1.6 turbo mock up pics
Old 03-30-2017, 09:51 AM
mr steve's Avatar
Total Cats: -12
Originally Posted by shuiend
He got the lines from me, and I specifically got them from Charleston Rubber and Gasket.
​​​​​​​ok thanks
mr steve is offline
Old 03-30-2017, 10:05 AM
Total Cats: 1,681
Originally Posted by mr steve
​​​​​​​ok thanks
Go look in your local phone book for hydraulic shops, then call them up and you can probably find one that can make lines for you.
shuiend is offline
Old 03-30-2017, 10:09 AM
mr steve's Avatar
Total Cats: -12
yeah i have the feed line just need to make a return. I will probably just make it
mr steve is offline
Old 03-30-2017, 06:31 PM
wackbards's Avatar
Total Cats: 266
Port the wastegate hole.
It's gonna cost you about $40 if you don't have any of this stuff already, but you can basically pick it all up on the way home from work...
https://www.miataturbo.net/build-thr...6/#post1383638
Heavy Duty Variable Speed Rotary Tool Kit 31 Pc
Dremel 1/8 in. Spear Shaped Tungsten Carbide Cutter for Steel, Stainless Steel, Iron, Ceramics, Plastics, and Hard Wood-9903 - The Home Depot
Permatex 80038 - Prussian Blue | O'Reilly Auto Parts
wackbards is offline
Old 03-31-2017, 07:28 AM
mr steve's Avatar
Total Cats: -12
Thanks man. I've got most of it, need to grab the carbide cutter from HD racing
mr steve is offline
Old 03-31-2017, 08:42 AM
wackbards's Avatar
Total Cats: 266
I recommend a rounded tip cutter like the one I linked to. The Prussian blue is handy for determining exactly where the waste gate flap is making contact.
Old 03-31-2017, 10:14 AM
mr steve's Avatar
Total Cats: -12
thanks
mr steve is offline
Old 04-05-2017, 03:41 PM
mr steve's Avatar
Total Cats: -12
Quick question- anyone know which fittings I need to get the t3 working with this oil line? I already have an m10 x1.5 to 4an for the block.....RACING TURBO UPGRADE OIL COOLING FEED LINE 36" T3 T4 T04E T70 T60 MIATA RX7 RX8 | eBay
I also have the flange that bolts to the feed side of turbo
mr steve is offline
Old 09-07-2017, 02:53 PM
mr steve's Avatar
Total Cats: -12
That downpipe works pretty good! Almost ready to tune.... I guess I'm waiting til after the storm.
mr steve is offline
Old 11-05-2017, 08:45 AM
Lztaas's Avatar
Can you share where you bought your turbo? I am looking for one with the same specs.
not insisting, inquiring.
here are the specs on the turbo:
T3 Internal wastegate COM.42 A/R 45 Trim.48A/R
  • 2.37" Inlet Diameter
  • 2.28" Outlet Diameter
  • Wet Floating Bearing
  • T3 Flange
  • Oil Inlet M12X1.5
  • Compressor Wheel
  • Ind: 1.67"
  • Exd:2.37"
  • Turbiner Wheel
  • 4-Bolt Standard Hot Side
  • Ind: 2.52"
  • Exd: 1.82"
Lztaas is offline
Old 11-05-2017, 06:36 PM
mr steve's Avatar
Total Cats: -12
It was an ebay listing called:
For Turbo Charger T3 Internal wastegate COM.42 A/R 45 Trim.48A/R
But that is no longer active.
In other news this blew a head gasket on the first ride, some pics:
mr steve is offline
Old 11-25-2017, 07:48 PM
mr steve's Avatar
Total Cats: -12
Porting just the hole didn't do the trick, you will need to do a lot of porting of hole and make a valley to the hole. What I ended up with was sort of like this but without the deep valley near the flange.
mr steve is offline
Old 11-27-2017, 01:28 PM
mr steve's Avatar
Total Cats: -12
here is a pic of the car almost finished. it made around 250 on the virtual dyno at 15psi boost creeping. I will see what I can do now with the ebc hooked up...no more power but a lot more midrange
I still need to work on the undertray and get the slicks mounted for an event this weekend.
mr steve is offline
Old 11-29-2017, 05:30 PM
borka's Avatar
Total Cats: 196
250 is impressive for a stock 1.6 with ebay everything.
running megasquirt? what injectors?
borka is offline
Old 12-02-2017, 04:35 PM
mr steve's Avatar
Total Cats: -12
Megasquirt, 670cc injectors, 212KPA. It has an open downpipe that I cut right to about 15"
I have since dialed the boost back to 175kpa
mr steve is offline
Old 12-02-2017, 04:38 PM
mr steve's Avatar
Total Cats: -12
I got a steal on these rims and mounted some used SM7's on there for now to learn the car. Will probably go with A7's or the RS4's eventually depending on whether I really want to switch wheels at events.
mr steve is offline
