Carbon fibre time attack twins
Old Jun 2, 2010 | 08:02 PM
lightyear's Avatar
Total Cats: 93
Default Carbon fibre time attack twins
Hi, i am starting the build of what will be hopefully the lightest turbo miata time attack cars in the world. They will have '99 turbo motors, full cage, carbon fibre everything, and as much metal cut out as we can. We are almost finished stripping the first car-
And the second car is yet to see our wicked ways-
The silver car lost it's fuel tank hump, parcel shelf, and seatbelt towers last night.
If you guys have any sugestions, we are always keen to listen.
They are going in next week to get the cages installed.
Old Jun 2, 2010 | 08:22 PM
curly's Avatar
Cpt. Slow
Total Cats: 1,404
Wow, that's one hell of a statement to make. Do you know what the lightest turbo miata time attack car weighs? AKA: what is your final weight goal?
Plans to acid dip the chassis to get rid of weather proofing?
Old Jun 2, 2010 | 08:41 PM
lightyear's Avatar
Total Cats: 93
I don't know what the lightest car is. But we are going to give it a go. We probably will just grind off the under side with a wire wheel. My na weighs about 1760lbs, and these will be lighter.
Old Jun 3, 2010 | 05:17 AM
KPLAFIN's Avatar
Beat this:
Old Jun 3, 2010 | 05:55 AM
lightyear's Avatar
Total Cats: 93
For weight i couldn't beat it, but i could walk faster than you could push that around a track.
Old Jun 3, 2010 | 09:44 AM
fooger03's Avatar
Total Cats: 230
Originally Posted by KPLAFIN
Beat this:
Needs holes drilled in PPF!!!
And lose the coilovers
Old Jun 3, 2010 | 09:49 AM
fooger03's Avatar
Total Cats: 230
Beat this:
OP:
get rid of the steel safety cups on the engine mounts, ditch the intake manifold support bracket, make sure you have the latest alternator (should already have with the '99), replace the front glass with a poly (or get rid of the front glass and wear a closed face helmet)
cut out the trunk pan, replace with flat aluminum
Old Jun 3, 2010 | 02:01 PM
DEI liberal femininity
Total Cats: 574
carbon's heavy for non structural parts.
Old Jun 3, 2010 | 02:50 PM
turotufas's Avatar
I remember when you told us about this idea. So I'm down to see some custom *****.
Old Jun 3, 2010 | 06:33 PM
lightyear's Avatar
Total Cats: 93
You think???
[QUOTE cut out the trunk pan, replace with flat aluminum [QUOTE]
We have cut out the floor of the boot that the spare wheel sits in and the fuel tank hump, parcel shelf as well as the seat belt towers. It will have a flat floor from the seat to the very back of the car. Probably alloy. We where going to do it in carbon, but decided not too.
Old Jun 6, 2010 | 09:05 PM
lightyear's Avatar
Total Cats: 93
We are going for this look.
Old Jun 6, 2010 | 11:27 PM
is that with a full stock fuel tank etc? impressive
Old Jun 6, 2010 | 11:38 PM
lightyear's Avatar
Total Cats: 93
Yep. The new ones will have a fuel cell next to the driver, on the passenger floor.
Old Jun 7, 2010 | 12:02 AM
WonTon's Avatar
isnt there a reason why our gas tanks are mounted where they are???
Old Jun 7, 2010 | 12:23 AM
lightyear's Avatar
Total Cats: 93
Yes, so you can carry a passenger. Why would you want the tank sitting so high? I know some people will say that it helps with weight distrubution. But the rear wing and rear diffuser will add weight to the rear when you are at speed. I was reading the other day- a car with 50/50 weight static,.. when at speed will end up 40/60 due to font end lift going down the straight. That's why you have to add aero. To balance your car while it is driving.
Old Jun 7, 2010 | 12:26 AM
WonTon's Avatar
i know that (bout the areo). i was just curious....
Old Jun 9, 2010 | 06:00 AM
hf-mx5t's Avatar
Total Cats: 235
sitting next to the fueltank and pump etc, is great in case of a chrash
Old Jun 9, 2010 | 09:37 AM
lightyear's Avatar
Total Cats: 93
I like to live dangerously. Seriously though, we will have the fuel cell boxed in an alloy box, using the original filler point from the oem tank. And i think it's one of the safest places on the cars. Totally surrounded by a rollcage.
Old Jun 9, 2010 | 10:10 AM
My guess is sitting next to a fuel cell, boxed and barred (cage) in a Miata is probably safer than sitting in front of the OE gas tank. That said, I'm surprised any sanctioning body would allow the fuel cell in the car. I know here they've got rules (build guidelines) that specifically work towards separating the fuel from the driver compartment. Actually the ASN (FIA Canada) allowed the NB Miatas to run with the stock fuel tank because of it's location. It was indirectly suggested that fuel cell was sufficiently isolated within the body/chassis to protect it.
Old Jun 9, 2010 | 10:55 AM
Total Cats: 4,368
Attachment 17130
naca ducts need not apply.
