Flyin Miata - Miata Accessories 1-800-FLY-MX5s (orders) 1-970-242-3800 (tech)
FM Exhaust Brace
Old Feb 3, 2010 | 08:44 PM
Tw34k's Avatar
Total Cats: 31
^ word! ^
Old Feb 4, 2010 | 12:10 AM
bbundy's Avatar
Total Cats: 146
Pictures of my failed U-bolt clamp configuration. I had about 3 of those things fall off even after double nutting them. The U-bolt clamp looks the same Geometry. Even if you tried not to over tighten it would loosen up even without the nuts turning on the U-bolt. Usually it would start rattleing after some hard use. Hot pipe, thermal expansion, and external loading is just too much for the small contact area the U-bolt puts on the pipe.
Vs. my current setup which has been on the car over 2 years driven long road trips and a large number of track days running significantly below spec Miata lap records. It has never come loose or had any problems. large contact area and the clamp ends up the pretty close to the same temperature as the pipe so they expand and contract together.
I haven’t figured out how to post big pictures that you don’t have to click on?
Bob
Attached Thumbnails FM Exhaust Brace-p1010001.jpg   FM Exhaust Brace-p1010002.jpg   FM Exhaust Brace-p1010006.jpg   FM Exhaust Brace-p1010011.jpg
Old Feb 4, 2010 | 12:24 AM
turotufas's Avatar
Total Cats: 7
Default what good
I'm definitely purchasing the exhaust brace for my whip.
I'm still like every time I see that v-band setup. Time machine! aha... FM is the **** though.
Old Mar 3, 2010 | 04:30 PM
JKav's Avatar
Total Cats: 47
Originally Posted by hustler
[rad pics of turbo hangers snipped]
or
AIDS!!!
Pardon the thread necromancy but hustler's pics are worth emphasizing. I really like turbo hangers to take the load off the manifold and the turbine joint. They don't however increase the resonant frequency of the system so its smart to also add a rigid brace between the turbo and the block. Otherwise vibration cracks everything to hell. Ask me how I know.
Old Mar 3, 2010 | 04:38 PM
gospeed81's Avatar
Total Cats: 26
I always thought this would work as it ties motor/tranny/hotside together as a unit...but it was discounted for same reasons Bob posted the one other time it came up here.
Wouldn't the point that the clamp is applied make the difference in whether resonance was a factor or not? I'm thinking the distance from clamp to downpipe flange, and distance in other direction from clamp to first flex section would be critical, and need to be similar.
Old Apr 5, 2010 | 11:00 AM
Faeflora's Avatar
Total Cats: 130
Wouldn't worm-gear-clamping (or something better) the exhaust to the mounting points (3 at muffler, one a little north) help? Basically tying the exhaust to the frame at those points? NVH be damned?
Old Apr 5, 2010 | 12:42 PM
fooger03's Avatar
Total Cats: 230
if you did that, the engine would still move and vibrate about on it's mounts - the exhaust wouldnt --> death to turbo/manifold joint
the entire drivetrain / all moving parts are suspended seperately from the body of the car in one way or another. The exhaust is a 'moving part' even though it might not move very much.
Old Aug 31, 2010 | 11:42 PM
DeerHunter's Avatar
Total Cats: 2,329
A datum point for everyone: I just ran a track day with the FM exhaust brace and the manifold bolts are still tight. Seems to work as advertised.
Old Sep 1, 2010 | 12:02 AM
Full_Tilt_Boogie's Avatar
Total Cats: 409
Have you participated in a similar track event without said brace with loosened manifold bolts as a result?
Old Sep 1, 2010 | 01:58 PM
DeerHunter's Avatar
Total Cats: 2,329
I have, but fuel pump issues prevented me from running for any extended period. Pre-brace, the nuts did come loose during some spirited backroad bombing, so I know I wasn't immune.
Old Sep 1, 2010 | 09:31 PM
Faeflora's Avatar
Total Cats: 130
What fuel pump issues?
Old Sep 1, 2010 | 10:25 PM
DeerHunter's Avatar
Total Cats: 2,329
I installed a TRE high-pressure pump before FM figured out they suck hard. The problem was intermittent and we chased our tails for a long while before it started happening to other customer cars as well, which confirmed the actual cause. I now have a Walbro and all is fine.
Old Mar 28, 2011 | 08:57 PM
kenzo42's Avatar
Total Cats: 13
BFTD.
Any more experiences w/ this, regarding stud stretching/loosening?
Old Apr 20, 2011 | 11:42 AM
soloracer's Avatar
I'm also in for updates since I just bolted one of these up last night.
Old Apr 20, 2011 | 11:53 AM
Vashthestampede's Avatar
Total Cats: 58
I actually plan on ordering on of these today myself. Seems it cant hurt to have the extra support. I have no idea if it'll work with my ARTech 3" dp, but I can always make it work if need be.
Old Apr 20, 2011 | 11:58 AM
I used .051" safety wire to hold my exhaust at the clamp to the rear subframe to stop left/right movement. I definitely felt the shift pattern improvement at the last race, and my bumper ceased melting.
Corky Bell
Prefabbed Turbo Kits
Nov 22, 2016 09:01 PM
Goldwar
Sep 29, 2015 09:20 AM
