Equivalent of a Greddy turbo?
Old 04-24-2008, 01:10 PM
Default Equivalent of a Greddy turbo?
Been wondering, if the Greddy turbo used the Garrett naming convention, what T2, T3, etc. would it be most closely related to size, spool, and flow wise?
kotomile is offline
Old 04-24-2008, 01:26 PM
Total Cats: 6,608
Here's the compressor map for the TD04H-15G: http://www.stealth316.com/images/td04-15g-cfm.gif
And the specs (copied from http://www.fordlaser.com/viewtopic.p...6b5212665acf53)
Compressor
Wheel 15G
Inducer Diameter (in.) 1.625 / 41.3 mm
Exducer Diameter (in.) 2.182 / 55.4 mm
Trim 55
Turbine
Wheel TD04H
Exducer Diameter (in.) 1.740 / 44.2 mm
Inducer Diameter (in.) 2.047 / 52 mm
Housing TD04H 6cm2 or AR around 0.5
See also:http://fc3spro.com/TECH/TURBO/tmodels.html
Should be pretty easy to do a comparison with this data. To me, it looks a lot like a GT2259. Which is kinda depressing.
Joe Perez is offline
Old 04-24-2008, 01:32 PM
compressor is about the same size output as a T360 or 2560. physically it's smaller. but he wheel design helps allow it to flow more.
01-03-2016 07:18 PM
Trent
10-01-2015 12:15 PM
10-01-2015 11:25 AM
Quick Reply: Equivalent of a Greddy turbo?
