Supermiata S1 build - Vegas
Old 12-07-2017, 11:12 PM
  #161
williams805's Avatar
Total Cats: 27
What pumps are you running? And how will you control them? On at a certain temp and then fans at a higher temp?
williams805 is offline
Old 12-08-2017, 10:55 AM
  #162
EErockMiata's Avatar
Total Cats: 76
Mayhaps I could ask where you sourced the 10mm alumilite? I want to get some for a splitter but I do not have a local source and shipping is a bizzo.
I love the diff/trans cooler setup. Very GTLM/GT3 spec stuff. It's definitely cool seeing you do a turbo wheel to wheel car. Something different from the 949 brain trust, at least, something different that the public gets to see.
EErockMiata is offline
Old 12-08-2017, 11:06 AM
  #163
Total Cats: 2,376
Our source for alumaite
.31 SNR
emilio700 is offline
Old 01-18-2018, 11:05 PM
  #164
PatCleary's Avatar
Visit the seat mfr website for dimensions. I'm very skinny (6-3, 160lb bicycle racer) so any normal American dude is "big" to me. The HTE-R 400 fits in a cage Miata better than any other FISA seat I have seen. The 400 refers to the wing width, 400mm where most seats are 560-620mm. That's right where the door hoop/hardtop is. Too wide a set and you have to cut part of the wing off and compromise seat position and comfort. AFAIK, no other FIA seat is anywhere near that narrow.
I'm a sticker for getting the seat in the most comfortable and safe position while remaining centered behind the center of the steering wheel. This goes a long way to reducing driver fatigue in enduros. Crusher had a Cobra Evo with a TC cage build around the seat. Every driver that got in it said it was either the most comfortable Miata or most comfortable race car they had ever been in. For me, the seat was a bit too close to the pedals but I mounted it there so normal height drivers could fit in.
Te steering column is angled. In my cars I always have a very long extension on the hub adapter so the wheel is maybe 4-5" further back than OEM. Driver weight further back also helps weight distribution and is safer. The centerline of the wheel and the spot where the shaft attaches to to the dash bar are often a good 1/2" offset since the shaft is angled. I put my seats behind the center of the wheel, not where the shaft attaches to to the dash bar. With a wide seat, that's difficult. I have also driven Miatas that had their seat angled a few degrees to fit the tub and also radically offset from the wheel centerline. I found those excruciating to drive.
edit: I sat in/owned OMP seats other than the HTE-R 400 before buying it. Compared data on OMP's site so I could estimate how I would fit in it. IOW, sit in any OMP seat that you can still find official dimensions for and perhaps extrapolate fit into the HTE-R 400.
You lost man points by quoting the pics BTW
Emilio - Did you have to cut the floor to fit? I'm a similar build but a couple inches taller, and I'm considering better seat options.
PatCleary is offline
Old 01-18-2018, 11:40 PM
  #165
Total Cats: 2,376
No, but I am also very thin. That means I have virtually no "backside padding". A heavy driver that is the same height as I am will sit much higher.
.31 SNR
Old 01-19-2018, 03:41 AM
  #166
BEAVIS's Avatar
We fit the HTE-R 400 in a caged car - the seat is lovely, but it would still sit too high for my liking (6 foot 2). I opted to drop the floor an inch or 2.
I'm not a rotund fella, but I like to sit low. I also chose to leave the butt cushions out for extra height gain.
Oh and yes - right hand drive.
BEAVIS is offline
Old 01-19-2018, 06:19 AM
  #167
PatCleary's Avatar
Thanks Emilio. Looks worth exploring at least.
Old 01-19-2018, 11:26 AM
  #168
Total Cats: 2,376
https://www.miataturbo.net/race-prep...-thread-91760/
.31 SNR
Old 02-01-2018, 11:38 AM
  #169
Total Cats: 2,376
Vegas is at Renderos Racing getting paint, Bass Boat Orange. Interior, underside and engine bay are dove gray gloss. Also decided on a few little changes to the front end after we got it from TC so Alex is taking care of that.
TC made custom flared steel fenders for it. Alex had them copied in composite. Mine are thin FRP with a layer of Kevlar for flexibility. Note the front shock tower to door hoop tie bar that obviates the brake booster, thus the Tilton pedals.
Cleaning up before paint
After paint
engine bay
.31 SNR
Old 03-04-2018, 06:14 PM
  #170
Total Cats: 2,376
Default Paint
So pimp
.31 SNR
Old 03-04-2018, 06:18 PM
  #171
Bass boat paint?!?! That is sexy af
Old 03-04-2018, 06:25 PM
  #172
mx5-kiwi's Avatar
Total Cats: 57
I had my OMP all set to finally bolt in prior to driving 4 hours to the race meet, it was in all square, same basic position as previous seat. Decided on one last seat trial WITH helmet and found the roll cage bar locked my head in position hard against the inner head restraint.
Was lucky I did that final check. I was so concerned with being square, straight, inclined just right for my dodgy back that I totally missed checking the head/helmet area restrictions. Presumably you haven't made the same mistake....
It seems that I have to now relocate the seat about 2-3 cms in, meaning cutting the tunnel etc. Would also like to go a bit lower but that means a whole new floor, cutting oem frame rails the aftermarket AND the frame rail strengtheners......got put in the too hard basket for the time being...
mx5-kiwi is offline
Old 03-04-2018, 06:38 PM
  #173
Total Cats: 2,376
Maybe start a new Thread about your seat?
.31 SNR
Old 03-04-2018, 06:45 PM
  #174
Total Cats: 2,376
I didn't know how this worked. Apparently it's just big flakes you layover whatever color paint. The metal flakes come in different sizes. When they get to a certain size they are called "Bass Boat". I clicked "buy".
.31 SNR
Old 03-04-2018, 07:47 PM
  #175
That's going to be great to watch on sunny days.
Old 03-04-2018, 09:50 PM
  #176
Mobius's Avatar
Total Cats: 365
Exciting.
You know, for as many times as you excuse the quality of the video during it due to the lighting, I think that camera did amazingly well and the quality is fine. Another random old GoPro Hero 2?
Mobius is offline
Old 03-04-2018, 10:51 PM
  #177
Total Cats: 2,376
Originally Posted by Mobius
Exciting.
Samsung S7
.31 SNR
Old 03-05-2018, 11:15 PM
  #178
doward's Avatar
Total Cats: 749
Couple picks I snapped on my way out. John has moved Vegas to its new home on the two post.
Left rear wheel/tire is a 15x11 6UL with a 275/35. Right rear is a 245/40 Maxxis RC1 on 15x10 for this cars eventual usage as a Supermiata S1.
The cage ties in at both shock towers, windshield frame and b pillar. It also has some gussets added as extra A pillar/main hoop FIA bar “style” reinforcement.
doward is offline
Old 03-06-2018, 12:30 AM
  #179
Total Cats: 2,376
I think I'm going to run a 1/4" windshield on this one. The 3/16" shields we usually use rattle a bit above 120mph. Ordered a pile of sensors for it today. Capacitive fuel sender isn't as sensitive to sloshing. Ran one of those on Crusher back in the day. The diff and trans will have sending units going into the MS Evo so we can control the separate fans and pump from the ECU. The ECU will data log those temps plus feed that info through the CAN bus to the AIM MXG.
Can't stop looking at that paint though. I love it.
.31 SNR
Old 03-06-2018, 06:34 PM
  #180
jpreston's Avatar
Total Cats: 176
I think I'm just now seeing the last 3 pages of this thread on a full size (non-cellphone) screen for the first time. ****. So much awesome.
jpreston is offline
Quick Reply: Supermiata S1 build - Vegas
