole to 3/8" and added a second.
I plugged the passenger side and used the factory driver's side nipple to a simple vented catch can. I've never had to drain the catch can. I honestly think the the steel wool I used is the key. It's the coarse ribbon type and I only had it in part of the first chamber to give the oil mist something to collect on
Bronson M is offline
Old 07-27-2017, 11:22 PM
  #204
kero's Avatar
Total Cats: 8
I thought about those scrub things but i decided against it incase the oil would start to break it down. I figure ill stuff that in the oil catch can instead
kero is offline
Old 07-27-2017, 11:25 PM
  #205
Bronson M's Avatar
Total Cats: 217
There's reports of the actual steel wool breaking up and going through the engine, it's more like hair. The stuff I used is the 1/8" wide ribbon, it's not breaking up.
Old 07-27-2017, 11:30 PM
  #206
kero's Avatar
Total Cats: 8
Yea i have that same ribbon stuff that i used on my can before.
Anyway, were you having issues before this or just preemptive?
Also, what's the theory behind capping the passenger side? And why not the driver side? Why not can on one, and filter vta on the other?
kero is offline
Old 07-27-2017, 11:48 PM
  #207
Bronson M's Avatar
Total Cats: 217
This was preemptive since I was adding the turbo. This is also a "race car" in that I didn't care if I needed to change the oil often as my street driving consisted of tuning and the odd trip to work.
In my application the flow is simply around the rings and out the valve cover. I was not introducing oily air to the intake tract. The driver's side baffle was two chambers so I just went with that side and planned to expand if I saw signs of crankcase pressure. So far I've seen no evidence of a problem other than the oil smells of fuel in 3k miles. Normally my track days are less than a 1000 miles apart so it's a non issue.
For a street car I would add the pcv back in the factory config but switch to a PCV that sealed under boost. The flow on the driver's side would be into the valve cover under cruise and out under boost.
Old 07-28-2017, 08:59 AM
  #208
ryansmoneypit's Avatar
Total Cats: 456
I cringe every time I see real steel wool being used. Copper is easy to find and a lot easier for your engine to eat, if it did.
Passenger side is the side of the valve cover that oil can pool and have a hard time draining. Using it often results excessive oil consumption/caught in catch can.
ryansmoneypit is offline
Old 07-28-2017, 10:48 AM
  #209
kero's Avatar
Total Cats: 8
So would i be better off venting that side and putting catch can on the driver side?
kero is offline
Old 07-28-2017, 11:40 AM
  #210
Bronson M's Avatar
Total Cats: 217
Depends if you're going to hook up manifold vacuum to the catch can and you're ok with the passenger side vent slobbering all over the motor.
Old 07-28-2017, 01:46 PM
  #211
kero's Avatar
Total Cats: 8
My plan originally was to use a filter on the driver side and catch can hooked up to intake manifold through check valve on passenger side
kero is offline
Old 07-28-2017, 01:58 PM
  #212
Total Cats: 3,019
Well, that's not going to work. It's a permanent vacuum leak
sixshooter is online now
Old 07-28-2017, 06:53 PM
  #213
kero's Avatar
Total Cats: 8
How is that any different than the stock pcv hooked up to mani? I will have a check valve to prevent boost entering the crankcase
kero is offline
Old 07-28-2017, 07:29 PM
  #214
Total Cats: 857
Google for information on PCV systems and you will see that the valve prevents and/or limits flow in either direction depending on conditions. Check valve does not do that.
DNMakinson is offline
Old 07-28-2017, 08:26 PM
  #215
kero's Avatar
Total Cats: 8
I really thought a PCV valve was just a check valve. I didn't consider the limiting flow factors, i guess i can just run the pcv inline instead of the check valve
kero is offline
Old 07-28-2017, 08:27 PM
  #216
Run both
Old 07-28-2017, 09:07 PM
  #217
kero's Avatar
Total Cats: 8
I think that's the best idea. Going to install the new cover tomorrow, we'll see how it does.
kero is offline
6strngs
10-27-2015 01:16 AM
gesso
10-23-2015 09:26 PM
MartinezA92
Insert BS here
10-08-2015 10:38 PM
LucaCarMods
10-03-2015 05:58 AM
Johnny Tater
Engine Performance
09-23-2015 06:10 PM
Quick Reply: Please not another crankcase ventilation thread.
