91 BRG 1.8BP MK turbo build
Old 01-17-2017, 08:18 PM
  #121
Alberto Chipres's Avatar
Jebus. Sweet picture of our lord and savior Robo Cop.
Alberto Chipres is offline
Old 02-04-2017, 03:43 PM
  #122
wackbards's Avatar
Total Cats: 266
Been waiting to do my VVT & MK swap until I had a reliable daily in the stable. Now it's time!
wackbards is offline
Old 02-05-2017, 07:37 PM
  #123
wackbards's Avatar
Total Cats: 266
OK swappage commencing!
The igniter rewire pic on the VVT swap thread has been wrong forever. Here's what it looks like corrected:
here are the wires spliced:
Old 02-11-2017, 12:04 PM
  #124
wackbards's Avatar
Total Cats: 266
Is this the correct pinout for the NB cam sensor (CMP)?
Old 03-19-2017, 07:59 PM
  #125
wackbards's Avatar
Total Cats: 266
Bought a FM heat shield & a FM CAI box about a year ago to see if they would fit with my MK kit. It looks like the heat shield fits with a little bit of relief grinding on the upper lip. The CAI box is going to be a little bit trickier. I ordered up a 135° and a 45° elbow. We'll see if that does the trick.
Old 03-26-2017, 12:46 AM
  #126
wackbards's Avatar
Total Cats: 266
Don't forget to get a bigger bra after getting a VVT boob job.
Old 03-27-2017, 10:07 PM
  #127
wackbards's Avatar
Total Cats: 266
I've just about got the MK turbo to play nice with the FM airbox. I used a 135* and a 45* elbow.
I had to open up the hole a bit to make things fit. Nothing a little speed tape can't class up.
The old exhaust manifold gasket should roughly represent the level of the hood. It's getting just about dialed.
Old 03-28-2017, 09:01 PM
  #128
wackbards's Avatar
Total Cats: 266
Intercooler mounted. Shamelessly stole the mount location from Aiden. I think I bent every fin on that thing goofing around with fitment.
Old 04-01-2017, 03:22 PM
  #129
wackbards's Avatar
Total Cats: 266
I think I've got my IC fitment sorted out, although I'm a little worried about tire clearance. There's ~2 1/4" clearance between the tires and IC pipes with the car on jacks and the wheels at full lock. Other than that, I think it's just a matter of sealing back up the holes I hacked in the under tray.
passenger side w/wheel @ full lock
driver's side w/wheel @ full lock
Old 04-15-2017, 07:25 AM
  #130
wackbards's Avatar
Total Cats: 266
Conti extremecontact sport 205/50 on advanti S2 15x8. ~31.25 lbs without lugs.
Old 04-23-2017, 05:09 PM
  #131
wackbards's Avatar
Total Cats: 266
Pretty much buttoned up here. I'm waiting on a couple clamps to put the hot side IC pipes back in, and some fuel hose.
More importantly, stickers:
Old 04-23-2017, 05:44 PM
  #132
Total Cats: 1,681
Looks good. I like the sticker placement.
shuiend is offline
Old 04-24-2017, 11:47 PM
  #133
wackbards's Avatar
Total Cats: 266
Shiiiiiiit... Coolant reroute spacer is leaking. Guess it's better to find it now before I'm on the road.
Old 05-03-2017, 12:52 AM
  #134
wackbards's Avatar
Total Cats: 266
coolant reroute leak patched up. Now I'm loading my map & calibrating sensors. My VVT OCV solenoid is making racket with the key on/engine off and TS VVT output set to off. This seems fishy.
Old 05-03-2017, 10:07 AM
  #135
Total Cats: 1,681
Unplug it. Get the car working without VVT, then add it back in later.
shuiend is offline
Old 05-03-2017, 03:15 PM
  #136
konmo's Avatar
Total Cats: 23
Nice work man keep it up. I did the same swap/turbo install as this last year and it was one heck of a project. But definitely learned a lot.
konmo is offline
Old 05-03-2017, 03:52 PM
  #137
wackbards's Avatar
Total Cats: 266
Sound advice. I'm more worried that I've cross wired it with something else. I have some MM testing in my future.
Old 05-03-2017, 09:29 PM
  #138
wackbards's Avatar
Total Cats: 266
Car no start. Here's what the composite log looks like. This looks at least like I'm getting a signal from both the cam & crank, but it looks kinda hosed up. Any intuition as to what I've done wrong?
Old 05-03-2017, 10:15 PM
  #139
wackbards's Avatar
Total Cats: 266
tune, log, composite log for ref
File Type: msq
File Type: msl
File Type: csv
Old 05-03-2017, 10:39 PM
  #140
wackbards's Avatar
Total Cats: 266
hmmm... RPM in the log never went above 180. I'm used to seeing cranking RPM in the 3-500 RPM range. It sounded like normal cranking speed...
Quick Reply: 91 BRG 1.8BP MK turbo build
