megasquirt on low imp 440s
Old 02-24-2008, 04:59 AM
juhanis's Avatar
Default megasquirt on low imp 440s
here it is... no resistors, no tricks, well, maybe some fairy dust. first of all the pics...
that's a horrible afr
idle shot
under hood
here is the video of the "impossible"
http://www.youtube.com/watch?v=8yt63J549Zo
juhanis is offline
Old 02-24-2008, 05:10 AM
dude you kill me good job
Old 02-24-2008, 05:13 AM
juhanis's Avatar
hehe, i just couldnt think of how else to prove it. i was annoyed the last time someone said that my original video wasnt true.
juhanis is offline
Old 02-24-2008, 09:06 AM
paul's Avatar
OK, so who wants to buy my 6 Supra Black Top Low Z 440 injectors? cheap.
paul is offline
Old 02-24-2008, 09:33 AM
AFM Crusader
olderguy's Avatar
Total Cats: 337
Maybe include with Eric's MS?
olderguy is offline
Old 02-24-2008, 09:36 AM
paul's Avatar
I'll PM you about this Bruce.
paul is offline
Old 02-24-2008, 11:27 AM
so the statement about not being compatible was more of a cautionary one rather than a "just wont do it" one?
Old 02-24-2008, 11:41 PM
therieldeal's Avatar
did you have any issues with voltage spikes from the injectors? or did you isolate the injector circuit from the rest of the board? ... or are you just lucky?
therieldeal is offline
Old 02-25-2008, 06:02 AM
juhanis's Avatar
i'm just going to say, i dont know. they just work. i dont really have any issues, and i never have with either setup. the car runs great, i'm now at 10-11psi and climbing. my car must be magical i dont know. plus i didnt build the ms, neogenisis/braineack did.
juhanis is offline
Old 02-25-2008, 06:17 AM
Jefe's Avatar
I'm using DSM 450's...
So is this guy..
http://www.msruns.com/viewtopic.php?t=10708
I must have missed the part where it says we can't use low imp?
Nice vid (not as good as your EMB one though )
Jefe is offline
Old 02-25-2008, 07:39 AM
you silly guy, one of the benefits of the MS is it can run low ohm injectors without resistor packs. you might want to read up on how to correctly setup the PWM settings to run them a little better.
Old 02-25-2008, 08:49 AM
Matt Cramer's Avatar
Total Cats: 67
Yes, it's more cautionary than a warning that it's impossible. The problem isn't that Megasquirt is unable to drive the injectors, so much as a noise issue.
Matt Cramer
www.diyautotune.com
Matt Cramer is offline
Old 02-25-2008, 10:20 AM
That's really easy to fix with a five conductor (4x inj + ground) shielded cable, shield-grounded at the MS box (not at the injectors!). Should reject all the noise you can throw at it. You can get overkill wire by the foot at mcmaster for about $3/foot. Probably elsewhere much cheaper.
Old 02-26-2008, 05:19 AM
juhanis's Avatar
i'll have to look into that, sorry for kinda calling you out on that other thread. i have no idea how the plug wires were on the wrong coils i thought it was something more serious, it worked on my stock stuff. it works GREAT now, so far at 13psi and rising. and thanks for hauling *** on the shipping.
juhanis is offline
Big_gumby
09-30-2015 03:34 PM
JesseTheNoob
09-30-2015 02:44 PM
Goldwar
09-29-2015 09:20 AM
DonPlatt
09-25-2015 02:57 AM
Quick Reply: megasquirt on low imp 440s
