Are these injectors PNP?
1991 Mazda MX6 Turbo 330cc Injectors. 195500-2150.
This auction is for a good set of 4 Nippon-Denso fuel injectors removed from a 1991 Mazda MX6 turbo
These were ohm tested and are all in spec. These are in very good shape!
These injectors will fit in MANY import stock fuel rails. They include injector connectors and are high impedence.No resistor box is needed!
Perfect for a turbo project to use with an SAFC or other standalone and can support around 250 hp on a 4 cylinder.
you guys are bastards....it's like i did all that work for nothing
I will give you credit for them being on the mx6 however:
89-91 B2600 Truck 326cc - Gray Top #195500-2150
which i almost dont think it's right, cause it shares the same engine as the 626 turbo and Probe turbo, and those injectors aren't pnp.....
but the end product will be the right thing.
I'm king of ignoring the FAQ (but then always directing people to it, sorry :gay: )
I'm contemplating selling these. Will they work then? I don't quite understand what you're saying...
Thanks. 330s are a bit rarer than 1.8s and 305s, plus the EMB users.. someone can use em
ok, just did a quick search.
they also DID come in the 88-89 90-92 MX6/626/Probe Turbo.
I could have sworn mine were square...but it's been so long, anyways, part number is the key component here.
Thank you Sir!
***** time!!
These are now for-sale
https://www.miataturbo.net/forums/showthread.php?t=8868
***** time!!
